I am new to the nRF5 SDK. This is my first time using nRFX SPIM so this may well be a beginner error.
I'm using SDK version 17.02 and I am using a nRF52840 module.
I based my code off the nrfx_spim example found in the peripheral examples folder.
I am building, or porting across, code for a waveshare EPD 2in9 display module. I found that all other examples found online are using nrf spim method. I wanted to use the new nrfx option.
So for my set up I have done the following:
static const nrfx_spim_t spi = NRFX_SPIM_INSTANCE(SPI_INSTANCE); /**< SPI instance. */
nrfx_spim_config_t spi_config = NRFX_SPIM_DEFAULT_CONFIG;
spi_config.frequency = NRF_SPIM_FREQ_8M;
spi_config.ss_pin = EPD_SS_PIN;
//spi_config.miso_pin = EPD_MISO_PIN;
spi_config.mosi_pin = EPD_MOSI_PIN;
spi_config.sck_pin = EPD_SCK_PIN;
spi_config.dcx_pin = EPD_DCX_PIN;
spi_config.use_hw_ss = true;
spi_config.ss_active_high = false;
APP_ERROR_CHECK(nrfx_spim_init(&spi, &spi_config, spim_event_handler, NULL));
Then to write to SPI bus within my application I have (by way of example):
uint8_t m_tx_buf[4];
memset(m_tx_buf, '\0', sizeof(m_tx_buf));
m_tx_buf[0] = 0x44; // SET_RAM_X_ADDRESS_START_END_POSITION
m_tx_buf[1] = (Xstart >> 3) & 0xFF;
m_tx_buf[2] = (Xend >> 3) & 0xFF;
spi_write(&m_tx_buf, 3);
Then for event handler I have:
static volatile bool spi_xfer_done; /**< Flag used to indicate that SPI instance completed the transfer. */
void spim_event_handler(nrfx_spim_evt_t const * p_event,
void * p_context)
spi_xfer_done = true;
And for the SPI write function, I have:
function : SPI write command
parameter:
static inline void spi_write(const void * data, size_t size)
nrfx_spim_xfer_desc_t xfer_desc = NRFX_SPIM_XFER_TRX(data, size, NULL, 0);
APP_ERROR_CHECK(nrfx_spim_xfer_dcx(&spi, &xfer_desc, 0, 1)); // first byte is always the command byte
while (!spi_xfer_done)
__WFE();
This works fine if data is a couple of bytes. However if I have something like this, it crashes the device and comes up with a fatal error message and keeps rebooting.
const uint8_t EPD_2IN9_lut_full_update[31] = {0x32, // 1st param is the WRITE_LUT_REGISTER command
0x50, 0xAA, 0x55, 0xAA, 0x11, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0xFF, 0xFF, 0x1F, 0x00,
const uint8_t EPD_2IN9_lut_partial_update[31] = {0x32, // 1st param is the WRITE_LUT_REGISTER command
0x10, 0x18, 0x18, 0x08, 0x18, 0x18,
0x08, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x13, 0x14, 0x44, 0x12,
if(Mode == EPD_2IN9_FULL)
spi_write(&EPD_2IN9_lut_full_update, sizeof(EPD_2IN9_lut_full_update));
else if(Mode == EPD_2IN9_PART)
spi_write(&EPD_2IN9_lut_partial_update, sizeof(EPD_2IN9_lut_partial_update));
else {
NRF_LOG_DEBUG("error, the Mode is EPD_2IN9_FULL or EPD_2IN9_PART");
NRF_LOG_FLUSH();
I don't understand why. So all comment appreciated.
For my workaround, which mostly works (as in, I can run a simple demo), I had to implement the following:
parameter:
//while (!spi_xfer_done)
//__WFE();
nrf_delay_ms(1);
void * p_context)
//spi_xfer_done = true;
