Notify - Not updating in MCP
I'm running: SDK 7.1, PCA10028 eval board, SD310 2.0.1, MCP 3.8.0.7
I'm trying to get Notifications to work. I have two attributes. I write to one and have it update the value of the second, which then is set to Notify the Central (in this case Nordic's MCP).
I connect, discover and enable services. When I write to the first attribute, the write works. I then call sd_ble_gatts_hvx(...), no errors are returned (err_code == 0); The value for the second attribute remains unchanged in the MCP. However if I read the attribute from the MCP it returns the updated value.
I turn on LED on my dev board when I get a BLE_EVT_TX_COMPLETE - this event never occurs, if I don't read the second attribute. Read the attribute, the BLE_EVT_TX_COMPLETE event will occur, but sometimes takes several seconds.
After the BLE_EVT_TX_COMPLETE event I can not write or read anything from the peripheral device.
What am I doing wrong?
Code: Set up of attribute that Notifies the Central. Note, I only enable notify, but I can still read it from the MCP
    char_md.char_props.notify 			= 1;
    char_md.char_props.write  			= 1;
	char_md.char_props.write_wo_resp 	= 1;
	char_md.char_user_desc_max_size  	= sizeof("Batt");
	char_md.char_user_desc_size 			= sizeof("Batt");
    char_md.p_char_user_desc    			= (uint8_t *)char_user_desc;
    char_md.p_char_pf         				= NULL;
    char_md.p_user_desc_md    			= NULL;
    char_md.p_cccd_md         			= &cccd_md;
    char_md.p_sccd_md         			= NULL;
Code To Notify The Central:
uint16_t				d_len;
ble_gatts_hvx_params_t	reset_param;
uint32_t				err_code;
d_len = 1;
reset_param.handle 	= p_blinds->pwr_batt_cap_handles.value_handle;
reset_param.type   	= BLE_GATT_HVX_NOTIFICATION;
reset_param.p_len 	= &d_len;
reset_param.p_data 	= buf;
reset_param.offset 	= 0;
err_code = sd_ble_gatts_hvx(p_blinds->conn_handle, &reset_param);
Do I need to do anything else? Thanks, Clint
