Zephyr API to read the nRF5340 die temperature
I am looking for some some nRF5340 example code that reads the nRF5340 die temperature using zephyr APIs.
I've looked at previous posts but I could only find this one https://devzone.nordicsemi.com/f/nordic-q-a/56171/how-to-get-die-temperature-on-nrf52832-using-zephyr from 10 months ago that stated none existed. I am hoping someone, somewhere musty have done something similar.
Thank you.
Kind regards
  • Hi Hakon,
    While waiting for your response to my previous reply where I asked you four questions I went back to my application (App Core) where I implemented the die temperature software based on your example. I am now unable to load the project in SES (File >  Open nRF Connect SDK Project...). I am getting this error,
    Cannot create project
    create_nordic_project.py failed(1)
    I am attaching a screen capture of the nRF Connect Options selected.
    Note, I am selecting the board nrf5340pdk_nrf5340_cpuapp for the App Core application. However, I've noticed in you very first response to my question you mentioned this
    The temp peripheral is only accessible on the network core:
    https://infocenter.nordicsemi.com/topic/ps_nrf5340/temp.html?cp=3_0_0_6_33
    So we need to configure the board nrf5340pdk_nrf5340_cpunet, but since the network core is started from the app cpu, you first need to have something on the app core running with this config set:
    Fullscreen
    1
    CONFIG_BOARD_ENABLE_CPUNET=y
    XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
    Must I include the above config line in my App Core project? Note, this line is not present in the project  file prj.conf of your App Core example.
    Another windge about DevZone, I cannot edit some of my responses.
    Kind regards
    Mohamed
    Learner said:
    &temp {
    compatible = "nordic,nrf-temp", "nordic,nrf-spim";
    status = "okay";
    The temp peripheral cannot be compatible with several hardware peripherals.
    If you need to use an SPI, you should declare it like this:
    &spiX
        status = "okay";
        rest-of-config;
    It seems that you are configuring for the network core. You should look into the peripherals available on the network core:
    https://infocenter.nordicsemi.com/topic/ps_nrf5340/chapters/memory.network/netmem.html?cp=3_0_0_5_2_0#net_instantiation
    For SPI, you should use "spi0". Note that SPIM0 is a shared peripheral, with other bus peripherals; meaning only one of SPI*0, TWI*0 can be enabled simultaneously:
    https://infocenter.nordicsemi.com/topic/ps_nrf5340/peripheral_interface.html?cp=3_0_0_6_0_1#concept_shared_id
    Håkon
  • Good morning Hakon,
    Thank you.
    Please look at my last two previous posts and answer my questions there. Ignore the older questions.
    I have changed my overlay file and it now looks like this,
    // SEGGER Embedded Studio auto generated
    &spi0 {
    status = "okay";
    cs-gpios = <&gpio0 19 0>;
    sck-pin = < 13 >;
    mosi-pin = < 9 >;
    miso-pin = < 40 >;
    &temp {
    compatible = "nordic,nrf-temp";
    status = "okay";
    But I am still getting the same error when I try to load the project. See below.
    Creating solution spi_test_LR1110-2-TX-RX-CMAC-AES.emProject
    C:/Zypher/v1.5.0-rc1/toolchain/opt/bin/cmake.exe -GNinja -DBOARD=nrf5340pdk_nrf5340_cpuapp -DBOARD_DIR=C:\Zypher\v1.5.0-rc1\zephyr\boards\arm\nrf5340dk_nrf5340 -BC:\Dev\PID-4\spi_test_LR1110-2-TX-RX-CMAC-AES\build_nrf5340pdk_nrf5340_cpuapp_Zypher_v1.50rc1_temp -SC:\Dev\PID-4\spi_test_LR1110-2-TX-RX-CMAC-AES -DNCS_TOOLCHAIN_VERSION=1.5.0 -DDTC_OVERLAY_FILE=C:\Dev\PID-4\spi_test_LR1110-2-TX-RX-CMAC-AES/nrf5340pdk_nrf5340_cpuapp.overlay -DEXTRA_KCONFIG_TARGETS=menuconfig_ses -DEXTRA_KCONFIG_TARGET_COMMAND_FOR_menuconfig_ses=C:\Zypher\v1.5.0-rc1\toolchain\segger_embedded_studio/html/configure_nordic_project_menuconfig.py
    -- Application: C:/Dev/PID-4/spi_test_LR1110-2-TX-RX-CMAC-AES
    -- Zephyr version: 2.4.99 (C:/Zypher/v1.5.0-rc1/zephyr)
    -- Found Python3: C:/Zypher/v1.5.0-rc1/toolchain/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
    -- Found west (found suitable version "0.9.0", minimum required is "0.7.1")
    -- Board: nrf5340pdk_nrf5340_cpuapp
    -- Cache files will be written to: C:/Zypher/v1.5.0-rc1/zephyr/.cache
    -- Found dtc: C:/Zypher/v1.5.0-rc1/toolchain/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
    -- Found toolchain: gnuarmemb (C:/Zypher/v1.5.0-rc1/toolchain/opt)
    -- Found BOARD.dts: C:/Zypher/v1.5.0-rc1/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340pdk_nrf5340_cpuapp.dts
    -- Found devicetree overlay: C:/Dev/PID-4/spi_test_LR1110-2-TX-RX-CMAC-AES/nrf5340pdk_nrf5340_cpuapp.overlay
    Including boilerplate (Zephyr base): C:/Zypher/v1.5.0-rc1/zephyr/cmake/app/boilerplate.cmake
    -- Using NCS Toolchain 1.5.0 for building. (C:/Zypher/v1.5.0-rc1/toolchain/cmake)
    Error: nrf5340pdk_nrf5340_cpuapp.dts.pre.tmp:704.1-6 Label or path temp not found
    FATAL ERROR: Syntax error parsing input tree
    CMake Error at C:/Zypher/v1.5.0-rc1/zephyr/cmake/dts.cmake:205 (message):
    command failed with return code: 1
    C:/Zypher/v1.5.0-rc1/zephyr/cmake/app/boilerplate.cmake:533 (include)
    C:/Zypher/v1.5.0-rc1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:24 (include)
    C:/Zypher/v1.5.0-rc1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:35 (include_boilerplate)
    CMakeLists.txt:15 (find_package)
    error: cmake failed
    create_nordic_project.py failed (1)
    I have been struggling with this problem for days, I hope you will be able to identify what I am doing wrong.
    I am not sure why you are saying I am configuring for the network. This is how my prj.conf file looks, all lines referring to the Network core are commented out.
    # Copyright (c) 2020 Nordic Semiconductor ASA
    # SPDX-License-Identifier: LicenseRef-BSD-5-Clause-Nordic
    ### Logging ####
    # For the PID 4 hardware we must set CONFIG_SERIAL=n because otherwise the SPI CS/BUSY
    # pins will be allocated to UART0 CTS/RTS pins.
    CONFIG_SERIAL=n
    CONFIG_LOG=y
    CONFIG_USE_SEGGER_RTT=y
    CONFIG_RTT_CONSOLE=y
    #CONFIG_UART_CONSOLE=n
    CONFIG_DEBUG_OPTIMIZATIONS=y
    CONFIG_NEWLIB_LIBC=y
    CONFIG_PRINTK=y
    # This will be needed when using to NCS v1.40 or higher, #ifdef ZEPHYR_V_1_50
    CONFIG_DEPRECATED_ZEPHYR_INT_TYPES=y
    ### NETWORK core ###
    # needed when measuring the SoC die temperature
    #!!!CONFIG_BOARD_ENABLE_CPUNET=n
    ### GPIOs ###
    CONFIG_GPIO=y
    # ADC
    CONFIG_ADC=y
    # No need for this as it is already enabled by default in ...\adc\Kconfig.nrfx
    #CONFIG_ADC_NRF5_SAADC = y
    ### SPI ###
    CONFIG_SPI=y
    #CONFIG_SPI_ASYNC=y
    CONFIG_MAIN_STACK_SIZE=4096
    CONFIG_SPI_1=y
    #!!!CONFIG_NRFX_SPIM1=y
    ### TEMPERATURE SENSOR ###
    #CONFIG_BOARD_ENABLE_CPUNET=y
    #CONFIG_SENSOR=y
    #CONFIG_TEMP_NRF5=y
    ### IPC stuff ###
    CONFIG_IPM=y
    CONFIG_IPM_NRFX=y
    CONFIG_IPM_MSG_CH_0_ENABLE=y
    CONFIG_IPM_MSG_CH_0_TX=y
    CONFIG_IPM_MSG_CH_1_ENABLE=y
    CONFIG_IPM_MSG_CH_1_RX=y
    # CONFIG_NRF_RPC=y
    ### I2C ###
    #CONFIG_LIS2DE12=y
    #CONFIG_I2C_1=y
    ### RTC ###
    # The RTC on nRF5340 is not really an Real Time Clock but it's a real time counter.
    # Timers will be used instead.
    #CONFIG_COUNTER_NRFX_RTC0=y
    ### RANDOM NUMBER GENERATION ###
    CONFIG_TIMER_RANDOM_GENERATOR=n
    CONFIG_ENTROPY_DEVICE_RANDOM_GENERATOR=n
    CONFIG_XOROSHIRO_RANDOM_GENERATOR=n
    # Cryptographically secure random number generators
    CONFIG_HARDWARE_DEVICE_CS_GENERATOR=n
    CONFIG_CTR_DRBG_CSPRNG_GENERATOR=n
    #CONFIG_CS_CTR_DRBG_PERSONALIZATION=n
    I also replaced the config line CONFIG_SPI_1=y with CONFIG_SPI_0=y and I got the same error.
    I am not I understand why I have to switch to using spi0 and not stick with spi1. Please explain.
    Thank you for your continued support.
    Kind regards
    Mohamed
  • Hi Mohamed,
    Learner said:
    &temp {
    status = "okay";
    Could you confirm if the nrf5340pdk_nrf5340_cpuapp.overlay contains "temp"?
    The TEMP peripheral is only available on the network core. The reason why you are getting an error is because for this specific board, there is no "temp" component.
    Håkon
  • Hi Hakon,
    I forgot to include details of the error I am getting in SES. Here it is below,
    Error: nrf5340pdk_nrf5340_cpuapp.dts.pre.tmp:710.1-6 Label or path temp not found
    CMakeLists.txt:14 (find_package)
    error: cmake failed
    Yes, I confirm my overlay file nrf5340pdk_nrf5340_cpuapp.overlay does contain  the "temp", because your blinky example appcore overlay file also contains it. The only difference I called my overlay file *_cpuapp.overlay while you called yours *_cpunet.overlay. Why and what is the significance of the naming convention?
    &temp {
     status = "okay";
    But in the example you sent me, in the blinky_appcore project you have an overlay file called nrf5340pdk_nrf5340_cpunet.overlay and contains "temp" which suggests that board nrf5340pdk does have a temp component. In fact your example ran, read and printed temperature values.
    Why is the appcore overlay file labelled "cpunet" when it is on the appcore?
    Kind regards
    Mohamed
