Cannot read full CA certificate
I want to read the CA certificate stored inside the modem, unfortunately the modem_key_mgmt_read function cannot read a certificate bigger than 2kb even ifCONFIG_AT_CMD_RESPONSE_MAX_LEN is set to 4kb(way more than needed). It does not return any error, just an incomplete certificate.
The modem_key_mgmt_write seems to work because I can get the TLS connection.
I have prepared a sample code to reproduce the problem please see the attached file. The relevant code is inside reproduce_bug function.
NCS 1.3.1
Modem fw 1.2.1
Is there any configuration that I have to do in order to be able to read the full certificate?
Vlad
1018.mqtt_simple.zip
    Where does the certificate come from?
    I have seen a similar case before, and then the issue was with the certificate itself.
    I also see the same behavior, but when I enable more logging, particularly in the at_cmd library, I see that the full certificate is read out of the modem:
    [00:07:01.415,954] [1B][0m<dbg> at_cmd.at_write: Sending command
    at%cmng=2,0,0[1B][0m
    [00:07:01.431,762] [1B][0m<dbg> at_cmd.at_write: Awaiting response for
    [00:07:01.439,605] [1B][0m<dbg> at_cmd.socket_thread_fn: at_cmd_rx 2242 bytes, %CMNG: 0,0,"0000000000000000000000000000000000000000000000000000000000000000","-----BEGIN CERTIFICATE-----
    MIIGCzCCA/OgAwIBAgIUU72NL4Kzf1mkLA4CItvWJhRVA8UwDQYJKoZIhvcNAQEL
    BQAwgZQxCzAJBgNVBAYTAlJPMRwwGgYDVQQKDBNSYXB0b3IgVGVjaG5vbG9naWVz
    MT4wPAYDVQQLDDVSYXB0b3IgVGVjaG5vbG9naWVzIFNlbGYgU2lnbmVkIENlcnRp
    ZmljYXRlIEF1dGhvcml0eTEnMCUGA1UEAwwed2lyZXBhcy5yYXB0b3ItdGVjaG5v
    bG9naWVzLnJvMB4XDTIwMTAyMDA3MTQ0MVoXDTIxMTAyMDA3MTQ0MVowgZQxCzAJ
    BgNVBAYTAlJPMRwwGgYDVQQKDBNSYXB0b3IgVGVjaG5vbG9naWVzMT4wPAYDVQQL
    DDVSYXB0b3IgVGVjaG5vbG9naWVzIFNlbGYgU2lnbmVkIENlcnRpZmljYXRlIEF1
    dGhvcml0eTEnMCUGA1UEAwwed2lyZXBhcy5yYXB0b3ItdGVjaG5vbG9naWVzLnJv
    MIICIjANBgkqhkiG9w0BAQEFAAOCAg8AMIICCgKCAgEA5okWs/YG5k63dukkeJdS
    NnO9hIgKFg+5CrU2bl0guIsPBHJDp2+2EwSt0vxtoHg4TW/UiZWNE1DpUCu9sGHq
    MxCK8SNdU0egEPBZXEQzycNBZlRCi97Sj0ka4hNxoV77sH9bwb52xatq9rLQ5hIW
    TU4pmBcgzhpJ2htrjLVCmiuv+y3DHRxd8yqrEaRdRzKj058aumJAUDOX0+TaQe1A
    v2cbu5gcg4Hqe8tbflC5jaDhgze3NTuB7O75e6nBjQkcYS9lTG6HTG+9N+uc4++x
    duMVLHjoSYWZP0sXOiKReSJDcNoClERKXr8L3ERZZl+ABPLkyYq3hesLFDeAgwgB
    YcwJmjWzfXcZXyLKLr+MoArJsrDk3S0cM1GSTyt0qtRh9b98yV06DxYCirXuuhiD
    xTiIqJJbPkD/pnZcsWPApEEQwnZ06kcOs9A8PRQIsDvIgEm1JU0SYl/ZKkdg4Hdv
    sqIaQ+gQtE75Yd003aVIWYT5FZHap57JDgaRgbYPHx8IFf0Z7FOVNn/zZHg5wG8x
    L4TFFI4ggUuz6tH42JNC8s4l4dDRRnd4Fkd1FV51D3gnGLW14UFGhgRn53pxDmjU
    mWFtXOYTIF0/YCwvNcmBB1PfK43E19BKI9B9ORcxGgDhJQz3g1gQWcb/e8O5ktOb
    EvuDsepZXjyNTZFTU5GkiQkCAwEAAaNTMFEwHQYDVR0OBBYEFPiZU2VhNbfFdy8Q
    DhwFcN1+VLK5MB8GA1UdIwQYMBaAFPiZU2VhNbfFdy8QDhwFcN1+VLK5MA8GA1Ud
    EwEB/wQFMAMBAf8wDQYJKoZIhvcNAQELBQADggIBAK0ZjZ8bTfZGPIkw+h9lh2Gl
    pruDECnnxtCZnYaGqLyG2jzEdi+yEWv1Z5smduNmRlcxzt2Ypo0364Xqyegl0MFb
    jlzMLGb93e/eURlqFcTOnNEEVDwjItzy1n62V5Pqpa8/S0A5iqaLegI4n6/VFtbU
    RFy1OTZZtl6e9j5GO5hOOfTU0JqOQv6LPrnwedsCslRaMaEG5Ac/k/fquJICM0Yu
    447Zu1gcdfFFCl/vC2HmeD8weDkrQTelr4frlC5iYX70yrUaOlE8A3vcS2WWUNsM
    0n42bXzSni5UNUPfFw/40rETv0GU/FJC+izLAtUkd/rrnk7uq4+kuDj0EqjgseCk
    UfnvpEopRUJI2zfQ+wtuywDn/GWE4yNFnYw5+9U3/IGU+WmV2C/IJtYsn00EWbzr
    TGjEHRWhNMwkQBxsPIcev6ytUeHduAP69MSy8N/BrDaQQu7naMXTXts1LHlDQv1s
    9387Eiy1FBblJcrnzVa/9EpekX9Xb1Suekm/fDACmSd0cn3I3hOKgtjIVRtqOx5s
    yWVhJ5UALBvmvg1LgKgU1KH71sOqQAWuRokHUI2p7f8DHyNXUoNcDUY8Nj+JbX4H
    BpxnMBPeBxzaBqxUE1Ol2pwyS9ZyZf6SZD0jxl3FJg3SDI86Z2Rh6EzJ1sQN0B6J
    T9dqRC46h+0ShzkwxGIP
    -----END CERTIFICATE-----
    OK
    But, for some reason, the full certificate is not forwarded to the modem_key_mgmt library. The same behavior is also seen in the AT host library.
    I will continue to investigate why the full certificate is not forwarded to the modem_key_mgmt library.
    Didrik
  • Hi Didrik,
    Thank you for your help.
    It's a self signed certificate generated by openssl. It's just a regular x509 certificate, nothing fancy about it.
    I took a deeper look at at_cmd file and it seems that the parser confuses the certificate string with the AT "OK" string. The certificate stops right before the "OK" characters. What happens is as follows:
    - The modem returns the full certificate (at_cmd.c line 146)
    - at_cmd calculates the payload_len with get_return_code (at_cmd.c 177)
    - get_return_code calculates the length based on the position of the "OK" or "ERROR" response
    - get_return_code miscalculates the length of the response because strstr finds the wrongs "OK" (at_cmd.c 73)
    get_return_code should try to find the last "OK" or "ERROR" not the first.
    Vlad
  • Yes, that certainly sounds plausible. I'll inform our developers about your findings.
