BLE_HCI_INSTANT_PASSED Disconnection Reason
Hi Team,
We are seeing an intermittent issue where BLE connection disconnects abruptly due to reason BLE_HCI_INSTANT_PASSED (0x28). We are using nRF SDK version 15.2.0. The mobile device is Moto G7 Power which runs on Android OS. We have seen this issue 8 times in past month with the same device. Please help us with the following queries:
1. When can this happen? I have seen a stack overflow post explaining the possible reasons. Is that an exhaustive explanation?
2. How can we prevent it? Our customers can have multiple types of devices hence we are looking at a firmware level solution. We came across this link to extend connection event length. Can that help?
Thanks in advance
  • Hi Kenneth,
    Thanks for helping us with this issue.
    Currently NRF_SDH_CLOCK_LF_ACCURACY is set to 7 which translates to 20 PPM accuracy. We have seen a recommendation in code documentation that we should use 500 PPM accuracy if we are using NRF_CLOCK_LF_SRC_RC (RC oscillator). We are using NRF_CLOCK_LF_SRC_XTAL (crystal oscillator). I have the following query:
    1. Should we move to NRF_CLOCK_LF_SRC_RC along with 500 PPM accuracy? or can we get same accuracy by moving to 500 PPM accuracy and keeping clock source as crystal oscillator?
  • Hi Kenneth,
    I want to understand the problem-3 in a better way.
    When we say a peripheral executing any operation that have higher priority than the BLE link, should we just consider operations supported by softdevice here like BLE advertising, Flash memory access, etc. mentioned in the scheduling priorities link shared by you above? Given we run a separate freertos task to poll softdevice events, should its priority be highest among other application tasks?
    In our setup, we currently support only one BLE connection but as soon as one master is connected to our peripheral we don't stop advertising but switch to a non-connectable advertisement to advertise device state as Busy. Can that advertisement conflict with the operation of already established BLE link?
    We also access flash to retrieve security keys required to enable handshake on the established BLE link, can that also impact the BLE link operation?
    Thanks
     Yes.
    That doesn't matter, as these control procedures are fully handled by the softdevice.
    It is possible that advertisement event and connection event may overlap at some instances, since they are asynchronous events they will from time to time overlap in time, in such case the advertisement event may sometimes get the timeslot and thereby the connection event may be skipped one period. Example of advertisement event may get the "timeslot" is simply because it first reserved the "timeslot", the next reserved "timeslot" will be calculated when the previous ended. It's not must that can be done to avoid this, though you may try to reduce the risk of this to occur for several periods in a row by having a connection interval and advertisement interval that differs. E.g. if connection interval is 200ms, then make sure the advertisement is not the same interval or a multiple of the same interval, actually it may better that the advertisement interval is 210ms, 410ms, 610ms or similar to make sure that if there is an overlap at a specific time, the next interval is not overlapping. (I added +10ms for the advertisement interval here compared to the connection interval, since there is always a 0-10ms random delay on advertisement intervals as specified by BT spec.)
    Reading should not be a problem no, only flash erase and flash write operations may have some impact.
    I assume you have an external crystal here with 20ppm tolerance, but even if you are using a crystal with 20ppm tolerance, you may consider to initiate the softdevice by specifying a 50ppm or 100ppm tolerance, this will increase the time window when receiving to allow some more drift if there is an LFCLK in the peer that is out of spec.
    Considering you are already using an external crystal I don't see the need to change to internal RC and 500ppm, but you could add some logic in your application that if you experience a disconnect with a peer due to BLE_HCI_INSTANT_PASSED, then it could on next startup initialize the softdevice with a higher tolerance (even as high as 250ppm when using external clock) to indirectly check if the problem goes away.
    This isn't exact science, but hopefully my comments make sense.
  • Hi Kenneth,
    We were able to analyse BLE sniffer logs for this issue and identified following root-cause:
    The Instant passed (code 40) error are for the LL Channel map indication commands sent from the phone stack to our peripheral device. The error occurs because the phone is sending the command with an instant set to +1 of the current connection event counter (meaning the very next connection event should take effect), but by the time it is sent out the internal connection event counter increases. Thus, the instant value received is same or less than the current connection event counter, which produces the stack error.
    For example, the following trace shows that the channel map indication instant was set to 81, but by the time it was sent out, the counter increased to 82.
    This issue happens when the mobile device is concurrently streaming music to a BLE headset. The mobile device being referred here is Moto G7.
    1. Can we change something on our peripheral firmware to make it robust to such issues? Will increasing connection interval on the firmware side help in this case?
    2. As per the sniffer logs, such failures not always result in disconnection. Do you have some insights from how BLE stack works to better understand the reason for this issue?
    3. We also saw some out of sync packets sent by our peripheral firmware. One such example is shown below where the connection interval is 30ms, but the packets are communicating at ~31ms. What can be done to avoid this? Will increasing the clock PPM accuracy as discussed above help here?
    Seems you have found the issue! According to BLE specifications there is a requirement that it should be minimum (6+slave latency) instances, this to ensure there is time for re-transmissions in case peripheral is in sleep or packets are lost. So this is a violation of BLE spec by the phone.
    I suggest to enable slave latency to see if that helps, if you are concerned slave latency will impact the throughput of the link you should be aware you can enable slave latency on the link by updating connection parameters, but yet ensure that the peripheral will behave as slave latency is not enabled by configuring local slave latency to 0 by using this api:
    https://infocenter.nordicsemi.com/topic/com.nordic.infocenter.s112.api.v7.2.0/structble__gap__opt__local__conn__latency__t.html?cp=4_7_0_1_2_1_6_49 (I linked to S112 softdevice, but similar for other softdevices).
    This is a pure stack scheduling issue on the Moto G7; violation of BLE spec by not following BLE requirements, the peripheral can't really do anything about this other than to recover by re-connecting again.
    I am not sure what exactly I see here. It is not possible that the peripheral device can initiate or send any packets in a connection event without first receiving a packet from the peer. So the sniffer may have missed the packet from the phone if there is no packet shown from the phone. However if the connection interval is 30ms, and the first packet the sniffer picks up are at 31.25ms, then it also sounds like something is wrong with the timing yes. Even if you configured with a tolerance of 500ppm (equal allow 500us drift in 1 second), that means can only tolerate a drift of about 15us in 30ms, which is not close to the sniffer log of 1.25ms in 30ms. So are you sure that the connection interval is not really 31.25ms here?
    The stability of the internal RC oscillator is (fTOL_CAL_LFRC )= 500ppm, as shown in this table:
    https://infocenter.nordicsemi.com/topic/ps_nrf52840/clock.html#unique_1494269344
    So if you are using the internal RC oscillators you should configure 500pmm. If you are using external crystal oscillator then you can configure the the tolerance to lower value since the stability is better. Yes, you may set 500ppm when using external crystal oscillator, but I don't expect it will help your current issues based on your observations with Moto G7 (violation of channel map indication).
