Hi all,
We have designed a PCB where we use BMD-350 ( which is based on nrf52832 ) , HX711 and the accelerometer ( MMA8452Q ) as primary components. The device is supposed to stay in a deep sleep mode and wake up only when the accelerometer detects an orientation change of more than a set threshold. It is supposed to wake up, transmit hx711 data through the BMD-350 and go back to sleep. Though we have tested the code with sd_app_event_wait () and it works fine, we wanted to test the deepest sleep mode i.e. System off mode of BLE. We have used the nrf_gpio_config_sense_input () and then used the command sd_power_system off. But after entering the system off mode, the BLE doesn't wake up from the accelerometer interrupt.
Here is the code snippet of int main:
// Enable DC DC Converter for lower power usage
nrf_power_dcdcen_set(true);
while (1)
switch (system_state)
case SYSTEM_INIT:
// System Init tings
timers_init ();
leds_init ();
// Internal Peripheral Power Up
// SAADC
saadc_init ();
saadc_sampling_event_init ();
saadc_sampling_event_enable ();
// User Timer
start_timer ();
// I2C
twi_init ();
enableAcclMOtionDetection ();
// External Device Power Up
ledInit ();
nrf_gpio_pin_write (LED_BLUE, RESET);
system_state = SYSTEM_RUNNING;
case SYSTEM_RUNNING:
watch_accl ();
sd_app_evt_wait ();
if (system_sleep_counter) break;
case SYSTEM_BROADCAST_START:
// BLE Stack Enable
ble_stack_init ();
HX711_power_up ();
HX711_begin (128);
HX711_set_offset (HX711_VALUE_OFFSET);
advertising_activeate ();
system_sleep_counter = SYSTEM_DATA_SEND_DURATION;
system_state = SYSTEM_BROADCAST;
case SYSTEM_BROADCAST:
adv_active_machine ();
case SYSTEM_DEINIT:
// External Device Power Down
HX711_power_down ();
nrf_gpio_pin_write (LED_BLUE, SET);
// Internal Peripheral Power Down
timers_deinit ();
timerStop ();
twi_disable ();
saadc_deinit ();
// BLE Power Down
advertising_stop ();
nrf_gpio_cfg_sense_input(ACCL_INT_1_PIN, NRF_GPIO_PIN_PULLUP, NRF_GPIO_PIN_SENSE_LOW);
sd_power_system_off ();
system_state = SYSTEM_INIT;
I have also attached the accelerometer c file ( accl.c ) for your reference. Can anyone help me in identifying why is the system not waking up from the accelerometer-generated interrupt in this configuration ?
#include "i2c_control.h"
#include "nrf_drv_gpiote.h"
#include "sdk_macros.h"
#include "boards.h"
#include "common_decl.h"
#include "timer_user.h"
extern uint32_t system_sleep_counter; /**< System sleep counter used in main for power managment */
// Accl related flags
uint8_t accl_int1_flag = RESET; /**< Accl intterupt flag */
uint8_t accl_read_flag = RESET; /**< Flag to tell it's time to read Accl */
/**@brief Accelerometer Interupt handler.
* @details This gets called when accelerometer raises hardware interrupt
* @param pin Which pin raised interrupr
* @param action Polarity of the Pin
void acclIntHandler (nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
// Clear interrupt flags
NRF_GPIOTE->EVENTS_PORT = RESET;
NRF_GPIOTE->EVENTS_IN[0] = RESET;
NRF_GPIOTE->EVENTS_IN[1] = RESET;
NRF_GPIOTE->EVENTS_IN[2] = RESET;
NRF_GPIOTE->EVENTS_IN[3] = RESET;
accl_int1_flag = SET;
return;
/**@brief Chec if motion happening in Accelerometer
* @details Reads Accelerometer and gets the flags in Accelerometer
* which tells wether acceleration is crossing threhhold
* @return 1: Acceleration is crossing threhhold, 0: Acceleration not crossing threhhold
uint8_t accl_check_motion_happening (void)
uint8_t sub_addr_data[2];
sub_addr_data[0] = 0x16;
/*ret_code_t twi_write_read(uint8_t addr, uint8_t subaddr[],
uint8_t subaddr_len, uint8_t data_read[],
uint8_t data_len)
twi_write_read (ACCL_SLAVE_ADDR, &sub_addr_data[0], 1, &sub_addr_data[1], 1);
return (sub_addr_data[1] & 0x80);
/**@brief Watch Accelerometer
* @details Controls the main program by using *system_sleep_counter*
* according to status of *accl_int1_flag* *accl_read_flag* and *system_sleep_counter*
void watch_accl (void)
When system_sleep_counter is 0, and interrupt is rasied by accelerometer
system_sleep_counter will be set to SYSTEM_UP_DURATION which will wake up
the system. If system_sleep_counter goes to 0 the system goes to sleep
if (accl_int1_flag && (!system_sleep_counter))
system_sleep_counter = SYSTEM_UP_DURATION;
When is wakeup mode system_sleep_counter will be non zero.
In wakeup mode at every ACCL_READ_FREQ the accelerometer's register will be read
and if motion is going on, the system_sleep_counter will be set to SYSTEM_UP_DURATION
if ((accl_read_flag) && (accl_check_motion_happening()))
return;
/**@brief Enable external interupt used by Accelerometer
* @details Enable external interupt used by Accelerometer and the callback function
* @return 32-bit success/error code
uint32_t enableAcclExtInt (void)
uint32_t err_code;
// Configure the device INT1 Pin Input as Interrupt
nrf_drv_gpiote_init ();
nrf_drv_gpiote_in_config_t config = GPIOTE_RAW_CONFIG_IN_SENSE_HITOLO(false);
config.pull = NRF_GPIO_PIN_PULLUP;
config.skip_gpio_setup = false;
err_code = nrf_drv_gpiote_in_init(ACCL_INT_1_PIN, &config, acclIntHandler);
VERIFY_SUCCESS(err_code);
nrf_drv_gpiote_in_event_enable (ACCL_INT_1_PIN, true);
return err_code;
/**@brief Enable motion detection in Accelerometer
* @details Enable motion detection and configure Accelerometer for power saving
* by wrting into it's registers over I2C.
uint32_t enableAcclMOtionDetection (void)
uint8_t send_array [3];
uint32_t err_code;
// Put Module in Standby mode do the settings
// And set Data Rate and auto_sleep to 12.5 Hz
// Auto Wakeup Sleep frrequency to 12.5 Hz
// Normal mode for LNOis and Fast Read
send_array[0] = 0x2A; // Register adress CTRL_REG1
send_array[1] = 0xF8; // Data to be written in the register
err_code = twi_write (ACCL_SLAVE_ADDR, send_array, 2);
// Auto Sleep counter
send_array[0] = 0x29; // Register adress FF_MT_CFG
send_array[1] = 0x00; // Data to be written in the register
// Setting to detect motion, X and Y axis will be considered
// only X and Y is considered beacause Z will always be 1g
// and status registers will reset after event is over
send_array[0] = 0x15; // Register adress FF_MT_CFG
send_array[1] = 0xD8; // Data to be written in the register
// Setting to set threshhold to 1.25g
// The step count is 0.063g/ count� 1.25/0.063g = 19.4; //Round up to 20
// DBCNTM bit is a logic �1�, the debounce counter is cleared to 0
// whenever the inertial event of interest is no longer true
send_array[0] = 0x17; // Register adress FF_MT_THS
send_array[1] = 0x82; // Data to be written in the register
// Debouce counter to avoid false reading
// Set to 10 Counts
send_array[0] = 0x18; // Register adress FF_MT_COUNT
send_array[1] = 0x0A; // Data to be written in the register
// Enable Motion Interrupt Function in the System
send_array[0] = 0x2D; // Register adress CTRL_REG4
send_array[1] = 0x04; // Data to be written in the register
// Route the Motion Interrupt Function to INT1 hardware pin
send_array[0] = 0x2E; // Register adress CTRL_REG5
// Self test disabled, Reset at 0
// Sleep mode and normal mode power profile is se to Low power
// Auto sleep enabled
send_array[0] = 0x2B; // Register adress CTRL_REG2
send_array[1] = 0x1F; // Data to be written in the register
// Activate the device aftr settings are done
// And set Data Rate to 12.5 Hz
send_array[1] = 0xF9; // Data to be written in the register
err_code = enableAcclExtInt ();
return err_code;
Any help would be appreciated. Thanks !
