hello Support team,
When customer to compile Nordic CHIP demo code(connectedhomeip\examples\lighting-app\nrfconnect. compiling error was attached.
tje
build@7766665acb29:/var/chip/examples/lighting-app/nrfconnect$ west build -b nrf52840dk_nrf52840
Including boilerplate (Zephyr base): /var/ncs/zephyr/cmake/app/boilerplate.cmake
-- Application: /var/chip/examples/lighting-app/nrfconnect
-- Zephyr version: 2.4.0 (/var/ncs/zephyr)
-- Found Python3: /usr/bin/python3.8 (found suitable exact version "3.8.5") found components: Interpreter
-- Found west (found suitable version "0.8.0", minimum required is "0.7.1")
-- Board: nrf52840dk_nrf52840
-- Cache files will be written to: /var/ncs/zephyr/.cache
-- Found dtc: /usr/bin/dtc (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found toolchain: gnuarmemb (/opt/gcc-arm-none-eabi-9-2020-q2-update)
-- Found BOARD.dts: /var/ncs/zephyr/boards/arm/nrf52840dk_nrf52840/nrf52840dk_nrf52840.dts
-- Found devicetree overlay: /var/chip/examples/lighting-app/nrfconnect/dts.overlay
-- Generated zephyr.dts: /var/chip/examples/lighting-app/nrfconnect/build/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: /var/chip/examples/lighting-app/nrfconnect/build/zephyr/include/generated/devicetree_unfixed.h
warning: LOG_STRDUP_MAX_STRING (defined at subsys/logging/Kconfig:238) was assigned the value '256'
but got the value ''. Check these unsatisfied dependencies: (!LOG_MINIMAL) (=n). See
http://docs.zephyrproject.org/latest/reference/kconfig/CONFIG_LOG_STRDUP_MAX_STRING.html and/or look
up LOG_STRDUP_MAX_STRING in the menuconfig/guiconfig interface. The Application Development Primer,
Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be
helpful too.
warning: LOG_STRDUP_BUF_COUNT (defined at subsys/logging/Kconfig:245) was assigned the value '20'
http://docs.zephyrproject.org/latest/reference/kconfig/CONFIG_LOG_STRDUP_BUF_COUNT.html and/or look
up LOG_STRDUP_BUF_COUNT in the menuconfig/guiconfig interface. The Application Development Primer,
helpful too.
Parsing /var/chip/config/nrfconnect/Kconfig
Loaded configuration '/var/ncs/zephyr/boards/arm/nrf52840dk_nrf52840/nrf52840dk_nrf52840_defconfig'
Merged configuration '/var/chip/examples/lighting-app/nrfconnect/prj.conf'
Merged configuration '/var/chip/config/nrfconnect/overlay-sample-defaults.conf'
Configuration saved to '/var/chip/examples/lighting-app/nrfconnect/build/zephyr/.config'
Kconfig header saved to '/var/chip/examples/lighting-app/nrfconnect/build/zephyr/include/generated/autoconf.h'
-- The C compiler identification is GNU 9.3.1
-- The CXX compiler identification is GNU 9.3.1
-- Found assembler: /opt/gcc-arm-none-eabi-9-2020-q2-update/bin/arm-none-eabi-gcc
-- Check if the system is big endian
-- Searching 16 bit integer
-- Looking for sys/types.h
-- Looking for sys/types.h - found
-- Looking for stdint.h
-- Looking for stdint.h - found
-- Looking for stddef.h
-- Looking for stddef.h - found
-- Check size of unsigned short
-- Check size of unsigned short - done
-- Searching 16 bit integer - Using unsigned short
-- Check if the system is big endian - little endian
-- Version: g07f430dac
CMake Warning at /var/ncs/zephyr/CMakeLists.txt:1331 (message):
-- Configuring done
-- Generating done
-- Build files have been written to: /var/chip/examples/lighting-app/nrfconnect/build
[1/546] Preparing syscall dependency handling
[6/546] Performing configure step for 'ChipConfig'
Done. Made 41 targets from 55 files in 745ms
[22/546] cd /var/chip/examples/lightin..."\n"MBEDTLS_CONFIG_FILE="nrf-config.h"
-e OPENTHREAD_CONFIG_ENABLE_BUILTIN_MBEDTLS=0
OPENTHREAD_CONFIG_ENABLE_BUILTIN_MBEDTLS_MANAGEMENT=0
OPENTHREAD_CONFIG_DHCP6_CLIENT_ENABLE=1
OPENTHREAD_CONFIG_DHCP6_SERVER_ENABLE=1
OPENTHREAD_CONFIG_DNS_CLIENT_ENABLE=1
OPENTHREAD_CONFIG_JOINER_ENABLE=1
OPENTHREAD_CONFIG_TMF_NETWORK_DIAG_MTD_ENABLE=1
OPENTHREAD_CONFIG_TMF_NETDATA_SERVICE_ENABLE=1
OPENTHREAD_CONFIG_IP6_SLAAC_ENABLE=1
OPENTHREAD_CONFIG_SNTP_CLIENT_ENABLE=1
PACKAGE_NAME=OPENTHREAD
PACKAGE_VERSION=g07f430dac
OPENTHREAD_CONFIG_THREAD_VERSION=OT_THREAD_VERSION_1_1
KERNEL
__ZEPHYR__=1
_FORTIFY_SOURCE=2
BUILD_VERSION=v2.4.0-ncs1-rc1-7-g41ce8e165a9a
__LINUX_ERRNO_EXTENSIONS__
USE_PARTITION_MANAGER=0
__PROGRAM_START
NRF_802154_IRQ_PRIORITY=1
NRF_802154_INTERNAL_RADIO_IRQ_HANDLING=0
NRF_802154_USE_RAW_API=1
NRF_802154_PENDING_SHORT_ADDRESSES=16
NRF_802154_PENDING_EXTENDED_ADDRESSES=16
NRF_802154_RX_BUFFERS=8
NRF_802154_CCA_MODE_DEFAULT=NRF_RADIO_CCA_MODE_ED
NRF_802154_CCA_CORR_LIMIT_DEFAULT=2
NRF_802154_CCA_CORR_THRESHOLD_DEFAULT=45
NRF_802154_CCA_ED_THRESHOLD_DEFAULT=45
NRF_802154_CSMA_CA_ENABLED=1
NRF_802154_TX_STARTED_NOTIFY_ENABLED=1
NRF_802154_FRAME_TIMESTAMP_ENABLED=1
NRF_802154_DELAYED_TRX_ENABLED=1
NRF_802154_ACK_TIMEOUT_ENABLED=1
NRF52840_XXAA
MBEDTLS_CONFIG_FILE=nrf-config.h
[507/546] Performing build step for 'ChipLibBuild'
[9/111] c++ obj/third_party/connectedhomeip/src/app/libCHIPDataModel.decoder.cpp.o
FAILED: obj/third_party/connectedhomeip/src/app/libCHIPDataModel.decoder.cpp.o
/opt/gcc-arm-none-eabi-9-2020-q2-update/bin/arm-none-eabi-g++ -MMD -MF obj/third_party/connectedhomeip/src/app/libCHIPDataModel.decoder.cpp.o.d -Wconversion -mthumb -O0 -g2 -fno-common -ffunction-sections -fdata-sections -fno-exceptions -Wall -Werror -Wno-deprecated-declarations -Wno-unknown-warning-option -Wno-missing-field-initializers -Wno-unused-but-set-variable -Wno-unused-variable -Wno-psabi -Wno-cast-function-type -Wno-maybe-uninitialized -fdiagnostics-color -fno-strict-aliasing -std=gnu++11 -fno-rtti -Wno-non-virtual-dtor -Wno-deprecated-copy -isystem/var/ncs/nrf/drivers/mpsl/clock_control -isystem/var/ncs/zephyr/include -isystem/var/chip/examples/lighting-app/nrfconnect/build/zephyr/include/generated -isystem/var/ncs/zephyr/soc/arm/nordic_nrf/nrf52 -isystem/var/ncs/zephyr/lib/libc/newlib/include -isystem/var/ncs/zephyr/lib/fnmatch/. -isystem/var/ncs/zephyr/subsys/net/lib/sockets/. -isystem/var/ncs/zephyr/subsys/net/lib/openthread/platform/. -isystem/var/ncs/zephyr/subsys/settings/include -isystem/var/ncs/zephyr/subsys/bluetooth -isystem/var/ncs/nrf/include -isystem/var/ncs/nrf/lib/multithreading_lock/. -isystem/var/ncs/nrf/subsys/bluetooth/controller/. -isystem/var/ncs/nrfxlib/mpsl/include -isystem/var/ncs/nrfxlib/crypto/nrf_cc310_mbedcrypto/include/mbedtls -isystem/var/ncs/nrfxlib/crypto/nrf_cc310_mbedcrypto/include -isystem/var/chip/examples/lighting-app/nrfconnect/build/modules/nrfxlib/nrf_security/include -isystem/var/chip/examples/lighting-app/nrfconnect/build/modules/nrfxlib/nrf_security/include/mbedtls_generated/ -isystem/var/ncs/mbedtls/include -isystem/var/ncs/mbedtls/include/mbedtls -isystem/var/ncs/nrfxlib/softdevice_controller/include -isystem/var/ncs/modules/hal/cmsis/CMSIS/Core/Include -isystem/var/ncs/modules/hal/nordic/drivers/nrf_radio_802154/. -isystem/var/ncs/modules/hal/nordic/nrfx -isystem/var/ncs/modules/hal/nordic/nrfx/drivers/include -isystem/var/ncs/modules/hal/nordic/nrfx/mdk -isystem/var/ncs/modules/hal/nordic/. -isystem/var/ncs/modules/lib/openthread/zephyr/../include -isystem/var/ncs/modules/lib/openthread/zephyr/../examples/platforms -isystem/var/ncs/modules/debug/segger/rtt -isystem/var/ncs/modules/crypto/tinycrypt/lib/include -isystem/var/ncs/zephyr/../nrfxlib/crypto/nrf_cc310_platform/include -isystem/var/ncs/modules/lib/openthread/zephyr/../include -isystem/var/ncs/modules/lib/openthread/zephyr/../examples/platforms -DKERNEL -D__ZEPHYR__=1 -D_FORTIFY_SOURCE=2 -DBUILD_VERSION=v2.4.0-ncs1-rc1-7-g41ce8e165a9a -D__LINUX_ERRNO_EXTENSIONS__ -DUSE_PARTITION_MANAGER=0 -D__PROGRAM_START -DNRF_802154_IRQ_PRIORITY=1 -DNRF_802154_INTERNAL_RADIO_IRQ_HANDLING=0 -DNRF_802154_USE_RAW_API=1 -DNRF_802154_PENDING_SHORT_ADDRESSES=16 -DNRF_802154_PENDING_EXTENDED_ADDRESSES=16 -DNRF_802154_RX_BUFFERS=8 -DNRF_802154_CCA_MODE_DEFAULT=NRF_RADIO_CCA_MODE_ED -DNRF_802154_CCA_CORR_LIMIT_DEFAULT=2 -DNRF_802154_CCA_CORR_THRESHOLD_DEFAULT=45 -DNRF_802154_CCA_ED_THRESHOLD_DEFAULT=45 -DNRF_802154_CSMA_CA_ENABLED=1 -DNRF_802154_TX_STARTED_NOTIFY_ENABLED=1 -DNRF_802154_FRAME_TIMESTAMP_ENABLED=1 -DNRF_802154_DELAYED_TRX_ENABLED=1 -DNRF_802154_ACK_TIMEOUT_ENABLED=1 -DNRF52840_XXAA -Os -fcheck-new -std=c++11 -Wno-register -fno-exceptions -fno-rtti -imacros /var/chip/examples/lighting-app/nrfconnect/build/zephyr/include/generated/autoconf.h -ffreestanding -fno-common -g -mcpu=cortex-m4 -mthumb -mabi=aapcs -imacros /var/ncs/zephyr/include/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-main -Wpointer-arith -Wno-address-of-packed-member -Wno-unused-but-set-variable -fno-asynchronous-unwind-tables -fno-pie -fno-pic -fno-strict-overflow -fno-reorder-functions -fno-defer-pop -fmacro-prefix-map=/var/chip/examples/lighting-app/nrfconnect=CMAKE_SOURCE_DIR -fmacro-prefix-map=/var/ncs/zephyr=ZEPHYR_BASE -fmacro-prefix-map=/var/ncs=WEST_TOPDIR -ffunction-sections -fdata-sections -specs=nano.specs -D_SYS__PTHREADTYPES_H_ -DMBEDTLS_CONFIG_FILE=\<nrf-config.h\> -DMBEDTLS_PK_WRITE_C -DMBEDTLS_X509_CREATE_C -DMBEDTLS_X509_CSR_WRITE_C -isystem/var/ncs/zephyr/include/posix -isystem/var/ncs/zephyr/../mbedtls/include -I/var/chip/examples/lighting-app/nrfconnect -I/var/chip/examples/lighting-app/nrfconnect/main/include -std=gnu++11 -DCHIP_HAVE_CONFIG_H=1 -I../../../../../config/nrfconnect/third_party/connectedhomeip/src/app/gen -I../../../../../config/nrfconnect/third_party/connectedhomeip/src/app/util -I../../../../../config/nrfconnect/third_party/connectedhomeip/src/app -Igen/third_party/connectedhomeip/src/app/include -I../../../../../config/nrfconnect/third_party/connectedhomeip/src/include -I../../../../../config/nrfconnect/third_party/connectedhomeip/src -Igen/include -I../../../../../config/nrfconnect/third_party/connectedhomeip/src/lib -I../../../../../config/nrfconnect/third_party/connectedhomeip/third_party/nlassert/repo/include -I../../../../../config/nrfconnect/third_party/connectedhomeip/third_party/nlio/repo/include -c ../../../../../config/nrfconnect/third_party/connectedhomeip/src/app/decoder.cpp -o obj/third_party/connectedhomeip/src/app/libCHIPDataModel.decoder.cpp.o
In file included from ../../../../../config/nrfconnect/third_party/connectedhomeip/src/app/decoder.cpp:26:
../../../../../config/nrfconnect/third_party/connectedhomeip/src/lib/core/CHIPEncoding.h:36:10: fatal error: nlbyteorder.hpp: No such file or directory
36 | #include <nlbyteorder.hpp>
compilation terminated.
[10/111] c++ obj/third_party/connectedhomeip/src/app/libCHIPDataModel.encoder.cpp.o
FAILED: chip/src/ChipLibBuild-stamp/ChipLibBuild-build chip/lib/libCHIP.a
cd /var/chip/examples/lighting-app/nrfconnect/build/chip && ninja
FATAL ERROR: command exited with status 1: /usr/local/bin/cmake --build /var/chip/examples/lighting-app/nrfconnect/build
the code is from
https://github.com/project-chip/connectedhomeip/tree/master/examples/lighting-app/nrfconnect
Best Regards,
George XIONG
