gap_params_init and connection parameter issue
I'm working on a firmware for a device that is created using ble proximity example. It is power constrain device and required a connection interval of 30 sec between a master (Android phone only) and slave nRF52810.
I’m using the following version and device.
  1. SDK v17.0.2
  2. 2. s112_nrf52_7.2.0_softdevice
  3. Basically I’m using Android phones as my central or master device and nRF52810 as peripheral or slave.
Basic feature of the firmware
                The architecture is based on Application Timer Event callbacks.
                The firmware was prepared using the BLE Peripheral Proximity example.
In order to minimize power consumption the device runs a minimum of active GATT services listed below:
  1. TX Power
  2. Instant Alert Service (IAS)
  3. Instant Alert Service Client (IAS-C)
  4. Connection is BLE_PERIPHERAL
To get the desire interval I'm changing the following parameters. I have used different values for these parameters without violating the following two constrain but seem I'm not able to go beyond 15 sec interval ( 30 sec is desired). Is there anything I'm not doing correct.
                   //constrains
    1. conn_sup_timeout * 4 > (1 + slave_latency) * max_conn_interval
    2. (1 + Conn_Latency) * Conn_Interval_Max * 2 < conn_sup_timeout
                   // Parameters
    1. MIN_CONN_INTERVAL               MSEC_TO_UNITS(800, UNIT_1_25_MS)
    2. MAX_CONN_INTERVAL               MSEC_TO_UNITS(830, UNIT_1_25_MS)
    3. SLAVE_LATENCY                   18
    4. CONN_SUP_TIMEOUT                MSEC_TO_UNITS(32000, UNIT_10_MS)
I'm getting the following error whenever I try to increase slave latency.
  • gap_params_init();
    • APP_ERROR_CHECK(err_code);
      • I think It might help you “void app_error_handler_bare(ret_code_t error_code)” here error_code = 0x00000007.
  • We are under the following assumptions.
    We want to use 110 mAh battery but still in the process of finalizing. We have a piezo buzzer (3 mA) and a led (2 mA).
    This is the alarm sequence
    1- LED "on" 500 ms, "off" 2000 ms
    2- LED "on" 500 ms, "off" 2000 ms
    4- LED "on" 500 ms, "off" 2000 ms
    5- Buzzer "on" 500 ms, "off" 2000 ms - 200 Hz frequency
    6- Buzzer "on" 500 ms, "off" 2000 ms
    7- Buzzer "on" 500 ms, "off" 2000 ms
    Device will be connected to 99%, 0.5% in alarm state, 0.5% advertising event. Our advertisement interval is 250 ms.
     In that case, the current from a 4second connection interval is negligible, so you don't need to spend time trying to increase the connection interval.
    Whether the radio uses 3µA or 1.5µA doesn't matter when you are drawing 5mA on top of that. Then your current consumption is 5mA, or 5.003mA if you like, but I assume the 5mA is not a 5.000mA.
    In your case, the LED is on 1/5th of the time, and the buzzer is on 1/5th of the time, so you have 3/5 + 2/5 mA = 1mA on average. Maybe less if the LED and buzzer are not used simultaneously.
    0.99*3µA
    + 0.005*1000µA
    + 0.005*38µA
    2.97µA
    + 5µA
    + 0.19µA
    = 8.16µA on average.
    This makes your 110mAh last 13480 hours = 561 days.
    Reducing the connection interval to 30 seconds if that was possible would take the average current consumption to 6.865µA, which would last 667 days. It is an increase, but you have a lot more to save by reducing the alarm time (shorter on for the LED and the buzzer).
    If that is not an option, I am afraid you need to look into a bigger battery.
    BR,
    Edvin
    I hope you had a great weekend, now I'm following all restrictions you mentioned here. I'm using following new parameters. But it still disconnect after one or two day. I'm using nRF connect app in android (this project is only for android). Can you tell me where I'm going wrong. You mentioned about Bluetooth specification, Vol6, part B, section 4.5.2: in your previous reply, would you please forward me the link for this pdf.
    #define MIN_CONN_INTERVAL MSEC_TO_UNITS(900, UNIT_1_25_MS)
    #define MAX_CONN_INTERVAL MSEC_TO_UNITS(1000, UNIT_1_25_MS)
    #define SLAVE_LATENCY 12
    #define CONN_SUP_TIMEOUT MSEC_TO_UNITS(32000, UNIT_10_MS)
    #define APP_ADV_INTERVAL MSEC_TO_UNITS(250, UNIT_0_625_MS)
    #define APP_ADV_DURATION 30000 // originally value was: 18000
    Thank you
    You can download the Bluetooth core specification here.
    What is the disconnect reason? Based on this discussion I assume it is supervision timeout, but I do not see it clearly stated so it would be good to know. Also, have you only tested one Android device, or do you see the same with other devices?
    And also, is there a problem with these disconnects? Normally the peripheral would start advertise on a disconnect and the phone would connect again without the user ever notising a difference. Depending on the RF environment etc it may not be possible to ensure that you never get any disconnects.
  • Hello Einar,
    Thank you for your kind response
    Error I can see on my nRF Connect app is Error 133, defined as: #define GATT_ERROR 0x85
    I believe supervision timeout is not the reason for the disconnection. As last night I changed my connection parameters to the default values accept advertisement interval.
    #define MIN_CONN_INTERVAL MSEC_TO_UNITS(500, UNIT_1_25_MS) /**< Minimum acceptable connection interval (0.5 seconds). */
    #define MAX_CONN_INTERVAL MSEC_TO_UNITS(1000, UNIT_1_25_MS) /**< Maximum acceptable connection interval (1 second). */
    #define SLAVE_LATENCY 0 /**< Slave latency. */
    #define CONN_SUP_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Connection supervisory timeout (4 seconds). */
    // change by Haider: old value APP_ADV_INTERVAL 40 {Range can be 20ms to 10.24 sec} /**< The advertising interval (in units of 0.625 ms. This value corresponds to 25 ms). */
    #define APP_ADV_DURATION 30000 // originally: 18000
    I'm using it with the similar device but does it matter? I also notice it do not connect after disconnection even if I manually tap the connect button on the app. I have to restart my peripheral and connect it.
