I think there is a problem with app_button.
Hello!
I am working on sdk v17 and ble_app_uart.
I'm going to make a button function first in this project. I created 3 functions of 'push, release, and long press' using the app button.
These are almost  exactly what I made in the previous project. But somehow when I run it, everything, not just the buttons, doesn't work.
When I brake the button_init and debug it, it goes straight to the error code. (See picture below)
I've put in the code for the button and the whole code.
static uint32_t pressed_time, released_time, pressed_duration = 0;
static bool pressed_cnt= false;
static bool over5sec_cnt = true; //When at first, trying to connect.
static uint32_t app_button_duration(void)
  pressed_duration = (released_time - pressed_time)*2; //ms
  return pressed_duration;
static void app_button_init_time_variable(void)
  //released_time = 0;
  //pressed_time = 0;
static void app_button_event_generator(void) //button press time
  ret_code_t err_code;
  if ((pressed_duration >= 700) && (pressed_duration < 2999) ) //1~3 sec
    /*if(m_conn_handle == BLE_CONN_HANDLE_INVALID) //in disconnect pairing
      printf("Not yet pairing!\n");
    else //in connect pairing
      pwm_change_frequency(500); //change PWM
      do_play_buzzer();
      printf("Disconnected pairing!\n");
      err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION); //disconnect pairing
  /*else if((pressed_duration >= 3000) && (pressed_duration < 999999999)) //over 3sec
      printf("POWER OFF...\n");
      do_play_buzzer(); //When Power Off play buzzer
    //Power Off Code
  app_button_init_time_variable();
static void app_button_event_handler(uint8_t pin_no, uint8_t button_action)
    static uint32_t first_pressed;
    static uint32_t long_pressed;
    switch (pin_no)
      case BSP_BUTTON_0: //button1
        switch (button_action)
          case APP_BUTTON_PUSH:
            NRF_LOG_INFO("Button pressed...");
            printf("Button pressed...");
            nrf_gpio_pin_clear(BSP_BUTTON_2); //led on
            //pwm_change_frequency(1500);
            //do_play_buzzer();
            //get pressed time
            pressed_time = app_timer_cnt_get()*1000/32768;//milli-sec
            NRF_LOG_INFO("pressed_time: %d", (int)pressed_time);
            printf("pressed_time: %d\n", (int)pressed_time);
            pressed_cnt = true;
            LongPress_timers_start(); //press time count
          } break;
           case APP_BUTTON_RELEASE:
              NRF_LOG_INFO("Button releaed...");
              nrf_gpio_pin_set(BSP_BUTTON_2); //led off
              //nrf_gpio_pin_set(LED_2);
              if (pressed_cnt)
                released_time = app_timer_cnt_get()*1000/32768; //milli-sec
                NRF_LOG_INFO("released_time: %d", (int)released_time);
                printf("released_time: %d\n", (int)released_time);
              pressed_cnt = false;
              LongPress_timers_stop();
           } break;
         APP_ERROR_HANDLER(pin_no);
    if(app_button_duration())
      app_button_event_generator();
static void app_buttons_init(void)
  uint32_t err_code;
  static const app_button_cfg_t app_buttons[BUTTONS_NUMBER] =
    #ifdef BSP_BUTTON_0 //button1
    {BSP_BUTTON_0, false, BUTTON_PULL, app_button_event_handler},
    #endif // BSP_BUTTON_0
  err_code = app_button_init((app_button_cfg_t *)app_buttons,
                                       BUTTONS_NUMBER,        // 4
                                       APP_TIMER_TICKS(50)); //debounce
    bool erase_bonds;
    // Initialize.
    uart_init();
    log_init();
    timers_init();
    //buttons_leds_init(&erase_bonds);
    app_buttons_init();
    power_management_init();
    ble_stack_init();
    gap_params_init();
    gatt_init();
    services_init();
    advertising_init();
    conn_params_init();
    //Add
    gpio_init();
    bsp_board_init(BSP_INIT_LEDS); //use bsp
    // Start execution.
    advertising_start();
    // Enter main loop.
    for (;;)
        idle_state_handle();
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "ble_hci.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "app_timer.h"
#include "ble_nus.h"
#include "app_uart.h"
#include "bsp_btn_ble.h"
#include "nrf_pwr_mgmt.h"
#if defined (UART_PRESENT)
#include "nrf_uart.h"
#if defined (UARTE_PRESENT)
#include "nrf_uarte.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
//Add Include
#include "app_button.h"
#include "nrf_delay.h"
#include "app_error.h"
#include "bsp.h"
#include "app_pwm.h"
#include "nrf_drv_saadc.h" //ADC
#include "nrf_drv_ppi.h"
#include "nrf_drv_timer.h"
#define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
#define DEVICE_NAME                     "Careroo"                               /**< Name of device. Will be included in the advertising data. */
#define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
#define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
#define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
#define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
#define SLAVE_LATENCY                   0                                           /**< Slave latency. */
#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
#define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
APP_TIMER_DEF(m_LongPress_timer_id); //button Long press time, repeate timer
static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
void gpio_init(void)
  nrf_gpio_cfg_output(BSP_LED_0); //board_led1
  nrf_gpio_pin_set(BSP_LED_0);
  nrf_gpio_cfg_output(BSP_LED_1); //board_led2
  nrf_gpio_pin_set(BSP_LED_1);
  nrf_gpio_cfg_output(BSP_LED_2); //board_led3
  nrf_gpio_pin_set(BSP_LED_2);
  nrf_gpio_cfg_output(BSP_LED_3); //board_led4
  nrf_gpio_pin_set(BSP_LED_3);
  nrf_gpio_cfg_input(BSP_BUTTON_0,NRF_GPIO_PIN_PULLUP);
/**@brief Function for assert macro callback.
 * @warning This handler is an example only and does not fit a final product. You need to analyse
 * @param[in] line_num    Line number of the failing ASSERT call.
 * @param[in] p_file_name File name of the failing ASSERT call.
static void LongPress_timers_stop();
uint32_t press_time; //press time count
static void LongPress_timer_handler(void * p_context)
  //static uint32_t press_time; //press time count
  press_time++;
  printf("COUNT : %d\n", press_time);
  if(press_time == 3) //Power Off
    printf("Power Off!\n");
    //pwm_change_frequency(500);
    //do_play_buzzer();
    //nrf_gpio_pin_clear(POWER_OFF); //LOW : power off
/**@brief Function for initializing the timer module.
static void timers_init(void)
    err_code = app_timer_init();
   //Create Press Time timers/
    err_code = app_timer_create(&m_LongPress_timer_id,
                                APP_TIMER_MODE_REPEATED,
                                LongPress_timer_handler);
static void LongPress_timers_start()
  err_code = app_timer_start(m_LongPress_timer_id, APP_TIMER_TICKS(1000), NULL); //count 1sec
    printf("Press Count Stop\n");
    press_time = 0; //count reset
    err_code = app_timer_stop(m_LongPress_timer_id);
 *          the device. It also sets the permissions and appearance.
    uint32_t                err_code;
                                          strlen(DEVICE_NAME));
    APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling the data from the Nordic UART Service.
 * @details This function will process the data received from the Nordic UART BLE Service and send
 *          it to the UART module.
 * @param[in] p_evt       Nordic UART Service event.
/**@snippet [Handling the data received over BLE] */
        uint32_t err_code;
        for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
            do
                err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
                if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                    NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
            } while (err_code == NRF_ERROR_BUSY);
        if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
            while (app_uart_put('\n') == NRF_ERROR_BUSY);
    uint32_t           err_code;
    ble_nus_init_t     nus_init;
    // Initialize NUS.
/**@brief Function for handling an event from the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module
 *          which are passed to the application.
 * @note All this function does is to disconnect. This could have been done by simply setting
 *       the disconnect_on_fail config parameter, but instead we use the event handler
 *       mechanism to demonstrate its use.
    uint32_t err_code;
/**@brief Function for handling errors from the Connection Parameters module.
    // Prepare wakeup buttons.
    uint32_t err_code;
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
        case BLE_ADV_EVT_IDLE:
            sleep_mode_enter();
    uint32_t err_code;
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connected");
            NRF_LOG_INFO("Disconnected");
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
            // Pairing not supported
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
            // No implementation needed.
/**@brief Function for the SoftDevice initialization.
 * @details This function initializes the SoftDevice and the BLE event interrupt.
    uint32_t ram_start = 0;
    // Enable BLE stack.
/**@brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
    if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
        m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
        NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
    NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                  p_gatt->att_mtu_desired_central,
                  p_gatt->att_mtu_desired_periph);
/**@brief Function for initializing the GATT library. */
void gatt_init(void)
    err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
    err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
 * @param[in]   event   Event generated by button press.
/*void bsp_event_handler(bsp_event_t event)
    uint32_t err_code;
    switch (event)
        case BSP_EVENT_SLEEP:
            sleep_mode_enter();
            break; // BSP_EVENT_SLEEP
        case BSP_EVENT_DISCONNECT: //A link should be disconnected. (long press Button1)
            break; // BSP_EVENT_DISCONNECT
        case BSP_EVENT_WHITELIST_OFF: // The device should remove its advertising whitelist
        //The whitelist is used to filter Connection requests (and/or scan requests) from central devices
            if (m_conn_handle == BLE_CONN_HANDLE_INVALID) //if disconnected
            break; // BSP_EVENT_WHITELIST_OFF
 *          a string. The string will be be sent over BLE when the last character received was a
 *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
/**@snippet [Handling the data received over UART] */
    static uint8_t index = 0;
    uint32_t       err_code;
    switch (p_event->evt_type)
        case APP_UART_DATA_READY:
            index++;
            if ((data_array[index - 1] == '\n') ||
                (data_array[index - 1] == '\r') ||
                (index >= m_ble_nus_max_data_len))
                if (index > 1)
                    do
                    } while (err_code == NRF_ERROR_RESOURCES);
                index = 0;
        case APP_UART_FIFO_ERROR:
/**@brief  Function for initializing the UART module.
/**@snippet [UART Initialization] */
static void uart_init(void)
        .rx_pin_no    = RX_PIN_NUMBER,
        .tx_pin_no    = TX_PIN_NUMBER,
        .use_parity   = false,
        .baud_rate    = NRF_UART_BAUDRATE_115200
#else
        .baud_rate    = NRF_UARTE_BAUDRATE_115200
                       UART_RX_BUF_SIZE,
                       UART_TX_BUF_SIZE,
                       uart_event_handle,
                       APP_IRQ_PRIORITY_LOWEST,
                       err_code);
    ble_advertising_init_t init;
    init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
    init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
    init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
static void log_init(void)
        nrf_pwr_mgmt_run();
  //pressed_time = 0;
      do_play_buzzer();
    //Power Off Code
    switch (pin_no)
            //do_play_buzzer();
            //get pressed time
            pressed_cnt = true;
          } break;
              if (pressed_cnt)
           } break;
  uint32_t err_code;
/**@brief Application main function.
    bool erase_bonds;
    // Initialize.
    uart_init();
    log_init();
    timers_init();
    app_buttons_init();
    ble_stack_init();
    gap_params_init();
    gatt_init();
    services_init();
    advertising_init();
    conn_params_init();
    //Add
    gpio_init();
    // Start execution.
    // Enter main loop.
    for (;;)
Can I know the problem with this?
Thank you!
