Why twi_scanner returns all 127 addresses on nrf52832?
SDK is nRF5_SDK_17.0.2_d674dde, running on nrf52832, I migrate twi_scanner example to \examples\ble_peripheral\ble_app_gatts_c, if I set handler NULL in nrf_drv_twi_init() of twi_init(), I can get right i2c address. But if I set a true handler, it returns all 127 addresses. I don't know why, would anyone help me? Thanks in advanced. Below is my main.c:
* Copyright (c) 2017 - 2020, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
/** @brief GATT Service client example application main file.
@details This file contains the main source code for a sample client application that uses the
GATT Service. This client can be used to receive Service Changed indications. This is
needed if your application interacts with GATT servers that modify, remove or add
services. A typical course of action if a Service Changed indication is received is to
rediscover the database on the peer device.
For more information about the GATT Service, see "Defined Generic Attribute Profile Service"
in Bluetooth Specification Version 5.0 Vol 3, Part G Section 7.
#include <stdint.h>
#include <string.h>
#include "app_adv.h"
#include "nordic_common.h"
#include "nrf.h"
#include "app_error.h"
#include "ble.h"
#include "ble_srv_common.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "app_timer.h"
#include "bsp.h"
#include "bsp_btn_ble.h"
#include "nrf_ble_gatts_c.h"
#include "boards.h"
#include "ble_gap.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "peer_manager.h"
#include "peer_manager_handler.h"
#include "fds.h"
#include "ble_conn_state.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "nrf_drv_twi.h"
#define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_BLE_CONN_CFG_TAG 1 /**< A tag identifying the SoftDevice BLE configuration. */
#define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
NRF_BLE_GATT_DEF(m_gatt); /**< GATT module instance. */
NRF_BLE_GATTS_C_DEF(m_gatts_c); /**< GATT Service client instance. Handles Service Changed indications from the peer. */
NRF_BLE_QWR_DEF(m_qwr); /**< Context for the Queued Write module.*/
BLE_DB_DISCOVERY_DEF(m_ble_db_discovery); /**< DB discovery module instance. */
NRF_BLE_GQ_DEF(m_ble_gatt_queue, /**< BLE GATT Queue instance. */
NRF_SDH_BLE_PERIPHERAL_LINK_COUNT,
NRF_BLE_GQ_QUEUE_SIZE);
/* TWI instance. */
static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(0);
static bool m_erase_bonds; /**< Bool to determine if bonds should be erased before advertising starts. Based on button push upon startup. */
static uint8_t m_pm_peer_srv_buffer[ALIGN_NUM(4, sizeof(ble_gatt_db_srv_t))] = {0}; /**< Data written to flash by peer manager must be aligned on 4 bytes.
When loading and storing we will treat this byte array as a ble_gatt_db_srv_t.
We use a static variable because it is written asynchronously. */
/**@brief Function for assert macro callback.
@details This function will be called in case of an assert in the SoftDevice.
@warning This handler is an example only and does not fit a final product. You need to analyze
how your product is supposed to react in case of Assert.
@warning On assert from the SoftDevice, the system can only recover on reset.
@param[in] line_num Line number of the failing ASSERT call.
@param[in] p_file_name File name of the failing ASSERT call.
/**@brief Function for handling the GATT Service Client errors.
* @param[in] nrf_error Error code containing information about what went wrong.
static void gatt_c_error_handler(uint32_t nrf_error)
APP_ERROR_HANDLER(nrf_error);
/**@brief Function for the LEDs initialization.
@details Initializes all LEDs used by the application.
static void leds_init(void)
/**@brief Function for the Timer initialization.
@details Initializes the timer module.
static void timers_init(void)
ret_code_t err_code;
err_code = app_timer_init();
@details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
device including the device name, appearance, and the preferred connection parameters.
ble_gap_conn_params_t gap_conn_params;
(const uint8_t *)DEVICE_NAME,
strlen(DEVICE_NAME));
gap_conn_params.min_conn_interval = MSEC_TO_UNITS(MIN_CONN_INTERVAL_MSEC, UNIT_1_25_MS);
gap_conn_params.max_conn_interval = MSEC_TO_UNITS(MAX_CONN_INTERVAL_MSEC, UNIT_1_25_MS);
gap_conn_params.slave_latency = SLAVE_LATENCY;
gap_conn_params.conn_sup_timeout = MSEC_TO_UNITS(CONN_SUP_TIMEOUT_MSEC, UNIT_10_MS);
@param[out] p_erase_bonds Boolean that will be set to true if the device is
woken up by the BSP_EVENT_CLEAR_BONDING_DATA event.
bsp_event_t startup_event;
err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, NULL);
/**@brief Function for handling events from the GATT Servive client module.
@param[in] p_evt GATT Service event.
static void gatts_evt_handler(nrf_ble_gatts_c_evt_t * p_evt)
switch (p_evt->evt_type)
case NRF_BLE_GATTS_C_EVT_DISCOVERY_COMPLETE:
NRF_LOG_INFO("GATT Service and Service Changed characteristic found on server.");
err_code = nrf_ble_gatts_c_handles_assign(&m_gatts_c,
p_evt->conn_handle,
&p_evt->params.srv_changed_char);
pm_peer_id_t peer_id;
err_code = pm_peer_id_get(p_evt->conn_handle, &peer_id);
ble_gatt_db_srv_t srv_db_to_store;
srv_db_to_store.charateristics[0] = p_evt->params.srv_changed_char;
memcpy(m_pm_peer_srv_buffer, &srv_db_to_store, sizeof(ble_gatt_db_srv_t));
err_code = pm_peer_data_remote_db_store(peer_id,
(ble_gatt_db_srv_t *)m_pm_peer_srv_buffer,
sizeof(m_pm_peer_srv_buffer),
NULL);
if (err_code == NRF_ERROR_STORAGE_FULL)
err_code = fds_gc();
err_code = nrf_ble_gatts_c_enable_indication(&m_gatts_c, true);
} break;
case NRF_BLE_GATTS_C_EVT_DISCOVERY_FAILED:
NRF_LOG_INFO("GATT Service or Service Changed characteristic not found on server.");
case NRF_BLE_GATTS_C_EVT_DISCONN_COMPLETE:
NRF_LOG_INFO("GATTS Service client disconnected connection handle %i.", p_evt->conn_handle);
case NRF_BLE_GATTS_C_EVT_SRV_CHANGED:
NRF_LOG_INFO("Service Changed indication received.");
NRF_LOG_INFO("Handle range start: %04x", p_evt->params.handle_range.start_handle);
NRF_LOG_INFO("Handle range end: %04x", p_evt->params.handle_range.end_handle);
/**@brief Function for handling Peer Manager events.
* @param[in] p_evt Peer Manager event.
static void pm_evt_handler(pm_evt_t const * p_evt)
pm_handler_on_pm_evt(p_evt);
pm_handler_flash_clean(p_evt);
switch (p_evt->evt_id)
case PM_EVT_BONDED_PEER_CONNECTED:
if (peer_id != PM_PEER_ID_INVALID)
ble_gatt_db_srv_t * remote_db;
remote_db = (ble_gatt_db_srv_t *)m_pm_peer_srv_buffer;
uint32_t data_len = sizeof(m_pm_peer_srv_buffer);
err_code = pm_peer_data_remote_db_load(peer_id, remote_db, &data_len);
if (err_code == NRF_ERROR_NOT_FOUND)
NRF_LOG_DEBUG("Could not find the remote database in flash.");
err_code = nrf_ble_gatts_c_handles_assign(&m_gatts_c, p_evt->conn_handle, NULL);
// Discover peer's services.
memset(&m_ble_db_discovery, 0x00, sizeof(m_ble_db_discovery));
err_code = ble_db_discovery_start(&m_ble_db_discovery, p_evt->conn_handle);
// Check if the load was successful.
NRF_LOG_INFO("Remote Database loaded from flash.");
// Assign the loaded handles to the GATT Service client module.
ble_gatt_db_char_t service_changed_handles = remote_db->charateristics[0];
p_evt->conn_handle,
&service_changed_handles);
// Enable indications.
} break;
case PM_EVT_CONN_SEC_SUCCEEDED:
// Check it the Service Changed characteristic handle exists in our client instance.
// If it is invalid, we know service discovery is needed.
// (No database was loaded during @ref PM_EVT_BONDED_PEER_CONNECTED)
if (m_gatts_c.srv_changed_char.characteristic.handle_value == BLE_GATT_HANDLE_INVALID)
// Peer data was cleared from the flash. Start advertising with an empty list of peers.
advertising_start(false);
// No implementation needed.
/**@brief Function for initializing the Peer Manager.
void peer_manager_init(void)
err_code = pm_init();
sec_param.bond = SEC_PARAM_BOND;
sec_param.mitm = SEC_PARAM_MITM;
sec_param.io_caps = SEC_PARAM_IO_CAPABILITIES;
sec_param.oob = SEC_PARAM_OOB;
sec_param.min_key_size = SEC_PARAM_MIN_KEY_SIZE;
sec_param.max_key_size = SEC_PARAM_MAX_KEY_SIZE;
sec_param.kdist_own.enc = 1;
sec_param.kdist_own.id = 1;
sec_param.kdist_peer.enc = 1;
sec_param.kdist_peer.id = 1;
/**@brief Function for handling database discovery events.
@details This function is callback function to handle events from the database discovery module.
Depending on the UUIDs that are discovered, this function should forward the events
to their respective services.
@param[in] p_event Pointer to the database discovery event.
static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
nrf_ble_gatts_c_on_db_disc_evt(&m_gatts_c, p_evt);
/**@brief Function for handling connection events.
@param[in] p_ble_evt Bluetooth stack event.
static void on_connect(ble_evt_t const * p_ble_evt)
NRF_LOG_INFO("Connected.");
err_code = nrf_ble_qwr_conn_handle_assign(&m_qwr, p_ble_evt->evt.gap_evt.conn_handle);
/**@brief Function for handling timeout BLE stack events.
static void on_timeout(ble_evt_t const * p_ble_evt)
case BLE_GATTC_EVT_TIMEOUT:
case BLE_GATTS_EVT_TIMEOUT:
* @param[in] p_ble_evt Bluetooth stack event.
* @param[in] p_context Unused.
pm_handler_secure_on_connection(p_ble_evt);
case BLE_GAP_EVT_CONNECTED:
on_connect(p_ble_evt);
} break;
NRF_LOG_INFO("Disconnected.");
ble_gap_phys_t const phys =
.rx_phys = BLE_GAP_PHY_AUTO,
.tx_phys = BLE_GAP_PHY_AUTO,
} break;
err_code = sd_ble_gatts_sys_attr_set(p_ble_evt->evt.gatts_evt.conn_handle, NULL, 0, 0);
// fall-through.
on_timeout(p_ble_evt);
@details Initializes the SoftDevice and the BLE event interrupt.
uint32_t ram_start = 0;
// Enable BLE stack.
// Register handler for BLE events.
/** @brief Database discovery initialization.
static void db_discovery_init(void)
ble_db_discovery_init_t db_init;
memset(&db_init, 0, sizeof(db_init));
db_init.evt_handler = db_disc_handler;
db_init.p_gatt_queue = &m_ble_gatt_queue;
ret_code_t err_code = ble_db_discovery_init(&db_init);
static void log_init(void)
/**@brief Function for handling the idle state (main loop). If there is no pending log operation,
then sleep until next the next event occurs.
nrf_pwr_mgmt_run();
/**@brief Function for initializing the GATT module.
static void gatt_init(void)
ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
* application about an error.
nrf_ble_gatts_c_init_t gatts_c_init = {0};
// Initialize GATTS Client Module.
gatts_c_init.evt_handler = gatts_evt_handler;
gatts_c_init.err_handler = gatt_c_error_handler;
gatts_c_init.p_gatt_queue = &m_ble_gatt_queue;
err_code = nrf_ble_gatts_c_init(&m_gatts_c, &gatts_c_init);
* @brief TWI events handler.
void twi_handler(nrf_drv_twi_evt_t const * p_event, void * p_context)
switch (p_event->type)
case NRF_DRV_TWI_EVT_DONE:
if (p_event->xfer_desc.type == NRF_DRV_TWI_XFER_RX)
* @brief UART initialization.
void twi_init (void)
const nrf_drv_twi_config_t twi_lm75b_config = {
.scl = 26,
.sda = 25,
.frequency = NRF_DRV_TWI_FREQ_400K,
.interrupt_priority = APP_IRQ_PRIORITY_HIGH,
.clear_bus_init = false
err_code = nrf_drv_twi_init(&m_twi, &twi_lm75b_config, twi_handler, NULL);
nrf_drv_twi_enable(&m_twi);
/**@brief Function for initializing all the modules used in this example application.
static void modules_init(void)
uint8_t address;
uint8_t sample_data;
bool detected_device = false;
log_init();
leds_init();
timers_init();
buttons_leds_init(&m_erase_bonds);
power_management_init();
ble_stack_init();
gap_params_init();
gatt_init();
db_discovery_init();
services_init();
advertising_init();
peer_manager_init();
twi_init();
for (address = 1; address <= 63; address++)
err_code = nrf_drv_twi_rx(&m_twi, address, &sample_data, sizeof(sample_data));
if (err_code == NRF_SUCCESS)
detected_device = true;
//if (sample_data != 0)
NRF_LOG_INFO("TWI device detected at address 0x%x.", address);
NRF_LOG_FLUSH();
if (!detected_device)
NRF_LOG_INFO("No device was found.");
NRF_LOG_FLUSH();
/**@brief Function for application main entry.
// Initialize.
modules_init();
// Start execution.
NRF_LOG_INFO("GATT Service client started.");
advertising_start(m_erase_bonds);
// Enter main loop.
for (;;)
idle_state_handle();
    When you don't have an event handler, the TWI TX function calls are blocking, and you the function will wait in the event handler until the transfer completes, either with an Ack or a Nack.
    When you do have an event handler, the TWI transfer calls are no longer blocking, and the return value of the nrf_drv_twi_rx() calls returns NRF_SUCCESS unless something is wrong (full buffer, for example).
    What you need to do if you have an event handler is that you need to check your events instead of the return value from nrf_drv_twi_rx(). If I were to modify the twi_scanner() to use an event handler, it would look something like this:
     * Copyright (c) 2016 - 2020, Nordic Semiconductor ASA
    /** @file
     * @defgroup tw_scanner main.c
     * @ingroup nrf_twi_example
     * @brief TWI Sensor Example main file.
     * This file contains the source code for a sample application using TWI.
    #include <stdio.h>
    #include "boards.h"
    /* TWI instance ID. */
    #if TWI0_ENABLED
    #define TWI_INSTANCE_ID     0
    #elif TWI1_ENABLED
    #define TWI_INSTANCE_ID     1
     /* Number of possible TWI addresses. */
     #define TWI_ADDRESSES      127
    /* TWI instance. */
    static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID);
    volatile bool xfer_done = false;
    static void my_twi_evt_handler(nrf_drv_twi_evt_t const * p_event, void * p_context)
        uint8_t address;
        switch(p_event->type)
                //NRF_LOG_INFO("NRF_DRV_TWI_EVT_DONE");
                address = p_event->xfer_desc.address;
                NRF_LOG_INFO("TWI device detected at address 0x%08x", address);
            case NRF_DRV_TWI_EVT_ADDRESS_NACK:
                //NRF_LOG_INFO("NRF_DRV_TWI_EVT_ADDRESS_NACK");
            case NRF_DRV_TWI_EVT_DATA_NACK:
                //NRF_LOG_INFO("NRF_DRV_TWI_EVT_DATA_NACK");
        xfer_done = true;
     * @brief TWI initialization.
        const nrf_drv_twi_config_t twi_config = {
           .scl                = 27,//ARDUINO_SCL_PIN,
           .sda                = 26,//ARDUINO_SDA_PIN,
           .frequency          = NRF_DRV_TWI_FREQ_100K,
           .clear_bus_init     = true
        err_code = nrf_drv_twi_init(&m_twi, &twi_config, my_twi_evt_handler, NULL);
        uint8_t address;
        NRF_LOG_INFO("TWI scanner started.");
        NRF_LOG_FLUSH();
        twi_init();
        for (address = 1; address <= TWI_ADDRESSES; address++)
                //NRF_LOG_INFO("TWI device detected at address 0x%08x.", address);
                NRF_LOG_INFO("twi_rx() returned 0x%02x", err_code);
            //NRF_LOG_FLUSH();
            while (!xfer_done)
                //wait
            xfer_done = false;
            NRF_LOG_FLUSH();
        while (true)
            NRF_LOG_PROCESS();
            /* Empty loop. */
    Please note how the xfer_done() is used. I added this because when you have an event handler, nrf_drv_twi_rx() is no longer blocking, so if you call it too many times too fast, it would return 0x11 = 17 = NRF_ERROR_BUSY (because the transfer buffers are full).
    Edvin
  • Thank you very much:). I also update codes as below and see something, I'm trying to figure out "When you don't have an event handler, the TWI TX function calls are blocking", because I can't see where TWI TX function is called.
  • sorry, I meant nrf_drv_twi_rx(), not "TWI TX function". And that is still found in the main() function in the main.c file that I uploaded.
