We have implemented a custom Watchdog Timeout handler, where we do the stack-dump. It has worked fine and we were able to analyze and fix the Watchdog resets. But now for one of the resets, the stack dump is missing. The RESETREAS register always points to WDT as the reason. There is no stack-dump and also GDB doesn't hit the NRF_BREAKPOINT_COND placed at the very beginning(before the stackdump) of Watchdog Timeout handler. (but it hits the breakpoint in main) The guess here is, watchdog timeout might be inside some high priority interrupt or at the same time another high priority interrupt is set. How can I debug this issue? Can I log any registers in the beginning to know what other interrupts were present?
PS:
1. This issue happened when we changed some code of a module that uses TWI interface.
2. These are my WDT settings
NRFX_WDT_CONFIG_IRQ_PRIORITY 0
NRFX_WDT_CONFIG_NO_IRQ 0
