How can I erase only UICR partition in run time
I am going to store some informations into UICR.
In case, wrong data wrote have to correct we need to rewrite it.
I have been searched the forum and the answer shows "can't only erase UICR"
I want to make sure is that correct?
    This is not a common use case. May I ask why you want to do so? The UICR is intended for custom data that doesn't change during the lifetime of the device. This is because the UICR also contains other crucial information, so if something erroneous occurs, you may brick the device (so that it requires manual re-programming).
    Disclaimer: If you need to enable APPROTECT (readback protection) you can not change the UICR after programming on the nRF52840. Perhaps, if you need to update the data during runtime, you should look into using FDS or fstorage instead?
    Edvin
    We are going to share the data stored in UICR between 2 groups(bootloader, application and softdevice) of images. One is factory image and the other is Shipping image.
    Factory image will store sensors calibration data at UICR. Then DFU by OTA with shipping image(BL APP and SD). UICR should not be replaced. So shipping image can get the calibration data whenever it need.
    Sometimes, we may make mistake to write wrong data into UICR in factory at runtime. This is the question, how do I correct it without eraseall. In the other word, just erase UICR part and keep BL, APP and SD.
  • The issue is that some configurations other than the custom registers are stored in UICR as well. If this is at factory, I would suggest erasing the entire chip if you need to correct UICR.
    Try to read out the UICR of one of the chips. You will see that the reset pin configuration and the bootloader start address are two of the things that are also stored in the UICR.
    Do you intend to use APPROTECT? The reason I stress this is that if you use APPROTECT, it is not physically possible to erase the UICR during runtime.
    It still sounds like it would be possible to do what you want to achieve without the use of UICR. It sounds like you can do this using FDS.
    However, if you want to experiment (and please don't do this if you do not have the possibility to manually re-program the chips), you can check out this experimental example that I put together from the ble_app_uart example in SDK17.0.2:
     * Copyright (c) 2014 - 2020, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup ble_sdk_uart_over_ble_main main.c
     * @ingroup  ble_sdk_app_nus_eval
     * @brief    UART over BLE application main file.
     * This file contains the source code for a sample application that uses the Nordic UART service.
     * This application uses the @ref srvlib_conn_params module.
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "ble_hci.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "app_timer.h"
    #include "ble_nus.h"
    #include "app_uart.h"
    #include "bsp_btn_ble.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrf_delay.h"
    #if defined (UART_PRESENT)
    #include "nrf_uart.h"
    #if defined (UARTE_PRESENT)
    #include "nrf_uarte.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
    #define DEVICE_NAME                     "Nordic_UART"                               /**< Name of device. Will be included in the advertising data. */
    #define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
    #define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    #define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
    #define SLAVE_LATENCY                   0                                           /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
    #define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
    BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
    NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
    BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
    static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
    static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
    static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
    /**@brief Function for assert macro callback.
     * @warning This handler is an example only and does not fit a final product. You need to analyse
     * @param[in] line_num    Line number of the failing ASSERT call.
     * @param[in] p_file_name File name of the failing ASSERT call.
    /**@brief Function for initializing the timer module.
    static void timers_init(void)
     *          the device. It also sets the permissions and appearance.
        uint32_t                err_code;
                                              strlen(DEVICE_NAME));
        APP_ERROR_HANDLER(nrf_error);
    /**@brief Function for handling the data from the Nordic UART Service.
     * @details This function will process the data received from the Nordic UART BLE Service and send
     *          it to the UART module.
     * @param[in] p_evt       Nordic UART Service event.
    /**@snippet [Handling the data received over BLE] */
            uint32_t err_code;
            for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
                do
                    err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
                    if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                        NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
                } while (err_code == NRF_ERROR_BUSY);
            if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
                while (app_uart_put('\n') == NRF_ERROR_BUSY);
        uint32_t           err_code;
        ble_nus_init_t     nus_init;
        // Initialize NUS.
    /**@brief Function for handling an event from the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module
     *          which are passed to the application.
     * @note All this function does is to disconnect. This could have been done by simply setting
     *       the disconnect_on_fail config parameter, but instead we use the event handler
     *       mechanism to demonstrate its use.
        uint32_t err_code;
    /**@brief Function for handling errors from the Connection Parameters module.
        // Prepare wakeup buttons.
        uint32_t err_code;
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
            case BLE_ADV_EVT_IDLE:
                sleep_mode_enter();
        uint32_t err_code;
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected");
                NRF_LOG_INFO("Disconnected");
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
                // Pairing not supported
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
                // No implementation needed.
    /**@brief Function for the SoftDevice initialization.
     * @details This function initializes the SoftDevice and the BLE event interrupt.
        ret_code_t err_code;
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for handling events from the GATT library. */
    void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
        if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
            m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
            NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
        NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                      p_gatt->att_mtu_desired_central,
                      p_gatt->att_mtu_desired_periph);
    /**@brief Function for initializing the GATT library. */
    void gatt_init(void)
        err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
        err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
     * @param[in]   event   Event generated by button press.
        uint32_t err_code;
        switch (event)
            case BSP_EVENT_SLEEP:
                sleep_mode_enter();
            case BSP_EVENT_DISCONNECT:
                err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
            case BSP_EVENT_WHITELIST_OFF:
     *          a string. The string will be be sent over BLE when the last character received was a
     *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
    /**@snippet [Handling the data received over UART] */
        static uint8_t index = 0;
        uint32_t       err_code;
        switch (p_event->evt_type)
            case APP_UART_DATA_READY:
                index++;
                if ((data_array[index - 1] == '\n') ||
                    (data_array[index - 1] == '\r') ||
                    (index >= m_ble_nus_max_data_len))
                    if (index > 1)
                        do
                        } while (err_code == NRF_ERROR_RESOURCES);
                    index = 0;
            case APP_UART_FIFO_ERROR:
    /**@brief  Function for initializing the UART module.
    /**@snippet [UART Initialization] */
    static void uart_init(void)
            .rx_pin_no    = RX_PIN_NUMBER,
            .tx_pin_no    = TX_PIN_NUMBER,
            .use_parity   = false,
            .baud_rate    = NRF_UART_BAUDRATE_115200
    #else
            .baud_rate    = NRF_UARTE_BAUDRATE_115200
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           APP_IRQ_PRIORITY_LOWEST,
                           err_code);
        ble_advertising_init_t init;
        init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
        init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
        init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
        bsp_event_t startup_event;
        uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
    static void log_init(void)
            nrf_pwr_mgmt_run();
    static void erase_uicr(void)
        NRF_LOG_INFO("Before erase,            NRF_UICR->CUSTOMER[0] = 0x%02x |", NRF_UICR->CUSTOMER[0]);
        NRF_NVMC->CONFIG = 0;       // Read access
        while (NRF_NVMC->READY == NVMC_READY_READY_Busy){}
        uint32_t p_uicr[132];
        memcpy(p_uicr, (uint32_t*)NRF_UICR_BASE, 528);
    //    NRF_LOG_RAW_INFO("read uicr (size = %04x:\r\n", sizeof(NRF_UICR_Type))
    //    for (uint16_t i; i<256; i++)
    //        addr = 0x10*i;
    //        NRF_LOG_RAW_INFO("0x%08x: %08x %08x %08x %08x \r\n", addr+0x10001000, p_uicr[0+4*i],
    //        p_uicr[1+4*i],
    //        p_uicr[2+4*i],
    //        p_uicr[3+4*i]);
    //        nrf_delay_ms(10);
        // Erase local copy of customer registers from the buffer.
        for (uint8_t i=0; i<32; i++)
            p_uicr[32+i] = 0xFFFFFFFF;
        NRF_NVMC->CONFIG = 2;       // Erase access
        NRF_NVMC->ERASEUICR = 1;    // Erase UICR
        NRF_NVMC->CONFIG = 1;       // Write access
        for (uint16_t i=0; i<132; i++)
            *(((uint32_t*)NRF_UICR_BASE)+i) = p_uicr[i];
        NRF_NVMC->CONFIG = 0;       // Read access;
        NRF_LOG_INFO("After  erase,            NRF_UICR->CUSTOMER[0] = 0x%02x |", NRF_UICR->CUSTOMER[0]);
    static void test_uicr1(void)
        NRF_LOG_INFO("Before first write,      NRF_UICR->CUSTOMER[0] = 0x%08x |", NRF_UICR->CUSTOMER[0]);
        uint32_t value = 0xDEADBEEF;
        if (NRF_UICR->CUSTOMER[0] == 0xFFFFFFFF)
            NRF_NVMC->CONFIG = NVMC_CONFIG_WEN_Wen << NVMC_CONFIG_WEN_Pos;
            NRF_UICR->CUSTOMER[0] = value;
            NRF_NVMC->CONFIG = NVMC_CONFIG_WEN_Ren << NVMC_CONFIG_WEN_Pos;
        NRF_LOG_INFO("After first write,       NRF_UICR->CUSTOMER[0] = 0x%08x |", NRF_UICR->CUSTOMER[0]);
    static void test_uicr2(void)
        NRF_LOG_INFO("Before second write,     NRF_UICR->CUSTOMER[0] = 0x%08x |", NRF_UICR->CUSTOMER[0]);
        uint32_t value = 0xCAFEF00D;
        NRF_LOG_INFO("After second write,      NRF_UICR->CUSTOMER[0] = 0x%08x |", NRF_UICR->CUSTOMER[0]);
    static void uicr_test(void)
        test_uicr1();
        erase_uicr();
        test_uicr2();
    /**@brief Application main function.
        bool erase_bonds;
        // Initialize.
        uart_init();
        log_init();
        timers_init();
        power_management_init();
    	nrf_delay_ms(5000);
        uicr_test();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        // Start execution.
        advertising_start();
    /*    uint32_t temp_uicr = 0x12345678;
        NRF_UICR->CUSTOMER[0] = (uint32_t)temp_uicr;
        uint32_t uicr = NRF_UICR->CUSTOMER[0];
        NRF_LOG_INFO("UICR->CUSTOMER[0] = 0x%08x", uicr);
        NRF_LOG_INFO("pointer 0x%08x", &temp_uicr);*/
        // Enter main loop.
        for (;;)
            idle_state_handle();
    Note that it stores the UICR, erases, and then writes everything back except for the NRF_UICR->CUSTOMER registers. If you loose power at the wrong time, the device is bricked. Also, the numbers here are quite hard-coded. It is probably possible to do this in a better, more readable way. But erasing the UICR of the nRF52840 during runtime is not something we recommend.
    BR,
    Edvin
