How can I fix the noise from the buzzer(PWM)?
Hello
I'm using a passive buzzer controlled by PWM.
When PWM is set and run, the buzzer will continue to output small noises.
This is probably a code problem. Below is my PWM code
#include "app_pwm.h"
APP_PWM_INSTANCE(PWM1,1);                   // Create the instance "PWM1" using TIMER1  (name, NRF_DRV_TIMER_INSTANCE(num)).
void pwm_play_buzzer_duration(uint32_t duration) //button buzzer
    uint8_t i;
    uint32_t duty = 50;
    NRF_LOG_INFO("pwm_play_buzzer_duration =>");
    ready_flag = false;
    //Set the duty cycle - keep trying until PWM is ready...
    while (app_pwm_channel_duty_set(&PWM1, 0, duty) == NRF_ERROR_BUSY);
    // ... or wait for callback.
    //while (!ready_flag);
    //APP_ERROR_CHECK(app_pwm_channel_duty_set(&PWM1, 1, duty));
    nrf_delay_ms(duration);
    app_pwm_disable(&PWM1);
void pwm_ready_callback(uint32_t pwm_id)    // PWM callback function
    NRF_LOG_INFO("pwm_ready_callback =>");
    ready_flag = true;
 init, Once executed
//buzzer PWM initializing
void pwm_init(void)
    ret_code_t err_code;
    /* 1-channel PWM, 200Hz, output on DK LED pins. */
    app_pwm_config_t pwm1_cfg = APP_PWM_DEFAULT_CONFIG_1CH(1500, BUZZER_PIN); //original 5000L
    /* Switch the polarity of the second channel. */
    pwm1_cfg.pin_polarity[1] = APP_PWM_POLARITY_ACTIVE_HIGH;
    /* Initialize and enable PWM. */
    err_code = app_pwm_init(&PWM1,&pwm1_cfg,pwm_ready_callback);
    app_pwm_enable(&PWM1);
    printf("Start PWM\n");
 pwm_change_frequency,Can be executed multiple times
void pwm_change_frequency(uint16_t period_us) // ex) pwm_change_frequency(500);
    app_pwm_disable(&PWM1); //disable PWM for change PWM
    app_pwm_uninit(&PWM1); //uninitializing a PWM
    app_pwm_config_t pwm1_cfg = APP_PWM_DEFAULT_CONFIG_1CH(period_us, BUZZER_PIN); //original 5000L
static void do_play_buzzer(void)
  pwm_play_buzzer_duration(200); //buzzer play time
  //printf("Play buzzer\n");
What is the PWM noise related to?
Thank you.
    Not sure I understand your question. If you have configured PWM to output a singla to the buzzer, and started it, would you not expect it to make sound?
    In the end of pwm_play_buzzer_duration(), it looks like you tried to stop the PWM, but then it is enabled immediate afterwards inside  do_play_buzzer().
    Jørgen
