gap_params_init and connection parameter issue
I'm working on a firmware for a device that is created using ble proximity example. It is power constrain device and required a connection interval of 30 sec between a master (Android phone only) and slave nRF52810.
I’m using the following version and device.
  1. SDK v17.0.2
  2. 2. s112_nrf52_7.2.0_softdevice
  3. Basically I’m using Android phones as my central or master device and nRF52810 as peripheral or slave.
Basic feature of the firmware
                The architecture is based on Application Timer Event callbacks.
                The firmware was prepared using the BLE Peripheral Proximity example.
In order to minimize power consumption the device runs a minimum of active GATT services listed below:
  1. TX Power
  2. Instant Alert Service (IAS)
  3. Instant Alert Service Client (IAS-C)
  4. Connection is BLE_PERIPHERAL
To get the desire interval I'm changing the following parameters. I have used different values for these parameters without violating the following two constrain but seem I'm not able to go beyond 15 sec interval ( 30 sec is desired). Is there anything I'm not doing correct.
                   //constrains
    1. conn_sup_timeout * 4 > (1 + slave_latency) * max_conn_interval
    2. (1 + Conn_Latency) * Conn_Interval_Max * 2 < conn_sup_timeout
                   // Parameters
    1. MIN_CONN_INTERVAL               MSEC_TO_UNITS(800, UNIT_1_25_MS)
    2. MAX_CONN_INTERVAL               MSEC_TO_UNITS(830, UNIT_1_25_MS)
    3. SLAVE_LATENCY                   18
    4. CONN_SUP_TIMEOUT                MSEC_TO_UNITS(32000, UNIT_10_MS)
I'm getting the following error whenever I try to increase slave latency.
  • gap_params_init();
    • APP_ERROR_CHECK(err_code);
      • I think It might help you “void app_error_handler_bare(ret_code_t error_code)” here error_code = 0x00000007.
  • err_code = 7 means NRF_ERROR_INVALID_PARAM (look at nrf_error.h).
    You have set your conn_sup_timeout to 32 000 units of 10ms = 32 seconds, which is the maximum allowed supervision timeout.
    From the Bluetooth specification, Vol6, part B, section 4.5.2:
    The connSupervisionTimeout shall be a multiple of 10ms in the range 100ms to 32.0s and shall be larger than
    (1 + connSlaveLatency) * connInterval * 2
    which is considered in your b. constraint.
    When conn_latency = 18:
    (1+18) * 800*1.25 *  2 = 38 000, which is already larger than your supervision timeout, so it should probably have returned NRF_ERROR_INVALID_PARAMS.
    You can't have 30ms connection interval. You can have maximum 4 seconds (you can find the limits in ble_gap.h. Search for BLE_GAP_CP_LIMITS).
    The reason that this requirement exists is that the devices should have at least two attempts to send a packet before they disconnect. Otherwise, you will get a disconnect every time a packet is lost due to noise on air.
    BR,
    Edvin
  • Thank you for your reply,
    I agree with your statement.
    But my connection interval is 830 ms and I'm taking advantage of slave latency to achieve effective connection interval 30 sec.
    But I think (1 + connSlaveLatency) * connInterval * 2 constrain don't allow to go beyond 15 sec. Or do we have any other way to get the better result.
    Do we have a way to disconnection and reconnect the peripheral with the 30 sec interval and transfer packets. but it is important to slave to sleep during that period of time.
    Thanks
     I agree.
     Yes, it is possible, but I don't know whether it actually saves you any power. Setting up a connection requires more packets back and forth than just maintaining the "15 second connection interval".
    Why do you have this strict requirement of 30ms? Is it to save power? If so, then using 15sec should be fine. You aren't saving much on going from 15 to 30 seconds. Besides, 30 seconds is against the specification.
    So why do you have this strict requirement of 30 seconds connection interval?
  • Thank you so much for the your help. We think about your suggestion regarding  more power consumption in disconnect and connect method and agree with you and dropping that idea.
    We wanted that spec. because of our battery life need to be more than 180 days. After doing some math we come up with that number. But if its impossible to do, we can compromise over there.
    you mention about Bluetooth specification, Vol6, part B, section 4.5.2:. Do you have link for this PDF. I have a PDF for Apple BLE spec., does something similar exist for Android I looked for it but didn't find any. It will be a great help if you can give me a link for that.
     What battery are you using? That should be doable using a coin cell battery, but it depends on what other things your application is doing. Perhaps you are looking in the wrong place.
    If a 15 (or 4 second) connection interval makes your battery drain in less than 180 days, then there is either a bug, or you are using a peripheral that is drawing a lot of power (causing the BLE current consumption to become negligible.
    Please check out our Online Power Profiler.
    Using 4 sec connection interval, and a bare minimum application it should consume about 3.3µA:
    Edit:
    If the coin cell battery contains 200mAh, it should last a couple of years. Of course there is some loss due to leak current, and your application is maybe using some other peripherals drawing a bit of power. The battery's internal resistance also matters.
    What sort of battery are you using?
    BR,
    Edvin
