BLE_GATTS_EVT_HVN_TX_COMPLETE not called after NRF_ERROR_RESOURCES
Hi everyone,
I work on an custom board with the nrf52840, the SDK 15.2.0, the SoftDevice 140 6.1.0 and FreeRTOS.
My problem is that during a BLE transfert of a lot of small packets (16 Bytes) I go stuck in the do while loop with sd_ble_gatts_hvx().
The context is that we ask on mobile phone side the donwload of the data. On each BLE_GATTS_EVT_HVN_TX_COMPLETE event we send a new packet on a queue.
We run a task which dequeue all notification to send them over the sd_ble_gatts_hvx() function.
During the process of sending we use a do-while loop as suggested in few other topics.
But the problem is that there is a moment the notification are not send any more. We have an NRF_ERROR_RESOURCES and we don't receive any BLE_GATTS_EVT_HVN_TX_COMPLETE event after this error occured so even if we wait for BLE_GATTS_EVT_HVN_TX_COMPLETE we are not able to continue any ble transfert.
Is anyone have a idea why ?
The softdevice task run with a priority of 3 (in FreeRTOS) and other task run with a priority of 2.
Thanks in advance for any response.
Etienne D
  • Hi Etienne
    What is the conditions for exiting the loop where you are sending notifications?
    The recommended way to maximize throughput is to upload notifications continuously until the NRF_ERROR_RESOURCES error occurs. Then you should stop calling the sd_ble_gatts_hvx() function until the BLE_GATTS_EVT_HVN_TX_COMPLETE event occurs, at which point the stack will be ready to accept more packets.
    Best regards
    Torbjørn
  • Hi Trobjorn,
    Thank you for your response.
    The loop look like the loop below.
        do{
            err_code = sd_ble_gatts_hvx(conn_handle, &hvx_params);
        }while(err_code == NRF_ERROR_RESOURCES);
    I try to push all notification into my queue and then treat them with the other task. But at some point an error NRF_ERROR_RESOURCES comes and we don not receive any TX_COMPLETE to continue the transfert.
    To do the waiting stage for the TX_COMPLETE we use a xEventGroupWaitBits in our notification function. And we use xEventGroupSetBits in the nrf_sdh_ble_evts_poll function inside the nrf_sdh_ble.c file.
    Best regards
    Etienne D
  • Hi Etienne
    I would not recommend doing the loop in this way.
    You can keep calling sd_ble_gatts_hvx as long as it returns NRF_SUCCESS, but once you get an error code in return you should hold off and wait for the BLE_GATTS_EVT_HVN_TX_COMPLETE event to occur:
    do{
    }while(err_code == NRF_SUCCESS);
    // Set some flag to indicate that you are waiting for the BLE_GATTS_EVT_HVN_TX_COMPLETE event
    Otherwise you are wasting a lot of CPU cycles continuously trying to upload data to the stack, and you risk blocking SoftDevice events being handled.
    Best regards
    Torbjørn
  • Hi Torbjorn,
    I found the problem for my missing BLE_GATTS_EVT_HVN_TX_COMPLETE.
    I apply the fix on softdevice_task and SD_EVT_IRQHandler functions.
    Now I receive well the event and my transfert can continue.
    Thank you again for your support.
    Etienne D
  • Hi Etienne
    That is great news. I will consider this case closed then Slight smile
    Best regards
    Torbjørn
