FDS, UART, BLE can not work together
Hello all,
I am using the example \ examples \ ble_peripheral \ ble_app_uart
Right now I'm having a problem that I cannot use FDS. My fds_event_handler I never see case "FDS_EVT_WRITE".
It my function main()
    ret_code_t err_code;
    bool erase_bonds;
    uart_init();
    log_init();
    CLOCK_INIT();
    timers_init();
    GPIO_INIT();
    SPI_INIT();
    printf("fdsT_find_record New Record\r\n");
    ret_code_t ret = fdsT_find_record();
    if(ret == FDS_ERR_NOT_FOUND)		// No record, so create a new one
            NRF_LOG_INFO("Creating New Record\r\n");
            // Create a new record
            ret = fdsT_write();
            if (ret != FDS_SUCCESS)
               NRF_LOG_INFO("Write fail!\r\n");
            fdsT_read();
            //NRF_LOG_INFO("Variable 5: %d\r\n", saveData2.var5);
    NRF_LOG_INFO("\r\nDelete Previous Record:\r\n");
    fdsT_find_and_delete();
    NRF_LOG_INFO("Writing New Record:\r\n");
    ret = fdsT_write();
    NRF_LOG_INFO("\r\nReading New Record:\r\n");
    printf("\r\nReading New Record:\r\n");
    fdsT_read();
    NRF_LOG_INFO("Program Start!\r\n");
    power_management_init();
    ble_stack_init();
    gap_params_init();
    gatt_init();
    services_init();
    advertising_init();
    conn_params_init();
    peer_manager_init();
//    nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;
//    spi_config.ss_pin   = SPI_SS_PIN;
//    spi_config.miso_pin = SPI_MISO_PIN;
//    spi_config.mosi_pin = SPI_MOSI_PIN;
//    spi_config.sck_pin  = SPI_SCK_PIN;
//    APP_ERROR_CHECK(nrf_drv_spi_init(&spi, &spi_config, spi_event_handler, NULL));
//    if (pdPASS != xTaskCreate(spi_thread, "SPI", TASK_STACK, NULL, 1, &m_spi_thread))
//      APP_ERROR_HANDLER(NRF_ERROR_NO_MEM);
    if (pdPASS != xTaskCreate(shiftregisterTaskmain, "shiftregisterTaskmain", TASK_STACK, NULL, 5, &m_shiftregister))
    if (pdPASS != xTaskCreate(bzctrTtaskmain, "bz_ctrl_taskmain", TASK_STACK, NULL, 4, &m_bzctrlTask))
    if (pdPASS != xTaskCreate(sendinformationTaskmain, "sendinformation_taskmain", TASK_STACK, NULL, 3, &m_sendinformation))
    if (pdPASS != xTaskCreate(ledctrlTaskstart, "ledctrlTaskstart", TASK_STACK, NULL, 2, &m_ledctrltaskstart))
    if(pdPASS != xTaskCreate(usermainloop, "MAIN", TASK_STACK, NULL, 1, &m_usermainloop)) {
    // Activate deep sleep mode.
    SCB->SCR |= SCB_SCR_SLEEPDEEP_Msk;
    while(1){
      nrf_delay_ms(10000);
    printf("SPI example starter\r\n");
    // Start execution.
    nrf_delay_ms(1000);
    erase_bonds = true;
    nrf_sdh_freertos_init(advertising_start, &erase_bonds);
    vTaskStartScheduler();
    // Enter main loop.
    for (;;)
        idle_state_handle();
        APP_ERROR_HANDLER(NRF_ERROR_FORBIDDEN);
It function fds test write flash
/////////////////////////TEST//////////////////////
static float					var1[7] = {5.00, 5.10, 5.20, 5.30, 5.40, 5.50, 5.60};
static float					var2 = 10.00;
static float					var3 = 5.00;
static uint8_t					var4[7] = {17,07,06,05,04,03,02};
static uint8_t					var5 = 99;
struct
    float     	var1[7];
    float     	var2;
    float       var3;
    uint8_t     var4[7];
    uint8_t	var5;
} saveData;
struct
    float     	var1[7];
    float     	var2;
    float	var3;
    uint8_t     var4[7];
    uint8_t	var5;
} saveData2;
static uint16_t fileID = 0x1000;
static uint16_t recordKey = 0x2000;
static fds_record_t        record;
static fds_record_desc_t   record_desc;
static fds_flash_record_t  flash_record;
static fds_find_token_t    ftok;
ret_code_t fdsT_write(void)
      saveData2.var5 = 0;
      uint8_t x = 0;
      for(x = 0; x<7; x++)
          saveData.var1[x] = var1[x];
          saveData.var4[x] = var4[x];
      saveData.var2 = var2;
      saveData.var3 = var3;
      saveData.var5 = var5;
      record.data.p_data         = &saveData;
      record.data.length_words   = sizeof(saveData)/4;
      record.file_id             = fileID;
      record.key                 = recordKey;
      NRF_LOG_INFO("fds_record_write:\r\n");
      ret_code_t ret = fds_record_write(&record_desc, &record);
         return ret;
      NRF_LOG_INFO("1111111:\r\n");
      uint32_t evt_id;
      while (write_flag==0){
        sd_evt_get(&evt_id);
        //printf("fds_record_write evt_id: %d\r\n",evt_id);
      NRF_LOG_INFO("Writing Record ID = %d \r\n",record_desc.record_id);
      return NRF_SUCCESS;
ret_code_t fdsT_update(void)
      ret_code_t ret = fds_record_update(&record_desc, &record);
         return ret;
      NRF_LOG_INFO("Updating Record ID = %d \r\n",record_desc.record_id);
      return NRF_SUCCESS;
ret_code_t fdsT_read(void)
        fds_find_token_t    ftok ={0};//Important, make sure you zero init the ftok token
        uint8_t *data;
        uint32_t err_code;
        NRF_LOG_INFO("Start Reading... \r\n");
        printf("Start Reading... \r\n");
        // Loop until all records with the given key and file ID have been found.
        while (fds_record_find(fileID, recordKey, &record_desc, &ftok) == FDS_SUCCESS)
              err_code = fds_record_open(&record_desc, &flash_record);
              if ( err_code != FDS_SUCCESS)
                      return err_code;
              NRF_LOG_INFO("Found Record ID = %d\r\n",record_desc.record_id);
              data = (uint8_t *) flash_record.p_data;
              memcpy(saveData2.var1,data,28);
              memcpy(&saveData2.var2,data+28,4);
              memcpy(&saveData2.var3,data+32,4);
              memcpy(saveData2.var4,data+36,7);
              memcpy(&saveData2.var5,data+43,1);
              // Access the record through the flash_record structure.
              // Close the record when done.
              err_code = fds_record_close(&record_desc);
              if (err_code != FDS_SUCCESS)
                      return err_code;
        printf("Variable 5: %d\r\n", saveData2.var5);
        return NRF_SUCCESS;
ret_code_t fdsT_find_and_delete (void)
      ftok.page=0;
      ftok.p_addr=NULL;
      // Loop and find records with same ID and rec key and mark them as deleted.
              fds_record_delete(&record_desc);
              NRF_LOG_INFO("Deleted record ID: %d \r\n",record_desc.record_id);
      // call the garbage collector to empty them, don't need to do this all the time, this is just for demonstration
      ret_code_t ret = fds_gc();
              return ret;
      return NRF_SUCCESS;
ret_code_t fdsT_find_record (void)
    bool recordFound = false;
    ftok.page=0;
    ftok.p_addr=NULL;
            NRF_LOG_INFO("Found Record : ID %d \r\n",record_desc.record_id);
            recordFound = true;
    if(!recordFound)
            NRF_LOG_INFO("No Record Found!\r\n");
            return FDS_ERR_NOT_FOUND;
    return NRF_SUCCESS;
#endif // NRF_MODULE_ENABLED(PEER_MANAGER)
Do you have any suggestions for me, thanks
Parents Reply
    If you have not done so already, please start a new thread for the problem you see. Although it does look the same on the surface, it may be other details in your code so that the issue appears for another reason. When issues appears in a customized project (not the unchanged example straight from the SDK) then the issue is usually in the custom code.
    Terje
