Power Profiler showing negative current for external DUT
I am using the Power Profiler Kit (Rev. 1.1.1.) with Power Profiler app (v2.3.1) to measure power consumption on an external DUT. The issue I am facing is negative current values shown by the Power Profiler app when I set the PPK output (regulated) voltage to around 2 V or less. Negative values are shown when nRF chip on my DUT is in low-power mode, and when it is not in low power mode (e.g. advertising) it seems to give logical measurements. If I set the output voltage to more than 2 V, I get currents of 4-5 mA or more while my DUT is in low-power mode, not sure what is the cause of this, but I would like to at least resolve the issue of negative idle currents with low output voltage.
My test setup is as follows, taken from the PPK User Guide:
- PPK stacked on top of a nRFDK52840,
- The nRFDK52840 connected to the PC with a USB cable,
- Power Supply switch on the PPK set to Regulator position,
- Power Select switch on the PPK set to External position.
Note that there is no battery or another power source connected to the DUT, it is powered solely from the PPK.
I have found a similar issue on the DevZone, and the answer here is that PPK cannot be stacked on top of the DK when using the voltage regulator (if I understood it correctly):
https://devzone.nordicsemi.com/f/nordic-q-a/59474/power-profiler-showing-negative-current
Besides this, an answer to another questions suggests that PPK has to be powered through the DK, because USB supply on the PPK is faulty:
https://devzone.nordicsemi.com/f/nordic-q-a/36162/power-profiler-graph-is-in-negative-region-and-average-current-also-appears-to-be-negative
Please advise on how to proceed with measuring the consumption of an external DUT.
Armin
