nrf calendar
#include "nrf_calendar.h"
#include "nrf.h"
static struct tm time_struct, m_tm_return_time;
static time_t m_time, m_last_calibrate_time = 0;
static float m_calibrate_factor = 0.0f;
static uint32_t m_rtc_increment = 60;
static void (*cal_event_callback)(void) = 0;
void nrf_cal_init(void)
// Select the 32 kHz crystal and start the 32 kHz clock
NRF_CLOCK->LFCLKSRC = CLOCK_LFCLKSRC_SRC_Xtal << CLOCK_LFCLKSRC_SRC_Pos;
NRF_CLOCK->TASKS_LFCLKSTART = 1;
while(NRF_CLOCK->EVENTS_LFCLKSTARTED == 0);
// Configure the RTC for 1 minute wakeup (default)
CAL_RTC->PRESCALER = 0xFFF;
CAL_RTC->EVTENSET = RTC_EVTENSET_COMPARE0_Msk;
CAL_RTC->INTENSET = RTC_INTENSET_COMPARE0_Msk;
CAL_RTC->CC[0] = m_rtc_increment * 8;
CAL_RTC->TASKS_START = 1;
NVIC_SetPriority(CAL_RTC_IRQn, CAL_RTC_IRQ_Priority);
NVIC_EnableIRQ(CAL_RTC_IRQn);
void nrf_cal_set_callback(void (*callback)(void), uint32_t interval)
// Set the calendar callback, and set the callback interval in seconds
cal_event_callback = callback;
m_rtc_increment = interval;
m_time += CAL_RTC->COUNTER / 4;
CAL_RTC->TASKS_CLEAR = 1;
CAL_RTC->CC[0] = interval * 4;
void nrf_cal_set_time(uint32_t year, uint32_t month, uint32_t day, uint32_t hour, uint32_t minute, uint32_t second)
static time_t uncal_difftime, difftime, newtime;
time_struct.tm_year = year - 1900;
time_struct.tm_mon = month;
time_struct.tm_mday = day;
time_struct.tm_hour = hour;
time_struct.tm_min = minute;
time_struct.tm_sec = second;
newtime = mktime(&time_struct);
// Calculate the calibration offset
if(m_last_calibrate_time != 0)
difftime = newtime - m_last_calibrate_time;
uncal_difftime = m_time - m_last_calibrate_time;
m_calibrate_factor = (float)difftime / (float)uncal_difftime;
// Assign the new time to the local time variables
m_time = m_last_calibrate_time = newtime;
struct tm *nrf_cal_get_time(void)
time_t return_time;
return_time = m_time + CAL_RTC->COUNTER / 8;
m_tm_return_time = *localtime(&return_time);
return &m_tm_return_time;
struct tm *nrf_cal_get_time_calibrated(void)
time_t uncalibrated_time, calibrated_time;
if(m_calibrate_factor != 0.0f)
uncalibrated_time = m_time + CAL_RTC->COUNTER / 8;
calibrated_time = m_last_calibrate_time + (time_t)((float)(uncalibrated_time - m_last_calibrate_time) * m_calibrate_factor + 0.5f);
m_tm_return_time = *localtime(&calibrated_time);
else return nrf_cal_get_time();
void CAL_RTC_IRQHandler(void)
if(CAL_RTC->EVENTS_COMPARE[0])
CAL_RTC->EVENTS_COMPARE[0] = 0;
m_time += m_rtc_increment;
if(cal_event_callback) cal_event_callback();
in here which function should i change to get milliseconds??
