ERROR 7 [NRF_ERROR_INVALID_PARAM] with custom service for BLE
I use the default ble_template application from the SDK and download a BLE custom service template from here to add it to the template code (as described in the README).
 * Copyright (c) 2014 - 2020, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup ble_sdk_app_template_main main.c
 * @ingroup ble_sdk_app_template
 * @brief Template project main file.
 * This file contains a template for creating a new application. It has the code necessary to wakeup
 * from button, advertise, get a connection restart advertising on disconnect and if no new
 * connection created go back to system-off mode.
 * It can easily be used as a starting point for creating a new application, the comments identified
 * with 'YOUR_JOB' indicates where and how you can customize.
#include <stdbool.h>
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "app_error.h"
#include "ble.h"
#include "ble_hci.h"
#include "ble_srv_common.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "app_timer.h"
#include "fds.h"
#include "peer_manager.h"
#include "peer_manager_handler.h"
#include "bsp_btn_ble.h"
#include "sensorsim.h"
#include "ble_conn_state.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "ble_cus.h"
#define DEVICE_NAME                     "Nordic_Template"                       /**< Name of device. Will be included in the advertising data. */
#define MANUFACTURER_NAME               "NordicSemiconductor"                   /**< Manufacturer. Will be passed to Device Information Service. */
#define APP_ADV_INTERVAL                300                                     /**< The advertising interval (in units of 0.625 ms. This value corresponds to 187.5 ms). */
#define APP_ADV_DURATION                18000                                   /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define APP_BLE_OBSERVER_PRIO           3                                       /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_BLE_CONN_CFG_TAG            1                                       /**< A tag identifying the SoftDevice BLE configuration. */
#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(100, UNIT_1_25_MS)        /**< Minimum acceptable connection interval (0.1 seconds). */
#define MAX_CONN_INTERVAL               MSEC_TO_UNITS(200, UNIT_1_25_MS)        /**< Maximum acceptable connection interval (0.2 second). */
#define SLAVE_LATENCY                   0                                       /**< Slave latency. */
#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)         /**< Connection supervisory timeout (4 seconds). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                   /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                  /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                       /**< Number of attempts before giving up the connection parameter negotiation. */
#define SEC_PARAM_BOND                  1                                       /**< Perform bonding. */
#define SEC_PARAM_MITM                  0                                       /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC                  0                                       /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS              0                                       /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES       BLE_GAP_IO_CAPS_NONE                    /**< No I/O capabilities. */
#define SEC_PARAM_OOB                   0                                       /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE          7                                       /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE          16                                      /**< Maximum encryption key size. */
#define DEAD_BEEF                       0xDEADBEEF                              /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
NRF_BLE_GATT_DEF(m_gatt);                                                       /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr);                                                         /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising);                                             /**< Advertising module instance. */
BLE_CUS_DEF(m_cus);
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID;                        /**< Handle of the current connection. */
/* YOUR_JOB: Declare all services structure your application is using
 *  BLE_XYZ_DEF(m_xyz);
// YOUR_JOB: Use UUIDs for service(s) used in your application.
static ble_uuid_t m_adv_uuids[] =                                               /**< Universally unique service identifiers. */
    {BLE_UUID_DEVICE_INFORMATION_SERVICE, BLE_UUID_TYPE_BLE},
   {CUSTOM_SERVICE_UUID, BLE_UUID_TYPE_VENDOR_BEGIN }
static void advertising_start(bool erase_bonds);
/**@brief Callback function for asserts in the SoftDevice.
 * @param[in] line_num   Line number of the failing ASSERT call.
 * @param[in] file_name  File name of the failing ASSERT call.
/**@brief Function for handling Peer Manager events.
 * @param[in] p_evt  Peer Manager event.
static void pm_evt_handler(pm_evt_t const * p_evt)
    pm_handler_on_pm_evt(p_evt);
    pm_handler_flash_clean(p_evt);
    switch (p_evt->evt_id)
            advertising_start(false);
/**@brief Function for the Timer initialization.
 * @details Initializes the timer module. This creates and starts application timers.
static void timers_init(void)
    // Initialize timer module.
    // Create timers.
    /* YOUR_JOB: Create any timers to be used by the application.
                 Below is an example of how to create a timer.
                 For every new timer needed, increase the value of the macro APP_TIMER_MAX_TIMERS by
                 one.
       ret_code_t err_code;
       err_code = app_timer_create(&m_app_timer_id, APP_TIMER_MODE_REPEATED, timer_timeout_handler);
       APP_ERROR_CHECK(err_code); */
 * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
 *          device including the device name, appearance, and the preferred connection parameters.
                                          (const uint8_t *)DEVICE_NAME,
                                          strlen(DEVICE_NAME));
    /* YOUR_JOB: Use an appearance value matching the application's use case.
       err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_);
/**@brief Function for initializing the GATT module.
static void gatt_init(void)
    ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
    APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling the YYY Service events.
 * YOUR_JOB implement a service handler function depending on the event the service you are using can generate
 * @details This function will be called for all YY Service events which are passed to
 *          the application.
 * @param[in]   p_yy_service   YY Service structure.
 * @param[in]   p_evt          Event received from the YY Service.
static void on_yys_evt(ble_yy_service_t     * p_yy_service,
                       ble_yy_service_evt_t * p_evt)
    switch (p_evt->evt_type)
        case BLE_YY_NAME_EVT_WRITE:
            APPL_LOG("[APPL]: charact written with value %s. ", p_evt->params.char_xx.value.p_str);
            // No implementation needed.
    /* YOUR_JOB: Add code to initialize the services used by the application.
       ble_xxs_init_t                     xxs_init;
       ble_yys_init_t                     yys_init;
       // Initialize XXX Service.
       memset(&xxs_init, 0, sizeof(xxs_init));
       xxs_init.evt_handler                = NULL;
       xxs_init.is_xxx_notify_supported    = true;
       xxs_init.ble_xx_initial_value.level = 100;
       err_code = ble_bas_init(&m_xxs, &xxs_init);
       // Initialize YYY Service.
       memset(&yys_init, 0, sizeof(yys_init));
       yys_init.evt_handler                  = on_yys_evt;
       yys_init.ble_yy_initial_value.counter = 0;
       err_code = ble_yy_service_init(&yys_init, &yy_init);
         ble_cus_init_t                     cus_init;
     // Initialize CUS Service init structure to zero.
    memset(&cus_init, 0, sizeof(cus_init));
    err_code = ble_cus_init(&m_cus, &cus_init);
/**@brief Function for handling the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module which
 *          are passed to the application.
 *          @note All this function does is to disconnect. This could have been done by simply
 *                setting the disconnect_on_fail config parameter, but instead we use the event
 *                handler mechanism to demonstrate its use.
/**@brief Function for handling a Connection Parameters error.
/**@brief Function for starting timers.
static void application_timers_start(void)
    /* YOUR_JOB: Start your timers. below is an example of how to start a timer.
       err_code = app_timer_start(m_app_timer_id, TIMER_INTERVAL, NULL);
    // Prepare wakeup buttons.
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
            NRF_LOG_INFO("Fast advertising.");
        case BLE_ADV_EVT_IDLE:
            sleep_mode_enter();
    ret_code_t err_code = NRF_SUCCESS;
            NRF_LOG_INFO("Disconnected.");
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connected.");
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
    uint32_t ram_start = 0;
    // Enable BLE stack.
/**@brief Function for the Peer Manager initialization.
static void peer_manager_init(void)
    err_code = pm_init();
    sec_param.bond           = SEC_PARAM_BOND;
    sec_param.mitm           = SEC_PARAM_MITM;
    sec_param.lesc           = SEC_PARAM_LESC;
    sec_param.keypress       = SEC_PARAM_KEYPRESS;
    sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
    sec_param.oob            = SEC_PARAM_OOB;
    sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
    sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
    sec_param.kdist_own.enc  = 1;
    sec_param.kdist_own.id   = 1;
    sec_param.kdist_peer.enc = 1;
    sec_param.kdist_peer.id  = 1;
/**@brief Clear bond information from persistent storage.
static void delete_bonds(void)
    NRF_LOG_INFO("Erase bonds!");
    err_code = pm_peers_delete();
 * @param[in]   event   Event generated when button is pressed.
static void bsp_event_handler(bsp_event_t event)
    switch (event)
        case BSP_EVENT_SLEEP:
            sleep_mode_enter();
            break; // BSP_EVENT_SLEEP
        case BSP_EVENT_DISCONNECT:
            break; // BSP_EVENT_DISCONNECT
        case BSP_EVENT_WHITELIST_OFF:
            break; // BSP_EVENT_KEY_0
    ble_advertising_init_t init;
    init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
    init.advdata.include_appearance      = true;
    init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
    init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
    init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
    bsp_event_t startup_event;
    err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
static void log_init(void)
        nrf_pwr_mgmt_run();
    if (erase_bonds == true)
        delete_bonds();
        // Advertising is started by PM_EVT_PEERS_DELETED_SUCEEDED event
        ret_code_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
/**@brief Function for application main entry.
    bool erase_bonds;
    // Initialize.
    log_init();
    timers_init();
    power_management_init();
    ble_stack_init();
    gap_params_init();
    gatt_init();
    advertising_init();
    services_init();
    conn_params_init();
    peer_manager_init();
    // Start execution.
    NRF_LOG_INFO("Template example started.");
    application_timers_start();
    advertising_start(erase_bonds);
    // Enter main loop.
    for (;;)
        idle_state_handle();
In SES I also changed the RAM location and the RAM size in the linker settings:
RAM_START=0x20002260
RAM_SIZE=0xDDA0
But I got the following error message when try to run the code
<info> app_timer: RTC: initialized.
<error> app: ERROR 7 [NRF_ERROR_INVALID_PARAM] at nRF5_SDK_17.0.2_d674dde\examples\ble_peripheral\ble_app_template\main.c:638
PC at: 0x00031DA1
<error> app: End of error report
So what is wrong here?
    Looking at line 638 ( as pointed out in the error message ) we find the APP_ERROR_CHECK with the error code returned from ble_advertising_init function. Looking at the ble_advertising_init API Reference yields the following exempt:
    NRF_ERROR_INVALID_PARAM If the advertising configuration in p_init is invalid.
    My guess here is that you are trying to include more than the possible 31 bytes into your advertising.
    To resolve this, I would recommend that you cut down on the device name - which right now is trying to configure advertising with full name, 15 + 2 = 17 bytes, just for the name - and move one or both uuid's to your scan response instead.
    Please try this, and see if it resolves your issue.
    Karl
  • Hello Karl,
    I have changed the name to "Dev", but the error is still the same.
  • Hello again Kampino,
    What is the length of your current advertising packet? Does it still exceed 31 bytes? Keep in mind that each field required 2 bytes overhead ( 1 for type and 1 for length). Please try to move one of your UUID's to the scan response, and see if this resolves your issue.
    Karl
  • Hello Karl,
    I will check this after. What do you mean with
    "Please try to move one of your UUID's to the scan response, and see if this resolves your issue."
    Can you give me a more detailed explanation about this please?
    Thank you.
    Are you familiar with the Scan Response in general, or are you asking how to implement it specifically?
    The scan response is a secondary advertising packet - like an extension - that is sent upon receiving a SCAN_REQ, in which the central asks for a SCAN_RSP, containing additional advertising data.
    Since you are using the Advertising module, you may just add scan response data exactly as you are adding advertising data right now - by setting the the srdata field of the ble_advertising_init_t structure you are already passing to your ble_advertising_init function.
    So, instead of including multiple UUID's in your advertising data, you may place some of them in your scan response data instead.
    Does this make things more clear, or is there something you would like me to explain in more detail?
    Please let me know if anything still should be unclear.
    Karl
