ble_app_uart add i2c slave power consumption
Hi Nordic experts:
I am working with sdk 17.0.2 nrf52840 ble_app_uart example project. I added twis i2c slave functionality in this project, and the project is working fine.Adding procedure as below
step1: nRF_Drivers include nrf_drv_twi.c, nrfx_twi.c and nrfx_twis.c
step2: sdk_config define TWIS_ENABLED 1 and define TWIS0_ENABLED 1. Here i define these in app_config.h
1106.sdk_config.h
7065.app_config.h
step3: main.c
          (1)include twis.c
          (2)mark off uart_init()
          (3)mark off tuttons_leds_init()
          (4)mark off printf("\r\nUART started.\r\n");
          (5)call init_twis().
          (6)modify APP_ADV_INTERVAL . From 40ms to 546ms
          (7)modify APP_ADV_DURATION. From 18000 to BLE_GAP_ADV_TIMEOUT_GENERAL_UNLIMITED
 * Copyright (c) 2014 - 2020, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup ble_sdk_uart_over_ble_main main.c
 * @ingroup  ble_sdk_app_nus_eval
 * @brief    UART over BLE application main file.
 * This file contains the source code for a sample application that uses the Nordic UART service.
 * This application uses the @ref srvlib_conn_params module.
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "ble_hci.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "app_timer.h"
#include "ble_nus.h"
#include "app_uart.h"
#include "bsp_btn_ble.h"
#include "nrf_pwr_mgmt.h"
#if defined (UART_PRESENT)
#include "nrf_uart.h"
#if defined (UARTE_PRESENT)
#include "nrf_uarte.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "app_config.h"
#include "twis.h"
#define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
#define DEVICE_NAME                     "Nordic_UART"                               /**< Name of device. Will be included in the advertising data. */
#define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
#define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
//#define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
#define    APP_ADV_INTERVAL                874
//#define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define    APP_ADV_DURATION                BLE_GAP_ADV_TIMEOUT_GENERAL_UNLIMITED         /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
#define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
#define SLAVE_LATENCY                   0                                           /**< Slave latency. */
#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
#define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
/**@brief Function for assert macro callback.
 * @warning This handler is an example only and does not fit a final product. You need to analyse
 * @param[in] line_num    Line number of the failing ASSERT call.
 * @param[in] p_file_name File name of the failing ASSERT call.
/**@brief Function for initializing the timer module.
static void timers_init(void)
 *          the device. It also sets the permissions and appearance.
    uint32_t                err_code;
                                          strlen(DEVICE_NAME));
    APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling the data from the Nordic UART Service.
 * @details This function will process the data received from the Nordic UART BLE Service and send
 *          it to the UART module.
 * @param[in] p_evt       Nordic UART Service event.
/**@snippet [Handling the data received over BLE] */
        uint32_t err_code;
        for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
            do
                err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
                if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                    NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
            } while (err_code == NRF_ERROR_BUSY);
        if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
            while (app_uart_put('\n') == NRF_ERROR_BUSY);
    uint32_t           err_code;
    ble_nus_init_t     nus_init;
    // Initialize NUS.
/**@brief Function for handling an event from the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module
 *          which are passed to the application.
 * @note All this function does is to disconnect. This could have been done by simply setting
 *       the disconnect_on_fail config parameter, but instead we use the event handler
 *       mechanism to demonstrate its use.
    uint32_t err_code;
/**@brief Function for handling errors from the Connection Parameters module.
    // Prepare wakeup buttons.
    uint32_t err_code;
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
        case BLE_ADV_EVT_IDLE:
            sleep_mode_enter();
    uint32_t err_code;
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connected");
            NRF_LOG_INFO("Disconnected");
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
            // Pairing not supported
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
            // No implementation needed.
/**@brief Function for the SoftDevice initialization.
 * @details This function initializes the SoftDevice and the BLE event interrupt.
    ret_code_t err_code;
    uint32_t ram_start = 0;
    // Enable BLE stack.
/**@brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
    if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
        m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
        NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
    NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                  p_gatt->att_mtu_desired_central,
                  p_gatt->att_mtu_desired_periph);
/**@brief Function for initializing the GATT library. */
void gatt_init(void)
    err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
    err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
 * @param[in]   event   Event generated by button press.
    uint32_t err_code;
    switch (event)
        case BSP_EVENT_SLEEP:
            sleep_mode_enter();
        case BSP_EVENT_DISCONNECT:
            err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
        case BSP_EVENT_WHITELIST_OFF:
 *          a string. The string will be be sent over BLE when the last character received was a
 *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
/**@snippet [Handling the data received over UART] */
    static uint8_t index = 0;
    uint32_t       err_code;
    switch (p_event->evt_type)
        case APP_UART_DATA_READY:
            index++;
            if ((data_array[index - 1] == '\n') ||
                (data_array[index - 1] == '\r') ||
                (index >= m_ble_nus_max_data_len))
                if (index > 1)
                    do
                    } while (err_code == NRF_ERROR_RESOURCES);
                index = 0;
        case APP_UART_FIFO_ERROR:
/**@brief  Function for initializing the UART module.
/**@snippet [UART Initialization] */
static void uart_init(void)
        .rx_pin_no    = RX_PIN_NUMBER,
        .tx_pin_no    = TX_PIN_NUMBER,
        .use_parity   = false,
        .baud_rate    = NRF_UART_BAUDRATE_115200
#else
        .baud_rate    = NRF_UARTE_BAUDRATE_115200
                       UART_RX_BUF_SIZE,
                       UART_TX_BUF_SIZE,
                       uart_event_handle,
                       APP_IRQ_PRIORITY_LOWEST,
                       err_code);
    ble_advertising_init_t init;
    init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
    init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
    init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
    bsp_event_t startup_event;
    uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
static void log_init(void)
        nrf_pwr_mgmt_run();
/**@brief Application main function.
    bool erase_bonds;
    // Initialize.
    //uart_init();
    log_init();
    timers_init();
    //buttons_leds_init(&erase_bonds);
    power_management_init();
    ble_stack_init();
    gap_params_init();
    gatt_init();
    services_init();
    advertising_init();
    conn_params_init();
    // Start execution.
    //printf("\r\nUART started.\r\n");
    advertising_start();
    init_twis();
    // Enter main loop.
    for (;;)
        idle_state_handle();
#include <stdint.h>
#include <stdbool.h>
#include <string.h>
#include "twis.h"
#include "nrf_drv_twis.h"
#include "nrf_gpio.h"
static const nrf_drv_twis_t m_twis = NRF_DRV_TWIS_INSTANCE(0);
static uint8_t m_rxbuff[1+8];
static void twis_event_handler(nrf_drv_twis_evt_t const * const p_event)
  switch (p_event->type)
    case(TWIS_EVT_READ_REQ):
      if (p_event->data.buf_req)
        NRF_LOG_INFO("TWIS_EVT_READ_REQ");
//                ees_readBegin();
    case(TWIS_EVT_READ_DONE):
      NRF_LOG_INFO("TWIS_EVT_READ_DONE");
//      ees_readEnd(p_event->data.tx_amount);
    case(TWIS_EVT_WRITE_REQ):
      NRF_LOG_INFO("TWIS_EVT_WRITE_REQ");
        (void)nrf_drv_twis_rx_prepare(&m_twis, m_rxbuff, sizeof(m_rxbuff));
    case(TWIS_EVT_WRITE_DONE):
      NRF_LOG_INFO("TWIS_EVT_WRITE_DONE");
//         ees_writeEnd(p_event->data.rx_amount);
    case TWIS_EVT_READ_ERROR:
    case TWIS_EVT_WRITE_ERROR:
    case TWIS_EVT_GENERAL_ERROR:
      NRF_LOG_INFO("TWIS_EVT_ERR");
//            m_error_flag = true;
uint32_t init_twis(void)
  uint32_t ret;
  const nrf_drv_twis_config_t config =
    .addr               = {I2C_S_ADDR, 0},
    .scl                = I2C_S_SCL_PIN,
//    .scl_pull           = TWIS_DEFAULT_CONFIG_SCL_PULL,
    .scl_pull           = NRF_GPIO_PIN_PULLUP,
    .sda                = I2C_S_SDA_PIN,
//    .sda_pull           = TWIS_DEFAULT_CONFIG_SDA_PULL,
    .sda_pull           = NRF_GPIO_PIN_PULLUP,
    .interrupt_priority = TWIS_DEFAULT_CONFIG_IRQ_PRIORITY
    /* Init TWIS */
    do
      ret = nrf_drv_twis_init(&m_twis, &config, twis_event_handler);
      if (NRF_SUCCESS != ret)
      nrf_drv_twis_enable(&m_twis);
    }while (0);
    return ret;
4747.twis.h
then i use Atmel Power Debugger Kit to measure the custom board. The current is about 65uA and i think the current is high.Our production is very care power consumption.
I have tried as below...
I mark off advertising_start() and init_twis(). The current is about 4.7uA. I think it's ok.
I enable advertising_start() and disable init_twis().Measure the current is about 37.5uA
I also use online power profiler for ble to caculate the current consumption
I disable advertising_start() and enable init_twis().Measure the current is about 34.1uA
so my problem is when i use i2c slave will extra add 34.1uA?
Is anything i can reduce the power consumption?
I also have tried to enable dc/dc, and the power consumption is still high.
sdk version: - 17.0.2
chip: - NRF52840
development platform: - Segger embedded studio
board: custom board
custom board schematic as below and i don't use L1 on the custom board.
  • Hi
    You should expect to see at least 20uA of current when enabling a peripheral that needs to respond to data on an input pin at any time (TWIS or SPIS for instance).
    I will try to do some testing on my end to measure this and see if I get similar results to yours.
    Best regards
    Torbjørn
  • Hi again
    A colleague of mine did some measurements and found the current draw from enabling TWIS to be around 13uA, so less than the expected 20uA.
    He only tested by enabling the interface and stopping it, he didn't use the driver:
        NRF_TWIS0->ENABLE = 9;
        NRF_TWIS0->TASKS_STOP = 1;
        for(;;)
            __WFE();
    Are you able to test in a similar way and see what results you get?
    Also, can you confirm if you have external pullups on the I2C lines?
    Your schematic doesn't show any pullups.
    Best regards
    Torbjørn
