nRF SDK hci_usb extended connection disconnects after 40 seconds
Hello there,
hci_usb sample with following configuration always disconnects after 40 seconds.
Board: PCA10059, PCA10056 (both produces that error)
Host: Raspberry Pi 3, Raspbian, kernel 5.4.51-v7+
SDK Version: nRF Connect SDK v1.3.2
Configuration:
CONFIG_STDOUT_CONSOLE=y
CONFIG_GPIO=y
CONFIG_SERIAL=y
CONFIG_BT=y
CONFIG_BT_HCI=y
CONFIG_USB=y
CONFIG_USB_DEVICE_STACK=y
CONFIG_USB_DEVICE_BLUETOOTH=y
CONFIG_USB_DEVICE_BLUETOOTH_VS_H4=y
CONFIG_MAIN_STACK_SIZE=1024
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=1024
CONFIG_BT_CTLR_RX_BUFFERS=18
CONFIG_BT_CTLR_TX_BUFFERS=19
CONFIG_BT_CTLR_TX_BUFFER_SIZE=251
CONFIG_BT_CTLR_DATA_LENGTH_MAX=251
CONFIG_BT_HCI_CMD_COUNT=20
CONFIG_BT_RX_BUF_COUNT=20
CONFIG_BT_RX_BUF_LEN=258
CONFIG_BT_DISCARDABLE_BUF_SIZE=257
CONFIG_BT_MAX_CONN=10
CONFIG_USB_REQUEST_BUFFER_SIZE=384
CONFIG_BT_EXT_ADV=y
CONFIG_BT_CTLR_PHY_CODED=y
CONFIG_BT_LLL_VENDOR_NORDIC=y
CONFIG_BT_LL_NRFXLIB=y
When it attached to the host, the btmon output is like following:
Bluetooth monitor ver 5.54
= Note: Linux version 5.4.51-v7+ (armv7l)                              0.929263
= Note: Bluetooth subsystem version 2.22                               0.929273
= New Index: 00:00:00:00:00:00 (Primary,USB,hci0)               [hci0] 0.929277
= Open Index: 00:00:00:00:00:00                                 [hci0] 0.929280
= Index Info: 00:00:00:00:00:00 (Nordic Semiconductor ASA)      [hci0] 0.929285
@ MGMT Open: bluetoothd (privileged) version 1.14             {0x0002} 0.929290
@ MGMT Open: btmon (privileged) version 1.14                  {0x0001} 0.929642
@ RAW Open: hciconfig (privileged) version 2.22               {0x0003} 5.368125
@ MGMT Event: New Settings (0x0006) plen 4             {0x0001} [hci0] 5.368254
        Current settings: 0x00008a10
          Bondable
          Low Energy
          Secure Connections
          Static Address
@ MGMT Event: New Settings (0x0006) plen 4             {0x0002} [hci0] 5.368254
          Bondable
          Low Energy
          Secure Connections
          Static Address
= Close Index: 00:00:00:00:00:00                                [hci0] 5.368344
= Open Index: 00:00:00:00:00:00                                 [hci0] 5.368540
< HCI Command: Reset (0x03|0x0003) plen 0                    #1 [hci0] 5.368610
> HCI Event: Command Complete (0x0e) plen 4                  #2 [hci0] 5.369921
      Reset (0x03|0x0003) ncmd 1
        Status: Success (0x00)
< HCI Command: Read Local Supported... (0x04|0x0003) plen 0  #3 [hci0] 5.370005
> HCI Event: Command Complete (0x0e) plen 12                 #4 [hci0] 5.371933
      Read Local Supported Features (0x04|0x0003) ncmd 1
        Features: 0x00 0x00 0x00 0x00 0x60 0x00 0x00 0x00
          BR/EDR Not Supported
          LE Supported (Controller)
< HCI Command: Read Local Version In.. (0x04|0x0001) plen 0  #5 [hci0] 5.372035
> HCI Event: Command Complete (0x0e) plen 12                 #6 [hci0] 5.374918
      Read Local Version Information (0x04|0x0001) ncmd 1
        HCI version: Reserved (0x0b) - Revision 4331 (0x10eb)
        LMP version: Reserved (0x0b) - Subversion 4331 (0x10eb)
        Manufacturer: Nordic Semiconductor ASA (89)
< HCI Command: Read BD ADDR (0x04|0x0009) plen 0             #7 [hci0] 5.374991
> HCI Event: Command Complete (0x0e) plen 10                 #8 [hci0] 5.375907
      Read BD ADDR (0x04|0x0009) ncmd 1
        Address: 00:00:00:00:00:00 (OUI 00-00-00)
< HCI Command: LE Read Buffer Size (0x08|0x0002) plen 0      #9 [hci0] 5.376047
> HCI Event: Command Complete (0x0e) plen 7                 #10 [hci0] 5.377906
      LE Read Buffer Size (0x08|0x0002) ncmd 1
        Data packet length: 251
        Num data packets: 3
< HCI Command: LE Read Local Suppor.. (0x08|0x0003) plen 0  #11 [hci0] 5.377973
> HCI Event: Command Complete (0x0e) plen 12                #12 [hci0] 5.379930
      LE Read Local Supported Features (0x08|0x0003) ncmd 1
        Features: 0xf5 0x59 0x00 0x00 0x00 0x00 0x00 0x00
          LE Encryption
          Extended Reject Indication
          LE Ping
          LE Data Packet Length Extension
          LL Privacy
          Extended Scanner Filter Policies
          LE 2M PHY
          LE Coded PHY
          LE Extended Advertising
          Channel Selection Algorithm #2
< HCI Command: LE Read Supported St.. (0x08|0x001c) plen 0  #13 [hci0] 5.380000
> HCI Event: Command Complete (0x0e) plen 12                #14 [hci0] 5.380916
      LE Read Supported States (0x08|0x001c) ncmd 1
        States: 0x000003ffff3fffff
          Non-connectable Advertising State
          Scannable Advertising State
          Connectable Advertising State
          High Duty Cycle Directed Advertising State
          Passive Scanning State
          Active Scanning State
          Initiating State
            and Connection State (Master Role)
          Connection State (Slave Role)
            and Passive Scanning State
            and Active Scanning State
            and Initiating State
            and Connection State (Slave Role)
          Initiating State
            and Master Role & Master Role
          Low Duty Cycle Directed Advertising State
            and Master Role & Slave Role
            and Slave Role & Slave Role
          Initiating State
< HCI Command: Read Local Supported.. (0x04|0x0002) plen 0  #15 [hci0] 5.380978
> HCI Event: Command Complete (0x0e) plen 68                #16 [hci0] 5.383907
      Read Local Supported Commands (0x04|0x0002) ncmd 1
        Commands: 74 entries
          Disconnect (Octet 0 - Bit 5)
          Read Remote Version Information (Octet 2 - Bit 7)
          Set Event Mask (Octet 5 - Bit 6)
          Reset (Octet 5 - Bit 7)
          Read Transmit Power Level (Octet 10 - Bit 2)
          Set Controller To Host Flow Control (Octet 10 - Bit 5)
          Host Buffer Size (Octet 10 - Bit 6)
          Host Number of Completed Packets (Octet 10 - Bit 7)
          Read Local Version Information (Octet 14 - Bit 3)
          Read Local Supported Features (Octet 14 - Bit 5)
          Read BD ADDR (Octet 15 - Bit 1)
          Read RSSI (Octet 15 - Bit 5)
          Set Event Mask Page 2 (Octet 22 - Bit 2)
          LE Set Event Mask (Octet 25 - Bit 0)
          LE Read Buffer Size (Octet 25 - Bit 1)
          LE Read Local Supported Features (Octet 25 - Bit 2)
          LE Set Random Address (Octet 25 - Bit 4)
          LE Set Advertising Parameters (Octet 25 - Bit 5)
          LE Read Advertising Channel TX Power (Octet 25 - Bit 6)
          LE Set Advertising Data (Octet 25 - Bit 7)
          LE Set Scan Response Data (Octet 26 - Bit 0)
          LE Set Advertise Enable (Octet 26 - Bit 1)
          LE Set Scan Parameters (Octet 26 - Bit 2)
          LE Set Scan Enable (Octet 26 - Bit 3)
          LE Create Connection (Octet 26 - Bit 4)
          LE Create Connection Cancel (Octet 26 - Bit 5)
          LE Read White List Size (Octet 26 - Bit 6)
          LE Clear White List (Octet 26 - Bit 7)
          LE Add Device To White List (Octet 27 - Bit 0)
          LE Remove Device From White List (Octet 27 - Bit 1)
          LE Connection Update (Octet 27 - Bit 2)
          LE Set Host Channel Classification (Octet 27 - Bit 3)
          LE Read Channel Map (Octet 27 - Bit 4)
          LE Read Remote Used Features (Octet 27 - Bit 5)
          LE Encrypt (Octet 27 - Bit 6)
          LE Rand (Octet 27 - Bit 7)
          LE Start Encryption (Octet 28 - Bit 0)
          LE Long Term Key Request Reply (Octet 28 - Bit 1)
          LE Long Term Key Request Neg Reply (Octet 28 - Bit 2)
          LE Read Supported States (Octet 28 - Bit 3)
          LE Receiver Test (Octet 28 - Bit 4)
          LE Transmitter Test (Octet 28 - Bit 5)
          LE Test End (Octet 28 - Bit 6)
          Read Authenticated Payload Timeout (Octet 32 - Bit 4)
          Write Authenticated Payload Timeout (Octet 32 - Bit 5)
          LE Set Data Length (Octet 33 - Bit 6)
          LE Read Suggested Default Data Length (Octet 33 - Bit 7)
          LE Write Suggested Default Data Length (Octet 34 - Bit 0)
          LE Add Device To Resolving List (Octet 34 - Bit 3)
          LE Remove Device From Resolving List (Octet 34 - Bit 4)
          LE Clear Resolving List (Octet 34 - Bit 5)
          LE Read Resolving List Size (Octet 34 - Bit 6)
          LE Set Address Resolution Enable (Octet 35 - Bit 1)
          LE Set Resolvable Private Address Timeout (Octet 35 - Bit 2)
          LE Read Maximum Data Length (Octet 35 - Bit 3)
          LE Read PHY (Octet 35 - Bit 4)
          LE Set Default PHY (Octet 35 - Bit 5)
          LE Set PHY (Octet 35 - Bit 6)
          LE Enhanced Receiver Test (Octet 35 - Bit 7)
          LE Enhanced Transmitter Test (Octet 36 - Bit 0)
          LE Set Advertising Set Random Address (Octet 36 - Bit 1)
          LE Set Extended Advertising Parameters (Octet 36 - Bit 2)
          LE Set Extended Advertising Data (Octet 36 - Bit 3)
          LE Set Extended Scan Response Data (Octet 36 - Bit 4)
          LE Set Extended Advertising Enable (Octet 36 - Bit 5)
          LE Read Maximum Advertising Data Length (Octet 36 - Bit 6)
          LE Read Number of Supported Advertising Sets (Octet 36 - Bit 7)
          LE Remove Advertising Set (Octet 37 - Bit 0)
          LE Clear Advertising Sets (Octet 37 - Bit 1)
          LE Set Extended Scan Parameters (Octet 37 - Bit 5)
          LE Set Extended Scan Enable (Octet 37 - Bit 6)
          LE Extended Create Connection (Octet 37 - Bit 7)
          LE Read Transmit Power (Octet 38 - Bit 7)
          LE Set Privacy Mode (Octet 39 - Bit 2)
< HCI Command: Set Event Mask (0x03|0x0001) plen 8          #17 [hci0] 5.384072
        Mask: 0x200080000204e890
          Disconnection Complete
          Encryption Change
          Read Remote Version Information Complete
          Command Complete
          Command Status
          Hardware Error
          Data Buffer Overflow
          Encryption Key Refresh Complete
          LE Meta
> HCI Event: Command Complete (0x0e) plen 4                 #18 [hci0] 5.384909
      Set Event Mask (0x03|0x0001) ncmd 1
< HCI Command: LE Set Event Mask (0x08|0x0001) plen 8       #19 [hci0] 5.384978
        Mask: 0x00000000000a1e5f
          LE Connection Complete
          LE Advertising Report
          LE Connection Update Complete
          LE Read Remote Used Features Complete
          LE Data Length Change
          LE Enhanced Connection Complete
          LE Direct Advertising Report
          LE PHY Update Complete
          LE Extended Advertising Report
          LE Extended Advertising Set Terminated
          LE Channel Selection Algorithm
> HCI Event: Command Complete (0x0e) plen 4                 #20 [hci0] 5.386999
      LE Set Event Mask (0x08|0x0001) ncmd 1
< HCI Command: LE Read White List S.. (0x08|0x000f) plen 0  #21 [hci0] 5.387066
> HCI Event: Command Complete (0x0e) plen 5                 #22 [hci0] 5.388919
      LE Read White List Size (0x08|0x000f) ncmd 1
< HCI Command: LE Clear White List (0x08|0x0010) plen 0     #23 [hci0] 5.388985
> HCI Event: Command Complete (0x0e) plen 4                 #24 [hci0] 5.389908
      LE Clear White List (0x08|0x0010) ncmd 1
< HCI Command: LE Read Resolving Li.. (0x08|0x002a) plen 0  #25 [hci0] 5.390033
> HCI Event: Command Complete (0x0e) plen 5                 #26 [hci0] 5.391909
      LE Read Resolving List Size (0x08|0x002a) ncmd 1
< HCI Command: LE Clear Resolving L.. (0x08|0x0029) plen 0  #27 [hci0] 5.391978
> HCI Event: Command Complete (0x0e) plen 4                 #28 [hci0] 5.393927
      LE Clear Resolving List (0x08|0x0029) ncmd 1
< HCI Command: LE Read Maximum Data.. (0x08|0x002f) plen 0  #29 [hci0] 5.394001
> HCI Event: Command Complete (0x0e) plen 12                #30 [hci0] 5.394911
      LE Read Maximum Data Length (0x08|0x002f) ncmd 1
        Max TX octets: 251
        Max TX time: 2704
        Max RX octets: 251
        Max RX time: 2704
< HCI Command: LE Read Suggested De.. (0x08|0x0023) plen 0  #31 [hci0] 5.394981
> HCI Event: Command Complete (0x0e) plen 8                 #32 [hci0] 5.396906
      LE Read Suggested Default Data Length (0x08|0x0023) ncmd 1
        TX octets: 27
        TX time: 328
< HCI Command: LE Read Number of Su.. (0x08|0x003b) plen 0  #33 [hci0] 5.396975
> HCI Event: Command Complete (0x0e) plen 5                 #34 [hci0] 5.398927
      LE Read Number of Supported Advertising Sets (0x08|0x003b) ncmd 1
        Num supported adv sets: 1
< HCI Command: Set Event Mask Page 2 (0x03|0x0063) plen 8   #35 [hci0] 5.399064
        Mask: 0x0000000000800000
          Authenticated Payload Timeout Expired
> HCI Event: Command Complete (0x0e) plen 4                 #36 [hci0] 5.401913
      Set Event Mask Page 2 (0x03|0x0063) ncmd 1
< HCI Command: LE Write Suggested D.. (0x08|0x0024) plen 4  #37 [hci0] 5.401982
        TX octets: 251
        TX time: 2704
> HCI Event: Command Complete (0x0e) plen 4                 #38 [hci0] 5.402905
      LE Write Suggested Default Data Length (0x08|0x0024) ncmd 1
< HCI Command: LE Set Default PHY (0x08|0x0031) plen 3      #39 [hci0] 5.402974
        All PHYs preference: 0x00
        TX PHYs preference: 0x01
          LE 1M
        RX PHYs preference: 0x01
          LE 1M
> HCI Event: Command Complete (0x0e) plen 4                 #40 [hci0] 5.404910
      LE Set Default PHY (0x08|0x0031) ncmd 1
= Index Info: 00:00:00:00:00:00 (Nordic Semiconductor ASA)      [hci0] 5.405006
< HCI Command: LE Set Extended Adv.. (0x08|0x0036) plen 25  #41 [hci0] 5.405204
        Handle: 0x00
        Properties: 0x0010
          Use legacy advertising PDUs: ADV_NONCONN_IND
        Min advertising interval: 1280.000 msec (0x0800)
        Max advertising interval: 1280.000 msec (0x0800)
        Channel map: 37, 38, 39 (0x07)
        Own address type: Random (0x01)
        Peer address type: Public (0x00)
        Peer address: 00:00:00:00:00:00 (OUI 00-00-00)
        Filter policy: Allow Scan Request from Any, Allow Connect Request from Any (0x00)
        TX power: 127 dbm (0x7f)
        Primary PHY: LE 1M (0x01)
        Secondary max skip: 0x00
        Secondary PHY: LE 1M (0x01)
        SID: 0x00
        Scan request notifications: Disabled (0x00)
> HCI Event: Command Complete (0x0e) plen 5                 #42 [hci0] 5.406927
      LE Set Extended Advertising Parameters (0x08|0x0036) ncmd 1
        TX power (selected): 0 dbm (0x00)
< HCI Command: LE Set Advertising S.. (0x08|0x0035) plen 7  #43 [hci0] 5.407011
        Advertising handle: 0x00
        Advertising random address: 24:10:1D:26:A6:C0 (OUI 24-10-1D)
> HCI Event: Command Complete (0x0e) plen 4                 #44 [hci0] 5.407909
      LE Set Advertising Set Random Address (0x08|0x0035) ncmd 1
< HCI Command: LE Set Extended Sca.. (0x08|0x0038) plen 35  #45 [hci0] 5.407977
        Handle: 0x00
        Operation: Complete scan response data (0x03)
        Fragment preference: Minimize fragmentation (0x01)
        Data length: 0x0d
        Name (short): raspberryp
> HCI Event: Command Complete (0x0e) plen 4                 #46 [hci0] 5.409911
      LE Set Extended Scan Response Data (0x08|0x0038) ncmd 1
        Status: Invalid HCI Command Parameters (0x12)
< HCI Command: LE Set Extended Adv.. (0x08|0x0037) plen 35  #47 [hci0] 5.409996
        Handle: 0x00
        Operation: Complete extended advertising data (0x03)
        Data length: 0x06
        Flags: 0x04
        TX power: 0 dBm
@ MGMT Event: New Settings (0x0006) plen 4             {0x0001} [hci0] 5.410056
        Current settings: 0x00008a11
          Powered
          Bondable
          Low Energy
          Secure Connections
          Static Address
@ MGMT Event: New Settings (0x0006) plen 4             {0x0002} [hci0] 5.410056
          Powered
          Bondable
          Low Energy
          Secure Connections
          Static Address
@ RAW Close: hciconfig                                        {0x0003} 5.410926
> HCI Event: Command Complete (0x0e) plen 4                 #48 [hci0] 5.411952
      LE Set Extended Advertising Data (0x08|0x0037) ncmd 1
Setting extended scan parameters and enabling it performs a proper Coded PHY scan and following via following command I can succesfully connect the Coded PHY advertising board:
hcitool cmd 0x08 0x0043 0x00 0x01 0x01 0x04 0xBC 0x5C 0xED 0xFA 0xC3 0x04 0x0000 0x0001 0x0000 0x0001 0x0006 0x0000 0x18 0x00 0x00 0x00 0x80 0x0C 0x00 0x00 0x00 0x0047
Output of the command and disconnect:
< HCI Command: LE Extended Creat.. (0x08|0x0043) plen 26  #51 [hci0] 159.726999
        Filter policy: White list is not used (0x00)
        Peer address type: Random (0x01)
        Peer address: C3:FA:ED:5C:BC:04 (Static)
        Initiating PHYs: 0x04
        Entry 0: LE Coded
          Scan interval: 160.000 msec (0x0100)
          Scan window: 160.000 msec (0x0100)
          Min connection interval: 7.50 msec (0x0006)
          Max connection interval: 30.00 msec (0x0018)
          Connection latency: 0 (0x0000)
          Supervision timeout: 32000 msec (0x0c80)
          Min connection length: 0.000 msec (0x0000)
          Max connection length: 11360.000 msec (0x4700)
> HCI Event: Command Status (0x0f) plen 4                 #52 [hci0] 159.728566
      LE Extended Create Connection (0x08|0x0043) ncmd 1
@ RAW Close: hcitool                                 {0x0003} [hci0] 159.729179
> HCI Event: LE Meta Event (0x3e) plen 31                 #53 [hci0] 159.851569
      LE Enhanced Connection Complete (0x0a)
        Handle: 0
        Role: Master (0x00)
        Local resolvable private address: 00:00:00:00:00:00 (Non-Resolvable)
        Peer resolvable private address: 00:00:00:00:00:00 (Non-Resolvable)
        Connection interval: 30.00 msec (0x0018)
        Master clock accuracy: 0x00
@ MGMT Event: Device Connected (0x000b) plen 13      {0x0001} [hci0] 159.851662
        LE Address: C3:FA:ED:5C:BC:04 (Static)
        Flags: 0x00000000
        Data length: 0
@ MGMT Event: Device Connected (0x000b) plen 13      {0x0002} [hci0] 159.851662
        Flags: 0x00000000
        Data length: 0
< HCI Command: LE Read Remote Use.. (0x08|0x0016) plen 2  #54 [hci0] 159.851942
        Handle: 0
> HCI Event: LE Meta Event (0x3e) plen 4                  #55 [hci0] 159.852576
      LE Channel Selection Algorithm (0x14)
        Handle: 0
        Algorithm: #2 (0x01)
> HCI Event: Command Status (0x0f) plen 4                 #56 [hci0] 159.854577
      LE Read Remote Used Features (0x08|0x0016) ncmd 1
> HCI Event: LE Meta Event (0x3e) plen 12                 #57 [hci0] 159.915586
      LE Read Remote Used Features (0x04)
        Handle: 0
        Features: 0x25 0x41 0x00 0x00 0x00 0x00 0x00 0x00
          LE Encryption
          LE 2M PHY
= bluetoothd: No cache for C3:FA:ED:5C:BC:04                         159.918535
< ACL Data TX: Handle 0 flags 0x00 dlen 7                 #58 [hci0] 159.916965
      ATT: Exchange MTU Request (0x02) len 2
        Client RX MTU: 517
> HCI Event: Number of Completed Packets (0x13) plen 5    #59 [hci0] 159.975580
        Num handles: 1
        Handle: 0
        Count: 1
< HCI Command: Disconnect (0x01|0x0006) plen 3            #60 [hci0] 192.021591
        Handle: 0
        Reason: Remote User Terminated Connection (0x13)
> HCI Event: Command Status (0x0f) plen 4                 #61 [hci0] 192.022492
      Disconnect (0x01|0x0006) ncmd 1
> HCI Event: Disconnect Complete (0x05) plen 4            #62 [hci0] 192.073487
        Handle: 0
        Reason: Connection Terminated By Local Host (0x16)
@ MGMT Event: Device Disconnected (0x000c) plen 8    {0x0001} [hci0] 192.073540
        Reason: Connection terminated by local host (0x02)
@ MGMT Event: Device Disconnected (0x000c) plen 8    {0x0002} [hci0] 192.073540
The time that pass between connection and disconnect event is approximately 40 seconds but not exact every time.
My connection parameters which passed to controller via host is exactly fits the peripheral's settings.
Any help would be appreciated, thanks in advance.
