Zephyr API to read the nRF5340 die temperature
I am looking for some some nRF5340 example code that reads the nRF5340 die temperature using zephyr APIs.
I've looked at previous posts but I could only find this one https://devzone.nordicsemi.com/f/nordic-q-a/56171/how-to-get-die-temperature-on-nrf52832-using-zephyr from 10 months ago that stated none existed. I am hoping someone, somewhere musty have done something similar.
Thank you.
Kind regards
  • Hi Hakon,
    I am back on the die temperature example now.
    What are the two folders blinky_send and blinky_temp for?
    I can see only a build folder in each.
    Kind regards
    Mohamed
  • Hi Hakon,
    I have implemented the changes in my project as per your example but I am unable to load my project in SES. Below in blue is the error I am getting. Note, I am using SES v5.34a and NCS v1.5.0-rc1.
    My CMakeLists.txt file looks like this,
    # Copyright (c) 2020 Nordic Semiconductor
    # SPDX-License-Identifier: LicenseRef-BSD-5-Clause-Nordic
    cmake_minimum_required(VERSION 3.8.2)
    set(NRF_SUPPORTED_BOARDS
    nrf5340pdk_nrf5340_cpuapp
    find_package(Zephyr REQUIRED HINTS $ENV{ZEPHYR_BASE})
    project(empty_app_core)
    FILE(GLOB app_sources src/*.c src/radio/*.c src/lr1110_driver-master/*.c src/crypto/*.c src/adc/*.c src/timer/*.c src/mcu_temp/*.c)
    #FILE(GLOB app_sources src/radio/*.c)
    target_sources(app PRIVATE ${app_sources})
    #target_sources(app PRIVATE src/radio/*.c)
    #arget_sources(app PRIVATE src/*.c)
    #target_sources(app PRIVATE src/lr1110_driver-master/lr1110_driver_version.c)
    My project file prj.conf looks like this,
    # Copyright (c) 2020 Nordic Semiconductor ASA
    ### Logging ####
    # For the PID 4 hardware we must set CONFIG_SERIAL=n because otherwise the SPI CS/BUSY
    # pins will be allocated to UART0 CTS/RTS pins.
    CONFIG_SERIAL=n
    CONFIG_LOG=y
    CONFIG_USE_SEGGER_RTT=y
    CONFIG_RTT_CONSOLE=y
    #CONFIG_UART_CONSOLE=n
    CONFIG_DEBUG_OPTIMIZATIONS=y
    CONFIG_NEWLIB_LIBC=y
    CONFIG_PRINTK=y
    # This will be needed when using to NCS v1.40 or higher, #ifdef ZEPHYR_V_1_50
    CONFIG_DEPRECATED_ZEPHYR_INT_TYPES=y
    ### NETWORK core ###
    # needed when measuring the SoC die temperature
    #CONFIG_BOARD_ENABLE_CPUNET=n
    ### GPIOs ###
    CONFIG_GPIO=y
    # ADC
    CONFIG_ADC=y
    # No need for this as it is alresdy enabled by default in ...\adc\Kconfig.nrfx
    #CONFIG_ADC_NRF5_SAADC = y
    ### SPI ###
    CONFIG_SPI=y
    #CONFIG_SPI_ASYNC=y
    CONFIG_MAIN_STACK_SIZE=4096
    CONFIG_SPI_1=y
    ### TEMPERATURE SENSOR ###
    #CONFIG_BOARD_ENABLE_CPUNET=y
    #CONFIG_SENSOR=y
    #CONFIG_TEMP_NRF5=y
    ### IPC stuff ###
    CONFIG_IPM=y
    CONFIG_IPM_NRFX=y
    CONFIG_IPM_MSG_CH_0_ENABLE=y
    CONFIG_IPM_MSG_CH_0_TX=y
    CONFIG_IPM_MSG_CH_1_ENABLE=y
    CONFIG_IPM_MSG_CH_1_RX=y
    # CONFIG_NRF_RPC=y
    ### I2C ###
    #CONFIG_LIS2DE12=y
    #CONFIG_I2C_1=y
    ### RTC ###
    # The RTC on nRF5340 is not really an Real Time Clock but it's a real time counter.
    # Timers will be used instead.
    #CONFIG_COUNTER_NRFX_RTC0=y
    ### RANDOM NUMBER GENERATION ###
    CONFIG_TIMER_RANDOM_GENERATOR=n
    CONFIG_ENTROPY_DEVICE_RANDOM_GENERATOR=n
    CONFIG_XOROSHIRO_RANDOM_GENERATOR=n
    # Cryptographically secure random number generators
    CONFIG_HARDWARE_DEVICE_CS_GENERATOR=n
    CONFIG_CTR_DRBG_CSPRNG_GENERATOR=n
    #CONFIG_CS_CTR_DRBG_PERSONALIZATION=n
    while my overlay file nrf5340pdk_nrf5340_cpunet.overlay looks like this,
    // SEGGER Embedded Studio auto generated
    // chosen {
    * In some default configurations within the nRF Connect SDK,
    * e.g. on nRF52840 and nRF9160, the chosen zephyr,entropy node
    * is &cryptocell. This devicetree overlay ensures that default
    * is overridden wherever it is set, as this application uses
    * the RNG node for entropy exclusively.
    // zephyr,entropy = &rng;
    &temp {
    compatible = "nordic,nrf-temp";
    status = "okay";
    //&led0 { gpios = < &gpio1 9 GPIO_ACTIVE_LOW >; };
    // nRF5340PDK board
    //&spi1 {
    // cs-gpios = <&gpio1 9 0>;
    // compatible = "nordic,nrf-spim";
    // status = "okay";
    // sck-pin = < 47 >;
    // mosi-pin = < 45 >;
    // miso-pin = < 46 >;
    // PID-4 board
    &spi1 {
    cs-gpios = <&gpio0 19 0>;
    status = "okay";
    sck-pin = < 13 >;
    mosi-pin = < 9 >;
    miso-pin = < 40 >;
    aliases {
    //Didn't work with alias spi-1=&spi1 as defined in dts\...\nrf5340_cpuapp.dtsi and build\zephyr.dts;
    spi1 = &spi1;
    Creating solution spi_test_LR1110-2-TX-RX-CMAC-AES.emProject
    C:/Zypher/v1.5.0-rc1/toolchain/opt/bin/cmake.exe -GNinja -DBOARD=nrf5340pdk_nrf5340_cpuapp -DBOARD_DIR=C:\Zypher\v1.5.0-rc1\zephyr\boards\arm\nrf5340dk_nrf5340 -BC:\Dev\PID-4\spi_test_LR1110-2-TX-RX-CMAC-AES\build_nrf5340pdk_nrf5340_cpu_net -SC:\Dev\PID-4\spi_test_LR1110-2-TX-RX-CMAC-AES -DNCS_TOOLCHAIN_VERSION=1.5.0 -DEXTRA_KCONFIG_TARGETS=menuconfig_ses -DEXTRA_KCONFIG_TARGET_COMMAND_FOR_menuconfig_ses=C:\Zypher\v1.5.0-rc1\toolchain\segger_embedded_studio/html/configure_nordic_project_menuconfig.py
    -- Application: C:/Dev/PID-4/spi_test_LR1110-2-TX-RX-CMAC-AES
    -- Zephyr version: 2.4.99 (C:/Zypher/v1.5.0-rc1/zephyr)
    -- Found Python3: C:/Zypher/v1.5.0-rc1/toolchain/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
    -- Found west (found suitable version "0.9.0", minimum required is "0.7.1")
    -- Board: nrf5340pdk_nrf5340_cpuapp
    -- Cache files will be written to: C:/Zypher/v1.5.0-rc1/zephyr/.cache
    -- Found dtc: C:/Zypher/v1.5.0-rc1/toolchain/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
    -- Found toolchain: gnuarmemb (C:/Zypher/v1.5.0-rc1/toolchain/opt)
    -- Found BOARD.dts: C:/Zypher/v1.5.0-rc1/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340pdk_nrf5340_cpuapp.dts
    -- Generated zephyr.dts: C:/Dev/PID-4/spi_test_LR1110-2-TX-RX-CMAC-AES/build_nrf5340pdk_nrf5340_cpu_net/zephyr/zephyr.dts
    -- Generated devicetree_unfixed.h: C:/Dev/PID-4/spi_test_LR1110-2-TX-RX-CMAC-AES/build_nrf5340pdk_nrf5340_cpu_net/zephyr/include/generated/devicetree_unfixed.h
    -- Generated device_extern.h: C:/Dev/PID-4/spi_test_LR1110-2-TX-RX-CMAC-AES/build_nrf5340pdk_nrf5340_cpu_net/zephyr/include/generated/device_extern.h
    Parsing C:/Zypher/v1.5.0-rc1/zephyr/Kconfig
    Loaded configuration 'C:/Zypher/v1.5.0-rc1/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340pdk_nrf5340_cpuapp_defconfig'
    Merged configuration 'C:/Dev/PID-4/spi_test_LR1110-2-TX-RX-CMAC-AES/prj.conf'
    Configuration saved to 'C:/Dev/PID-4/spi_test_LR1110-2-TX-RX-CMAC-AES/build_nrf5340pdk_nrf5340_cpu_net/zephyr/.config'
    Kconfig header saved to 'C:/Dev/PID-4/spi_test_LR1110-2-TX-RX-CMAC-AES/build_nrf5340pdk_nrf5340_cpu_net/zephyr/include/generated/autoconf.h'
    -- The C compiler identification is GNU 9.2.1
    -- The CXX compiler identification is GNU 9.2.1
    -- Found assembler: C:/Zypher/v1.5.0-rc1/toolchain/opt/bin/arm-none-eabi-gcc.exe
    -- Configuring done
    Including boilerplate (Zephyr base): C:/Zypher/v1.5.0-rc1/zephyr/cmake/app/boilerplate.cmake
    -- Using NCS Toolchain 1.5.0 for building. (C:/Zypher/v1.5.0-rc1/toolchain/cmake)
    warning: UART_CONSOLE (defined at drivers/console/Kconfig:47) was assigned the value 'y' but got the
    value 'n'. Check these unsatisfied dependencies: SERIAL (=n), SERIAL_HAS_DRIVER (=n). See
    docs.zephyrproject.org/.../CONFIG_UART_CONSOLE.html and/or look up
    UART_CONSOLE in the menuconfig/guiconfig interface. The Application Development Primer, Setting
    Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful
    too.
    CMake Warning at C:/Zypher/v1.5.0-rc1/zephyr/CMakeLists.txt:1354 (message):
    WARNING: The board 'nrf5340pdk_nrf5340_cpuapp' is deprecated and will be
    removed in version v2.6.0
    CMake Error at C:/Zypher/v1.5.0-rc1/zephyr/cmake/extensions.cmake:416 (add_library):
    No SOURCES given to target: drivers__spi
    C:/Zypher/v1.5.0-rc1/zephyr/cmake/extensions.cmake:393 (zephyr_library_named)
    C:/Zypher/v1.5.0-rc1/zephyr/drivers/spi/CMakeLists.txt:3 (zephyr_library)
    CMake Generate step failed. Build files cannot be regenerated correctly.
    error: cmake failed
    create_nordic_project.py failed (1)
    Kind regards
    Mohamed
    Those should have been deleted, as the project name wasn't descriptive from my side. My apologies for this.
    You should use blinky_netcore_temp (nrf5340pdk_nrf5340_cpunet) and blinky_appcore.
    Were you able to run these successfully and fetch the temperature data from one core to the other?
    You are getting an error wrt. spi sources. Could you try adding "CONFIG_NRFX_SPIM1=y" to see if it compiles then?
    You are also setting the overlay by aliasing it to itself. Try just keeping it as-is without the alias.
    Håkon
  • Thank you Hakon.
    For some reason I could not reply to your latest response. The fields "Reply"  "Verify Answer"   "More"  are not showing. So, I am replying to you from one of your earlier responses.
    Yes, I can read the temperature values in the Terminal Emulator window in SES.
    I applied both suggestions but the problem remains. Note, my overlay file worked fine even with the spi1 alias before I added this,
    &temp {
    compatible = "nordic,nrf-temp", "nordic,nrf-spim";
    status = "okay";
    I think I found what I was doing wrong, I was selecting the wrong board for my application. I was selecting nrf5340pdk_nrf5340_cpunet instead of nrf5340pdk_nrf5340_cpuapp.
    My application project is loading successfully now but I am getting this build error. Any suggestion?
    5> C:/Zypher/v1.5.0-rc1/zephyr/include/devicetree.h:208:32: error: 'DT_N_ALIAS_spi1_P_cs_gpios_IDX_0_PH_P_label' undeclared (first use in this function)
    5> C:/Zypher/v1.5.0-rc1/zephyr/include/devicetree.h:2176:24: note: in definition of macro 'DT_CAT'
    5> C:/Zypher/v1.5.0-rc1/zephyr/include/devicetree/gpio.h:103:2: note: in expansion of macro 'DT_PROP'
    5> C:/Zypher/v1.5.0-rc1/zephyr/include/devicetree.h:463:32: note: in expansion of macro 'DT_CAT'
    5> C:/Zypher/v1.5.0-rc1/zephyr/include/devicetree.h:1095:2: note: in expansion of macro 'DT_PROP'
    5> C:/Zypher/v1.5.0-rc1/zephyr/include/devicetree/gpio.h:54:2: note: in expansion of macro 'DT_PHANDLE_BY_IDX'
    5> C:/Zypher/v1.5.0-rc1/zephyr/include/devicetree/gpio.h:103:10: note: in expansion of macro 'DT_GPIO_CTLR_BY_IDX'
    5> C:/Zypher/v1.5.0-rc1/zephyr/include/devicetree/gpio.h:114:2: note: in expansion of macro 'DT_GPIO_LABEL_BY_IDX'
    5> ../src/radio/pid4_radio.h:261:29: note: in expansion of macro 'DT_GPIO_LABEL'
    5> C:/Zypher/v1.5.0-rc1/zephyr/include/devicetree.h:208:25: note: in expansion of macro 'DT_CAT'
    5> ../src/radio/pid4_radio.h:259:29: note: in expansion of macro 'DT_ALIAS'
    5> ../src/radio/pid4_radio.h:261:43: note: in expansion of macro 'SPI_1_NODE'
    5> ../src/radio/pid4_radio.c:203:43: note: in expansion of macro 'SPI_1_CS'
    5> C:/Zypher/v1.5.0-rc1/zephyr/include/devicetree.h:208:32: note: each undeclared identifier is reported only once for each function it appears in
    5> C:/Zypher/v1.5.0-rc1/zephyr/include/devicetree.h:208:32: error: 'DT_N_ALIAS_spi1_P_cs_gpios_IDX_0_VAL_pin' undeclared (first use in this function)
    5> C:/Zypher/v1.5.0-rc1/zephyr/include/devicetree.h:898:2: note: in expansion of macro 'DT_PROP'
    5> C:/Zypher/v1.5.0-rc1/zephyr/include/devicetree/gpio.h:158:2: note: in expansion of macro 'DT_PHA_BY_IDX'
    5> C:/Zypher/v1.5.0-rc1/zephyr/include/devicetree/gpio.h:169:2: note: in expansion of macro 'DT_GPIO_PIN_BY_IDX'
    5> ../src/radio/pid4_radio.h:262:29: note: in expansion of macro 'DT_GPIO_PIN'
    5> ../src/radio/pid4_radio.h:262:41: note: in expansion of macro 'SPI_1_NODE'
    5> ../src/radio/pid4_radio.c:208:27: note: in expansion of macro 'SPI_1_CS_PIN'
    Kind regards
    Mohamed
  • Good morning Hakon,
    Although I did report seeing the temperature values printed on the App Core side, I don't see them this morning. The App Core boots up and all I can see in SES Terminal Emulator is this message,
    *** Booting Zephyr OS build v2.4.99-ncs1-rc1 ***
    App Core
    In fact, I remember now, I had the same problem yesterday at first then after I open Segger RTT Viewer suddenly the App Core application started printing the temperature values. Please answer the following questions about this example.
    Q1/ Is this the expected behaviour?
    Q2/ What is this line doing? It seems to kick start the communication between App and Net Cores.
           uint32_t ret = ipm_send(ipm_tx_handle, 1, 0, NULL, 0);
    Q3/ I expected to see both the message "TX ID <id>" and "RX ID <id>" but I don't, I only this "RX ID 0"
    Q3/ Please explain the chronological sequence of events that is taking place between the App Core and the Net core.
    Thank you for your support.
    Kind regards
    Mohamed
