nRF5340: QSPI + display?
Dear Nordic,
I am considering to make a board that includes an nRF5340 + display. I am looking at a display that supports QSPI and I was wondering if the nRF5340 QSPI can be used for this purpose. The datasheets says the following: "The QSPI peripheral provides support for communicating with an external flash memory device using SPI" (https://infocenter.nordicsemi.com/index.jsp?topic=%2Fps_nrf5340%2Fqspi.html)
So can the QSPI also be used for a connection to a display
Many Thanks,
Knut
    What display model do you have?  QSPI bus is commonly used to communicate with flash and PSRAM memories, displays are usually connected via SPI or 8-bit parallel bus. To work with SPI display, take a look at SPIM peripheral. There are drivers in nRF SDK for displays based on ST7735 and ILI9341 controllers.
    Edit: if you mean FT81x-based display, unfortunately it won't work. QSPI engine in nRF5340 has a hardcoded set of commands that is incompatible with FT81x.
  • Hi again,
    I am looking at using an LCD+touch display with an ST7796SI driver IC. I suppose this means that I would have to write a driver myself...
    In regards to your comment " There are drivers in nRF SDK for displays based on ST7735 and ILI9341 controllers" - are these drivers also available in nRF Connect SDK, which is needed for the nRF5340 chip I am using on the board I have designed?
    There is extensive documentation on the nRF SDK, but I am not able to find the same comprehensive documentation on the nRF Connect SDK.
    Many Thanks,
    Knut
    I didn't look deeeply but it seems command set is almost the same as for ILI9341 - most of work already done.
    Even if not - there are only two backend interfaces used by driver, GPIO and SPI master.
  • Hi ,
    I came across your post regarding the use of a QSPI display with the nRF5340, and I was curious about your final outcome. Did you eventually manage to get the QSPI display working, or did you switch to another solution?
    I'm currently working on a similar project and would appreciate any insights you could share.
    Thanks in advance!
  • Hi TomH,
    It's been some years since this project was active, so I am sorry I do not have any update. Some experimentation was done by my colleague, but I do not have any info about the results here.
    Best Regards,
