Toggle 2 LEDs back and forth with PPI, GPIOTE and timer
I am using NRF52840 DK to toggle led 3 and 4 back and forth (when LED 3 is ON, LED 4 should be OFF and so on). I have to toggle them in a small time interval of 10ms. I am using SDK 17.02. In order for the power consumption I am using GPIOTE with PPI and timer. Right now I am using a single timer to drive both the LEDs.
void timer_dummy_handler(nrf_timer_event_t event_type, void * p_context){}
static void led_blinking_setup()
    uint32_t compare_evt_addr_RED;
    uint32_t gpiote_task_addr_RED;
    uint32_t compare_evt_addr_IR;
    uint32_t gpiote_task_addr_IR;
    ret_code_t err_code;
    nrf_ppi_channel_t ppi_channel_RED;
    nrf_ppi_channel_t ppi_channel_IR;
    uint32_t ticks_RED = nrfx_timer_ms_to_ticks(&timer_gpio, 10); //same ticks for both IR and RED
    NRF_LOG_INFO("GPIO STARTED");
 nrf_drv_gpiote_out_clear(GPIO_OUTPUT_PIN_NUMBER1);
    nrf_drv_gpiote_out_config_t config = GPIOTE_CONFIG_OUT_TASK_TOGGLE(false);
    nrf_drv_gpiote_out_config_t config1=
    .action  = NRF_GPIOTE_POLARITY_TOGGLE,                                               \
        .init_state =  NRF_GPIOTE_INITIAL_VALUE_HIGH , \
        .task_pin   = true
    err_code = nrf_drv_gpiote_out_init(GPIO_OUTPUT_PIN_NUMBER, &config);
    err_code = nrf_drv_gpiote_out_init(GPIO_OUTPUT_PIN_NUMBER1, &config1);
    nrf_drv_timer_extended_compare(&timer_gpio, NRF_TIMER_CC_CHANNEL0, ticks_RED, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, false);
    err_code = nrf_drv_ppi_channel_alloc(&ppi_channel_RED);
   err_code = nrf_drv_ppi_channel_alloc(&ppi_channel_IR);
    compare_evt_addr_RED = nrf_drv_timer_event_address_get(&timer_gpio, NRF_TIMER_EVENT_COMPARE0);
    gpiote_task_addr_RED = nrf_drv_gpiote_out_task_addr_get(GPIO_OUTPUT_PIN_NUMBER);
    compare_evt_addr_IR = nrf_drv_timer_event_address_get(&timer_gpio, NRF_TIMER_EVENT_COMPARE0);
    gpiote_task_addr_IR = nrf_drv_gpiote_out_task_addr_get(GPIO_OUTPUT_PIN_NUMBER1);
    err_code = nrf_drv_ppi_channel_assign(ppi_channel_RED, compare_evt_addr_RED, gpiote_task_addr_RED);
    err_code = nrf_drv_ppi_channel_assign(ppi_channel_IR, compare_evt_addr_IR, gpiote_task_addr_IR);
    err_code = nrf_drv_ppi_channel_enable(ppi_channel_RED);
      err_code = nrf_drv_ppi_channel_enable(ppi_channel_IR);
    nrf_drv_gpiote_out_task_enable(GPIO_OUTPUT_PIN_NUMBER);
   nrf_drv_gpiote_out_task_enable(GPIO_OUTPUT_PIN_NUMBER1);
The code works perfectly fine. But I believe there is a better way approach rather than this method. By using this method, one of the LED remains ON even after the required time of the activity ends. I need the signal to be precise and accurate and should not course any problem in the timing. They have to be synchronized perfectly. Is there any other better approach to this problem?
Would appreciate your help. Thank you.
  • Yes, just like that (BTW looks like you forgot to check error return code after line 31)
  • Oh yeah. Was just a test code. Will include in the main code after testing Edvin's approach as well. Thank you for pointing out the error. Cheers!!
  • That looks good!
    Thanks for pointing out the forking, .
    I have given the toggle vs set/clr some thought. When you are using PPI I think you will be just fine using toggle, because the execution of the tasks are not dependent on the CPU. Particularly when you use the Fork functionality, these are based on the same event signal.
    If you had a toggle functionality that was done in an event handler in your application, which would require the CPU to execute it is more "scary", because this execution may be interrupted e.g. between the two toggle pin operations, by a higher priority interrupt. In worst case, the event will not be resumed until it occurs again, which may leave one pin in the wrong state.
    Edvin
  • Hai Edvin,
    If I have understood you right, the below-given code would do the trick right? But I have trouble setting up and clearing the pins. So I have left that line empty. Is my approach correct? If so how can u add up the missing line?
        uint32_t compare_evt_addr;
        uint32_t gpiote_task_addr;
        uint32_t compare_evt_addr1;
        uint32_t gpiote_task_addr1;
        nrf_ppi_channel_t ppi_channel;
       // Here comes the LED SET and CLEAR function
        uint32_t ticks_RED = nrfx_timer_ms_to_ticks(&timer, 20);
        nrf_drv_timer_compare(&timer, NRF_TIMER_CC_CHANNEL0, (ticks_RED/2), false);
        nrf_drv_timer_extended_compare(&timer, NRF_TIMER_CC_CHANNEL1, ticks_RED, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, false);
        err_code = nrf_drv_ppi_channel_alloc(&ppi_channel);
        compare_evt_addr = nrf_drv_timer_event_address_get(&timer, NRF_TIMER_EVENT_COMPARE0);
        gpiote_task_addr = nrf_drv_gpiote_out_task_addr_get(GPIO_OUTPUT_PIN_NUMBER);
        compare_evt_addr1 = nrf_drv_timer_event_address_get(&timer, NRF_TIMER_EVENT_COMPARE1);
        gpiote_task_addr1 = nrf_drv_gpiote_out_task_addr_get(GPIO_OUTPUT_PIN_NUMBER2);
        err_code = nrf_drv_ppi_channel_assign(ppi_channel, compare_evt_addr, gpiote_task_addr);
        err_code = nrf_drv_ppi_channel_assign(ppi_channel, compare_evt_addr1, gpiote_task_addr1);
        err_code = nrf_drv_ppi_channel_enable(ppi_channel);
        nrf_drv_gpiote_out_task_enable(GPIO_OUTPUT_PIN_NUMBER2);
    regards,
    Adarsh
  • This is obviously not your entire application, so it is a bit difficult to say what's missing. But you should either use two different ppi channels for gpiote_task_addr and gpiote_task_addr1, or you should use the fork functionality, as we discussed earlier.
    Other than that, it depends on what you have done outside this snippet. How did you set up your tasks on your gpiote_task_add and gpitoe_task_addr1?
    And did you remember to actually start the timer?
    Edvin
