Once paired in IOS, no pairing from Android.
Hello
I use nrf52832 and SDK v17.
And I'm using NUS (UART) service and peer manager. So far, I've been testing with an Android phone and connected it with an iPhone for several tests. I've successfully connected to the iPhone, and I've checked its operation. After that, however, the connection has failed on Android.
I used the peer manager for the Bluetooth disconnect function. Removing the peer manager code will pairing but the Bluetooth disconnect function will fail.
Is this problem caused by peer manager? I can't upload the entire code, so I'll just post the part about the peer manager.
Please let me know if you need anything else.
Thank you!
main.c
#define LESC_DEBUG_MODE                 0                                           /**< Set to 1 to use LESC debug keys, allows you to use a sniffer to inspect traffic. */
#define SEC_PARAM_BOND                  1                                           /**< Perform bonding. */
#define SEC_PARAM_MITM                  1                                           /**< Man In The Middle protection required (applicable when display module is detected). */
#define SEC_PARAM_LESC                  0                                           /**< LE Secure Connections enabled. */
#define SEC_PARAM_KEYPRESS              0                                           /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES       BLE_GAP_IO_CAPS_DISPLAY_ONLY                /**< Display I/O capabilities. */
#define SEC_PARAM_OOB                   0                                           /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE          7                                           /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE          16                                          /**< Maximum encryption key size. */
#define PASSKEY_TXT                     "Passkey:"                                  //< Message to be displayed together with the pass-key.
#define PASSKEY_TXT_LENGTH              8                                           //< Length of message to be displayed together with the pass-key.
#define PASSKEY_LENGTH                  6                                           //< Length of pass-key received by the stack for display.
static pm_peer_id_t m_peer_to_be_deleted = PM_PEER_ID_INVALID;
    uint32_t err_code;
    pm_handler_secure_on_connection(p_ble_evt);
        case BLE_GAP_EVT_DISCONNECTED: //when disconnected
            bool erase_bonds = false;
            NRF_LOG_INFO("Disconnected");
            // Check if the last connected peer had not used MITM, if so, delete its bond information.
            if (m_peer_to_be_deleted != PM_PEER_ID_INVALID)
                err_code = pm_peer_delete(m_peer_to_be_deleted);
                NRF_LOG_DEBUG("Collector's bond deleted");
            //advertising_start(erase_bonds); //auto pairing test
        } break;
        case BLE_GAP_EVT_CONNECTED: //when connected pairing
            NRF_LOG_INFO("Connected");
        } break;
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
        case BLE_GAP_EVT_SEC_PARAMS_REQUEST: //Edit
            NRF_LOG_DEBUG("BLE_GAP_EVT_SEC_PARAMS_REQUEST");
	case BLE_GAP_EVT_PASSKEY_DISPLAY: //add
            char passkey[PASSKEY_LENGTH + 1];
            memcpy(passkey, p_ble_evt->evt.gap_evt.params.passkey_display.passkey, PASSKEY_LENGTH);
            passkey[PASSKEY_LENGTH] = 0;
            NRF_LOG_INFO("Passkey: %s", nrf_log_push(passkey));
        } break;
        case BLE_GAP_EVT_LESC_DHKEY_REQUEST: //add
            NRF_LOG_INFO("BLE_GAP_EVT_LESC_DHKEY_REQUEST");
         case BLE_GAP_EVT_AUTH_STATUS: //add
             NRF_LOG_INFO("BLE_GAP_EVT_AUTH_STATUS: status=0x%x bond=0x%x lv4: %d kdist_own:0x%x kdist_peer:0x%x",
                          p_ble_evt->evt.gap_evt.params.auth_status.auth_status,
                          p_ble_evt->evt.gap_evt.params.auth_status.bonded,
                          p_ble_evt->evt.gap_evt.params.auth_status.sm1_levels.lv4,
                          *((uint8_t *)&p_ble_evt->evt.gap_evt.params.auth_status.kdist_own),
                          *((uint8_t *)&p_ble_evt->evt.gap_evt.params.auth_status.kdist_peer));
            // No implementation needed.
/**@brief Function for handling Peer Manager events.
 * @param[in] p_evt  Peer Manager event.
static void pm_evt_handler(pm_evt_t const * p_evt) //add
    ret_code_t err_code;
    pm_handler_on_pm_evt(p_evt);
    pm_handler_disconnect_on_sec_failure(p_evt);
    pm_handler_flash_clean(p_evt);
    switch (p_evt->evt_id)
        case PM_EVT_CONN_SEC_SUCCEEDED:
            pm_conn_sec_status_t conn_sec_status;
            // Check if the link is authenticated (meaning at least MITM).
            err_code = pm_conn_sec_status_get(p_evt->conn_handle, &conn_sec_status);
            if (conn_sec_status.mitm_protected)
                NRF_LOG_INFO("Link secured. Role: %d. conn_handle: %d, Procedure: %d",
                             ble_conn_state_role(p_evt->conn_handle),
                             p_evt->conn_handle,
                             p_evt->params.conn_sec_succeeded.procedure);
                // The peer did not use MITM, disconnect.
                NRF_LOG_INFO("Collector did not use MITM, disconnecting");
                err_code = pm_peer_id_get(m_conn_handle, &m_peer_to_be_deleted);
                err_code = sd_ble_gap_disconnect(m_conn_handle,
        } break;
        case PM_EVT_CONN_SEC_FAILED:
            advertising_start(false);
/**@brief Function for the Peer Manager initialization.
static void peer_manager_init(void)
    err_code = pm_init();
    sec_param.bond           = SEC_PARAM_BOND;
    sec_param.mitm           = SEC_PARAM_MITM;
    sec_param.lesc           = SEC_PARAM_LESC;
    sec_param.keypress       = SEC_PARAM_KEYPRESS;
    sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
    sec_param.oob            = SEC_PARAM_OOB;
    sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
    sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
    sec_param.kdist_own.enc  = 1;
    sec_param.kdist_own.id   = 1;
    sec_param.kdist_peer.enc = 1;
    sec_param.kdist_peer.id  = 1;
/**@brief Clear bond information from persistent storage.
static void delete_bonds(void)
    NRF_LOG_INFO("Erase bonds!");
    err_code = pm_peers_delete();
nrf connect App
nRF Connect, 2020-11-03
Smart_Helmet (E4:92:95:67:09:7A)
V	10:45:05.102	Connecting to E4:92:95:67:09:7A...
D	10:45:05.102	gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferred PHY = LE 1M)
D	10:45:05.186	[Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED
D	10:45:05.197	[Callback] Connection state changed with status: 0 and new state: CONNECTED (2)
I	10:45:05.197	Connected to E4:92:95:67:09:7A
V	10:45:05.209	Discovering services...
D	10:45:05.209	gatt.discoverServices()
D	10:45:05.274	[Broadcast] Action received: android.bluetooth.device.action.BOND_STATE_CHANGED, bond state changed to: BOND_BONDING (11)
D	10:45:05.311	[Broadcast] Action received: android.bluetooth.device.action.PAIRING_REQUEST, pairing variant: PAIRING_VARIANT_CONSENT (3)
I	10:45:05.927	Connection parameters updated (interval: 7.5ms, latency: 0, timeout: 5000ms)
D	10:45:05.988	[Callback] Services discovered with status: 0
I	10:45:05.988	Services discovered
V	10:45:05.994	Generic Access (0x1800)
- Device Name [R W] (0x2A00)
- Appearance [R] (0x2A01)
- Peripheral Preferred Connection Parameters [R] (0x2A04)
- Central Address Resolution [R] (0x2AA6)
Generic Attribute (0x1801)
Nordic UART Service (6e400001-b5a3-f393-e0a9-e50e24dcca9e)
- RX Characteristic [W WNR] (6e400002-b5a3-f393-e0a9-e50e24dcca9e)
- TX Characteristic [N] (6e400003-b5a3-f393-e0a9-e50e24dcca9e)
   Client Characteristic Configuration (0x2902)
D	10:45:05.994	gatt.setCharacteristicNotification(6e400003-b5a3-f393-e0a9-e50e24dcca9e, true)
I	10:45:06.086	Connection parameters updated (interval: 43.75ms, latency: 0, timeout: 5000ms)
I	10:45:06.353	Notification received from 6e400003-b5a3-f393-e0a9-e50e24dcca9e, value: (0x) 6F-76-65-72-20-37-35-00
ction.ACL_DISCONNECTED
After I delete the bond from the iPhone, it doesn't connect to the iPhone. Is there a way to reset the bond?
Thank you.
