nRF52840 examples with LFRC and calibration?
I am designing a custom board with a nRF52840 module that has no 32.768 kHz crystal embedded in it and as a first step want to test it with some examples that use only RC LFCLK.
The Blinky example doesn’t have any clock configured in the sdk_config.h (even the section for such configuration is missing), so can I assume that this example uses LFRC as it declared as default source  in the documentation?
Which other examples use LFRC and is there any example with a calibration?
Thanks
    All project configurations for the 52840 DK (pca10056) use the LFXTAL by default, but you can easily change this in the project's sdk_config header.
    Softdevice LFRC configuration
    // <o> NRF_SDH_CLOCK_LF_SRC  - SoftDevice clock source.
    // <0=> NRF_CLOCK_LF_SRC_RC
    // <1=> NRF_CLOCK_LF_SRC_XTAL
    // <2=> NRF_CLOCK_LF_SRC_SYNTH
    #ifndef NRF_SDH_CLOCK_LF_SRC
    #define NRF_SDH_CLOCK_LF_SRC 0
    // <o> NRF_SDH_CLOCK_LF_RC_CTIV - SoftDevice calibration timer interval.
    #ifndef NRF_SDH_CLOCK_LF_RC_CTIV
    #define NRF_SDH_CLOCK_LF_RC_CTIV 16
    // <o> NRF_SDH_CLOCK_LF_RC_TEMP_CTIV - SoftDevice calibration timer interval under constant temperature.
    // <i> How often (in number of calibration intervals) the RC oscillator shall be calibrated
    // <i>  if the temperature has not changed.
    #ifndef NRF_SDH_CLOCK_LF_RC_TEMP_CTIV
    #define NRF_SDH_CLOCK_LF_RC_TEMP_CTIV 2
    // <o> NRF_SDH_CLOCK_LF_ACCURACY  - External clock accuracy used in the LL to compute timing.
    // <0=> NRF_CLOCK_LF_ACCURACY_250_PPM
    // <1=> NRF_CLOCK_LF_ACCURACY_500_PPM
    // <2=> NRF_CLOCK_LF_ACCURACY_150_PPM
    // <3=> NRF_CLOCK_LF_ACCURACY_100_PPM
    // <4=> NRF_CLOCK_LF_ACCURACY_75_PPM
    // <5=> NRF_CLOCK_LF_ACCURACY_50_PPM
    // <6=> NRF_CLOCK_LF_ACCURACY_30_PPM
    // <7=> NRF_CLOCK_LF_ACCURACY_20_PPM
    // <8=> NRF_CLOCK_LF_ACCURACY_10_PPM
    // <9=> NRF_CLOCK_LF_ACCURACY_5_PPM
    // <10=> NRF_CLOCK_LF_ACCURACY_2_PPM
    // <11=> NRF_CLOCK_LF_ACCURACY_1_PPM
    #ifndef NRF_SDH_CLOCK_LF_ACCURACY
    #define NRF_SDH_CLOCK_LF_ACCURACY 1
  • I was referring  to this example, which doesn’t have any clock initialization in the the sdk_config.h (even the section for such configuration or any NRF_SDH_CLOCK* is missing):
    …\SDK17\examples\peripheral\blinky\pca10056\blank\ses\blinky_pca10056.emProject
    So the initial question is still on the table Wink
    Thanks
  • Sorry, I just assumed you were using the Bluetooth blinky example. The blinky example you're referring to does not use the 32K clock source, only the HFINT.
  • Ok, thanks, but could you point me to some example in SDK that shows
    Calibrating the 32.768 kHz RC oscillator
    Not necessary to be for PCA10056 - I anyway have only PCA10040 so far ...
    Thanks
  • None of the SDK peripheral examples includes clock calibration as far as I can tell, but the clock driver documentation does explain how you can enable it (link). I would recommend you to start with the Real Time Counter Example as it already includes the clock driver. I can also try to set up a simple example if needed, just let me know.
