Zigbee multi_sensor example + Zigbee CLI. Unable to bind.
I've just compiled clean examples from Zigbee and Thread SDK 4.1.0 and I'm following instructions from here:
I've got CLI on the nRF dongle and multi_sensor example loaded on nrf52DK, another dongle is used for the traffic sniffing.
https://infocenter.nordicsemi.com/index.jsp?topic=%2Fsdk_tz_v4.1.0%2Fzigbee_multi_sensor_example.html&cp=7_3_3_8_5_3_1&anchor=zigbee_multi_sensor_example_test
I am able to join the network, match descriptor, and get the addresses, but I cannot bind the devices.
zdo bind on f4ce36947ce4e2a6 10 f4ce36efda1451dd 64 0x0403 0x05b9
Error: Bind/unbind request timed out
I'm attaching wireshark log.
Can you please provide me some extra information on that topic?
Am I doing something wrong regarding the binding process?
Looking forward to hearing from you.
1856.multi_sensor_dump.pcapng
    Please make sure that you're using the correct addresses when binding. From the documentation the command is:
    "zdo bind on 0b010e1585785ce7 10 0b010ee031137990 64 0x0402 0x05b9"
    Here's an explanation of the different parts of the command:
    • 0b010e1585785ce7: the long address of the device to be binded to the CLI Agent, so the multi sensor in your case
    • 10: the endpoint of the multi sensor (when you issued the command "zdo match_desc 0xffff 0xffff 0x0104 2 0x0402 0x0403 0" you got the source address and endpoint, where endpoint was the ep=10 part)
    • 0b010ee031137990: the long address of the CLI Agent
    • 64: the endpoint of the CLI Agent
    • 0x0402: the source cluster ID, which in this case is the temperature measurement cluster (you can find a list over different Zigbee Cluster IDs here).
    • 0x05b9: the short address of your sensor, so the src_addr you got when issuing the command "zdo match_desc 0xffff 0xffff 0x0104 2 0x0402 0x0403 0"
    Hope this helps solve your problem!
    Marte
  • Thanks for your fast response.
    I think I'm using the correct addresses.
    I'm attaching CLI log with commands that was executed during sniffing.
    > bdb role zc
    Coordinator set
    Done
    > bdb start
    Started coordinator
    Done
    > reset
    > bdb role zc
    Coordinator set
    Done
    > bdb start
    Started coordinator
    Done
    > reset
    > bdb role zc
    Coordinator set
    Done
    > bdb start
    Started coordinator
    Done
    Sending broadcast request.
    src_addr=3AA6 ep=10
    zdo ieee_addr 3AA6
    > f4ce36947ce4e2a6
    Done
    zdo eui64
    f4ce36efda1451dd
    Done
    > zdo bind on f4ce36947ce4e2a6 10 f4ce36efda1451dd 64 0x0402 0x05b9
    Done
    From your CLI log I can see that you've forgotten to change the last part of the bind command, 0x05b9. This should be the short address of your sensor, so instead you should use the following command, where 0x05b9 is switched out with 0x3AA6:
    zdo bind on f4ce36947ce4e2a6 10 f4ce36efda1451dd 64 0x0402 0x3AA6
    The documentation of the example doesn't specify that this is the short address of your device, so it's easy to overlook.
    Marte
