ERROR 7 [NRF_ERROR_INVALID_PARAM] with custom service for BLE
I use the default ble_template application from the SDK and download a BLE custom service template from here to add it to the template code (as described in the README).
 * Copyright (c) 2014 - 2020, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup ble_sdk_app_template_main main.c
 * @ingroup ble_sdk_app_template
 * @brief Template project main file.
 * This file contains a template for creating a new application. It has the code necessary to wakeup
 * from button, advertise, get a connection restart advertising on disconnect and if no new
 * connection created go back to system-off mode.
 * It can easily be used as a starting point for creating a new application, the comments identified
 * with 'YOUR_JOB' indicates where and how you can customize.
#include <stdbool.h>
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "app_error.h"
#include "ble.h"
#include "ble_hci.h"
#include "ble_srv_common.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "app_timer.h"
#include "fds.h"
#include "peer_manager.h"
#include "peer_manager_handler.h"
#include "bsp_btn_ble.h"
#include "sensorsim.h"
#include "ble_conn_state.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "ble_cus.h"
#define DEVICE_NAME                     "Nordic_Template"                       /**< Name of device. Will be included in the advertising data. */
#define MANUFACTURER_NAME               "NordicSemiconductor"                   /**< Manufacturer. Will be passed to Device Information Service. */
#define APP_ADV_INTERVAL                300                                     /**< The advertising interval (in units of 0.625 ms. This value corresponds to 187.5 ms). */
#define APP_ADV_DURATION                18000                                   /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define APP_BLE_OBSERVER_PRIO           3                                       /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_BLE_CONN_CFG_TAG            1                                       /**< A tag identifying the SoftDevice BLE configuration. */
#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(100, UNIT_1_25_MS)        /**< Minimum acceptable connection interval (0.1 seconds). */
#define MAX_CONN_INTERVAL               MSEC_TO_UNITS(200, UNIT_1_25_MS)        /**< Maximum acceptable connection interval (0.2 second). */
#define SLAVE_LATENCY                   0                                       /**< Slave latency. */
#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)         /**< Connection supervisory timeout (4 seconds). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                   /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                  /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                       /**< Number of attempts before giving up the connection parameter negotiation. */
#define SEC_PARAM_BOND                  1                                       /**< Perform bonding. */
#define SEC_PARAM_MITM                  0                                       /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC                  0                                       /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS              0                                       /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES       BLE_GAP_IO_CAPS_NONE                    /**< No I/O capabilities. */
#define SEC_PARAM_OOB                   0                                       /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE          7                                       /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE          16                                      /**< Maximum encryption key size. */
#define DEAD_BEEF                       0xDEADBEEF                              /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
NRF_BLE_GATT_DEF(m_gatt);                                                       /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr);                                                         /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising);                                             /**< Advertising module instance. */
BLE_CUS_DEF(m_cus);
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID;                        /**< Handle of the current connection. */
/* YOUR_JOB: Declare all services structure your application is using
 *  BLE_XYZ_DEF(m_xyz);
// YOUR_JOB: Use UUIDs for service(s) used in your application.
static ble_uuid_t m_adv_uuids[] =                                               /**< Universally unique service identifiers. */
    {BLE_UUID_DEVICE_INFORMATION_SERVICE, BLE_UUID_TYPE_BLE},
   {CUSTOM_SERVICE_UUID, BLE_UUID_TYPE_VENDOR_BEGIN }
static void advertising_start(bool erase_bonds);
/**@brief Callback function for asserts in the SoftDevice.
 * @param[in] line_num   Line number of the failing ASSERT call.
 * @param[in] file_name  File name of the failing ASSERT call.
/**@brief Function for handling Peer Manager events.
 * @param[in] p_evt  Peer Manager event.
static void pm_evt_handler(pm_evt_t const * p_evt)
    pm_handler_on_pm_evt(p_evt);
    pm_handler_flash_clean(p_evt);
    switch (p_evt->evt_id)
            advertising_start(false);
/**@brief Function for the Timer initialization.
 * @details Initializes the timer module. This creates and starts application timers.
static void timers_init(void)
    // Initialize timer module.
    // Create timers.
    /* YOUR_JOB: Create any timers to be used by the application.
                 Below is an example of how to create a timer.
                 For every new timer needed, increase the value of the macro APP_TIMER_MAX_TIMERS by
                 one.
       ret_code_t err_code;
       err_code = app_timer_create(&m_app_timer_id, APP_TIMER_MODE_REPEATED, timer_timeout_handler);
       APP_ERROR_CHECK(err_code); */
 * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
 *          device including the device name, appearance, and the preferred connection parameters.
                                          (const uint8_t *)DEVICE_NAME,
                                          strlen(DEVICE_NAME));
    /* YOUR_JOB: Use an appearance value matching the application's use case.
       err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_);
/**@brief Function for initializing the GATT module.
static void gatt_init(void)
    ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
    APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling the YYY Service events.
 * YOUR_JOB implement a service handler function depending on the event the service you are using can generate
 * @details This function will be called for all YY Service events which are passed to
 *          the application.
 * @param[in]   p_yy_service   YY Service structure.
 * @param[in]   p_evt          Event received from the YY Service.
static void on_yys_evt(ble_yy_service_t     * p_yy_service,
                       ble_yy_service_evt_t * p_evt)
    switch (p_evt->evt_type)
        case BLE_YY_NAME_EVT_WRITE:
            APPL_LOG("[APPL]: charact written with value %s. ", p_evt->params.char_xx.value.p_str);
            // No implementation needed.
    /* YOUR_JOB: Add code to initialize the services used by the application.
       ble_xxs_init_t                     xxs_init;
       ble_yys_init_t                     yys_init;
       // Initialize XXX Service.
       memset(&xxs_init, 0, sizeof(xxs_init));
       xxs_init.evt_handler                = NULL;
       xxs_init.is_xxx_notify_supported    = true;
       xxs_init.ble_xx_initial_value.level = 100;
       err_code = ble_bas_init(&m_xxs, &xxs_init);
       // Initialize YYY Service.
       memset(&yys_init, 0, sizeof(yys_init));
       yys_init.evt_handler                  = on_yys_evt;
       yys_init.ble_yy_initial_value.counter = 0;
       err_code = ble_yy_service_init(&yys_init, &yy_init);
         ble_cus_init_t                     cus_init;
     // Initialize CUS Service init structure to zero.
    memset(&cus_init, 0, sizeof(cus_init));
    err_code = ble_cus_init(&m_cus, &cus_init);
/**@brief Function for handling the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module which
 *          are passed to the application.
 *          @note All this function does is to disconnect. This could have been done by simply
 *                setting the disconnect_on_fail config parameter, but instead we use the event
 *                handler mechanism to demonstrate its use.
/**@brief Function for handling a Connection Parameters error.
/**@brief Function for starting timers.
static void application_timers_start(void)
    /* YOUR_JOB: Start your timers. below is an example of how to start a timer.
       err_code = app_timer_start(m_app_timer_id, TIMER_INTERVAL, NULL);
    // Prepare wakeup buttons.
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
            NRF_LOG_INFO("Fast advertising.");
        case BLE_ADV_EVT_IDLE:
            sleep_mode_enter();
    ret_code_t err_code = NRF_SUCCESS;
            NRF_LOG_INFO("Disconnected.");
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connected.");
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
    uint32_t ram_start = 0;
    // Enable BLE stack.
/**@brief Function for the Peer Manager initialization.
static void peer_manager_init(void)
    err_code = pm_init();
    sec_param.bond           = SEC_PARAM_BOND;
    sec_param.mitm           = SEC_PARAM_MITM;
    sec_param.lesc           = SEC_PARAM_LESC;
    sec_param.keypress       = SEC_PARAM_KEYPRESS;
    sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
    sec_param.oob            = SEC_PARAM_OOB;
    sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
    sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
    sec_param.kdist_own.enc  = 1;
    sec_param.kdist_own.id   = 1;
    sec_param.kdist_peer.enc = 1;
    sec_param.kdist_peer.id  = 1;
/**@brief Clear bond information from persistent storage.
static void delete_bonds(void)
    NRF_LOG_INFO("Erase bonds!");
    err_code = pm_peers_delete();
 * @param[in]   event   Event generated when button is pressed.
static void bsp_event_handler(bsp_event_t event)
    switch (event)
        case BSP_EVENT_SLEEP:
            sleep_mode_enter();
            break; // BSP_EVENT_SLEEP
        case BSP_EVENT_DISCONNECT:
            break; // BSP_EVENT_DISCONNECT
        case BSP_EVENT_WHITELIST_OFF:
            break; // BSP_EVENT_KEY_0
    ble_advertising_init_t init;
    init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
    init.advdata.include_appearance      = true;
    init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
    init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
    init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
    bsp_event_t startup_event;
    err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
static void log_init(void)
        nrf_pwr_mgmt_run();
    if (erase_bonds == true)
        delete_bonds();
        // Advertising is started by PM_EVT_PEERS_DELETED_SUCEEDED event
        ret_code_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
/**@brief Function for application main entry.
    bool erase_bonds;
    // Initialize.
    log_init();
    timers_init();
    power_management_init();
    ble_stack_init();
    gap_params_init();
    gatt_init();
    advertising_init();
    services_init();
    conn_params_init();
    peer_manager_init();
    // Start execution.
    NRF_LOG_INFO("Template example started.");
    application_timers_start();
    advertising_start(erase_bonds);
    // Enter main loop.
    for (;;)
        idle_state_handle();
In SES I also changed the RAM location and the RAM size in the linker settings:
RAM_START=0x20002260
RAM_SIZE=0xDDA0
But I got the following error message when try to run the code
<info> app_timer: RTC: initialized.
<error> app: ERROR 7 [NRF_ERROR_INVALID_PARAM] at nRF5_SDK_17.0.2_d674dde\examples\ble_peripheral\ble_app_template\main.c:638
PC at: 0x00031DA1
<error> app: End of error report
So what is wrong here?
