Blocking BLE_STACK_HANDLER_INIT
Dear Support Team,
currently I'm working on a custom board which contains the NRF51822_QFAB_A0. I installed the softdevice (not the most recent version, but a version that worked on the development board NRF51822_QFAA).
Now every time I call BLE_STACK_HANDLER_INIT(NRF_CLOCK_LFCLKSRC_RC_250_PPM_4000MS_CALIBRATION, BLE_L2CAP_MTU_DEF, ble_evt_dispatch, true);
the device hangs. What can be the reason for this? (I also tried different other clock sources.)
Thank you and best, Peer.
  • This could happen if your 16MHz crystal is not able to spin up. Try spinning it up directly to check:
    while(NRF_CLOCK->EVENTS_LFCLKSTARTED == 0)
    (turn on an LED after this code block or something)
  • Thank you! In fact the oscillator was not working well. (A soldering problem.) Thank you agin and best, Peer.
    I have a similar issue with a nRF58122 board from China (Xuntong PTR 9048-B). Not sure what to do next.
    I am using the ble_app_hrs sample code which seems to work fine on the Evaluation Kit but fails on this board. I debugged this and the code seems to get stuck. What's next?
    // Initialize the SoftDevice handler module.
    SOFTDEVICE_HANDLER_INIT(NRF_CLOCK_LFCLKSRC_XTAL_20_PPM, false);
    More info: the SoC hardware revision is QFAAC0 and I am using the 6.0.0 S110 soft device.
    I also ensured that I wait for both EVENTS_LFCLKSTARTED and EVENTS_LFCLKSTARTED to be set to 1 (BTW, maybe I am missing something but the code mentioned in the previous post starts the HF clock but tests for the LF clock?). This is the code I used:
    NRF_CLOCK->TASKS_LFCLKSTART = 1;
    while(NRF_CLOCK->EVENTS_HFCLKSTARTED == 0)
  • Hi Adi, you're right that's a typo in the code fragment I had posted, it should have been EVENTS_HFCLKSTARTED as you noticed. From looking at the picture of your board here: http://www.aliexpress.com/store/product/Module-for-iBeacon-Bluetooth-Low-Energy-Wireless-module-NRF51822-32-bit-cortex-M0-256K-flash-Freeshipping/130096_1582777326.html it doesn't look like that board comes with the low frequency crystal, so you should use NRF_CLOCK_LFCLKSRC_RC_250_PPM_4000M instead of NRF_CLOCK_LFCLKSRC_XTAL_20_PPM in the soft device init.
1 2
