Alarm Cluster problem
Someone has been working with Alarm Cluster. I tried to implement it on multiprotocol dorr lock example but it was impossible. I have been reading ZCL library revision 6 and no find how to implement it.
What I want to do is to send an alarm from EP to Alexa.
Some help?
    Unfortunately we don't have any examples that use the Alarms cluster library. I would recommend starting by looking at our API reference for the ZCL Alarms cluster,where you will find macros, attributes and cluster commands for the relevant cluster library. You can also take a look at this page about implementing a Zigbee end product with ZCL, to find what has to be declared, and how to declare and configure this.
    Marte
  • Hi Marte,
    Thanks for your answer.
    I have been reading the documentation and I tried to play with alarm cluster.
    1. I heve defined door_lock_cluster adding alarm_mask_id for enabling alarm reporting.
    zb_zcl_door_loock.h
    /** @brief Declare attribute list for DoorLock cluster
        @param attr_list - attribute list name
        @param lock_state
        @param lock_type
        @param actuator_enabled
        @param alarm_mask_id
    #define ZB_ZCL_DECLARE_DOOR_LOCK_ATTRIB_LIST(attr_list,                               \
                                                 lock_state,                              \
                                                 lock_type,                               \
                                                 alarm_mask_id,                           \
                                                 actuator_enabled)                        \
      ZB_ZCL_START_DECLARE_ATTRIB_LIST(attr_list)                                         \
      ZB_ZCL_SET_ATTR_DESC(ZB_ZCL_ATTR_DOOR_LOCK_LOCK_STATE_ID, (lock_state))             \
      ZB_ZCL_SET_ATTR_DESC(ZB_ZCL_ATTR_DOOR_LOCK_LOCK_TYPE_ID, (lock_type))               \
      ZB_ZCL_SET_ATTR_DESC(ZB_ZCL_ATTR_DOOR_LOCK_ACTUATOR_ENABLED_ID, (actuator_enabled)) \
      ZB_ZCL_SET_ATTR_DESC(ZB_ZCL_ATTR_DOOR_LOCK_ALARM_MASK_ID,(alarm_mask_id))           \
      ZB_ZCL_FINISH_DECLARE_ATTRIB_LIST
    #define ZB_SET_ATTR_DESCR_WITH_ZB_ZCL_ATTR_DOOR_LOCK_ALARM_MASK_ID(data_ptr)                 \
        ZB_ZCL_ATTR_DOOR_LOCK_ALARM_MASK_ID,                                                     \
        ZB_ZCL_ATTR_TYPE_8BIT_ENUM,                                                              \
        ZB_ZCL_ATTR_ACCESS_READ_ONLY | ZB_ZCL_ATTR_ACCESS_REPORTING | ZB_ZCL_ATTR_ACCESS_SCENE,  \
        (zb_voidp_t) data_ptr        \
    zb_zcl_door_loock_addons.h
    typedef struct
        zb_uint8_t lock_state;
        zb_uint8_t lock_type;
        zb_bool_t  actuator_enabled;
          zb_uint16_t  alarm_mask_id;
    } zb_zcl_door_lock_attrs_t;
    Main.c
    ZB_ZCL_DECLARE_DOOR_LOCK_ATTRIB_LIST(door_lock_attr_list,
                                         &m_dev_ctx.door_lock_attr.lock_state,
                                         &m_dev_ctx.door_lock_attr.lock_type,
                                         &m_dev_ctx.door_lock_attr.actuator_enabled,
        &m_dev_ctx.door_lock_attr.alarm_mask_id
    m_dev_ctx.door_lock_attr.alarm_mask_id    = ZB_ZCL_DOOR_LOCK_ALARM_MASK_DEFAULT_VALUE;
    2. I tried to add Alarm Cluster but I have no idea how must I add this. Reading this page about implementing a Zigbee end product with ZCL you can see how to add a cluster step by step but Alarm cluster seems to bee diferent from other clusters.
    3.Then if Alarm cluster is defined How must I report an Alarm? Changing m_dev_ctx.door_lock_attr.alarm_mask_id value? I tried with 0x01 (Jammed) as show below:
    UNUSED_RETURN_VALUE(zb_zcl_set_attr_val(DOOR_LOCK_ENDPOINT,
                                                    ZB_ZCL_CLUSTER_ID_DOOR_LOCK,
                                                    ZB_ZCL_CLUSTER_SERVER_ROLE,
                                                    &value,
                                                    ZB_FALSE));
    4. In other post I saw somebody recomends ZB_ZCL_ALARMS_SEND_RESET_ALARM_REQ from alarm cluster for reporting alarms but reading I have no idea to use it and how it works.
    Any suggest or feedback about my steps?
    Thanks
