Question about customized task for GPIOTE
I was writing a program that uses the PPI with event from the timer and the task to one of the GPIO pins. The ideal scenario is that, whenever the timer fires, it will trigger the task and cause the GPIO pin to do a customized behavior (for example, turn on, then turn off, and turn on again).
I was aware that there are some default behavior (tasks) that can be used, such as GPIO_CONFIG_OUT_TASK_TOGGLE. I wonder if there is a way to define a task myself, so that I can update that pin many times in a customized way for each triggering event.
Jinyue
     You can setup the NRF_TIMERx to trigger several EVENTS_COMPARE[], which you connect using PPI channels.
    If you need a specific timer to trigger the "start" sequence, you likely have to use two timers.
    The NRF_TIMERy runs every 500 ms (then generates EVENTS_COMPARE[0], where this is shorted in NRF_TIMERy->SHORTS to restart the timer), for instance.
    You take that event NRF_TIMERy->EVENTS_COMPARE[0], and route that to start the next NRF_TIMERx.
    You could for instance setup NRF_TIMERx like this:
    1. EVENTS_COMPARE[0] happens after 100 ms
    2. EVENTS_COMPARE[1] happens after 250 ms (delta = 250-100=150ms)
    3. EVENTS_COMPARE[2] happens after 500 ms
    Each event should then have a corresponding PPI channel, with a defined GPIOTE task (set, clear or toggle)
    The last event occurring (time-wise) should be the one configured to restart the counter (see the SHORTS.COMPAREx_CLEAR mask here)
    If you need two things to occur from the same event, see PPI fork functionality.
    PPI only routes events to tasks. If you cannot generate an event, or set the functionality using one task; then it cannot be done with PPI.
    Håkon
  • Hi Håkon,
    Thanks for this update! Your proposed methodology makes sense.
    I have another question though. I wonder if there’s a way to write the gpio output pin based on different conditions.
    the idea scenario is that, I could loop through an array. If a bit is 1, I set the gpio pin. If the bit is 0, I clear the pin. Of course, this can be done using a timer interrupt, and I can check the array during the interrupt and call the pin_set or pin_clear method.
    however, if I am using PPI and GPIOTE, i find it very hard to implement this behavior. Because the connection and the task behavior is set beforehand, a given task for the gpio pin could only be SET, CLEAR, or TOGGLE. Is there a way to customize the task such that whenever a timer fired, it is linked to a gpiote task, and that task could write a 1 or 0 depending on the circumstances?
    thanks!
    jinyue
  • Another completely unrelated question. I am wondering if I can disable the timer in its own event_compare interrupt. The code would look like this:
    void timer_event_handler(nrf_timer_event_t event_type, void* p_context) {
        switch (event_type) {
            case NRF_TIMER_EVENT_COMPARE0:
                nrfx_timer_disable(&TIMER);
    Thanks!
  • I want to figure out a way to disable the timer after it has run some certain number of times...
    If you want to make this run without the involvement of the CPU, the PWM peripheral is the closest.
    PPI is not conditional, so you cannot set it up to "if this, do that, else do something_different". You need to involve the CPU if you want to do more advance patterns like this.
    Yes you can do this. that'll run TASKS_SHUTDOWN on the timer.
    increment a counter, check if it is greater or equal than the amount of times it should run; then disable (remember to reset your variable as well).
    Håkon
