USBD issue after bluetooth is connected once
Our application stores sensor data in flash and sends the data on request via USB. But if the device is connected to Bluetooth once then it is having issues in USB data transfer. Device receives 21 bytes in place of 20 bytes. Receiving same packet twice even if the host doesn't send. But everything works normal if we power cycle the device.
We wrote application over usbd_ble_uart_pca10056_s140 example.
Vishnu
  • Could you make sure that the device is not in fact resetting, when you connect the USB cable?
    It is not resetting. We disconnect the Bluetooth and stop advertising too when USB is connected.
    Are you familiar with the nRF Sniffer tool? It would be very helpful if you could provide a trace of the BLE communication when this happens, along with a log file of the USB traffic.
    Will try to do this. In fact the issue is happening without any Bluetooth packet exchange. I just connected the device to our app or nrf uart app and disconnected.
    Vishnu
  • Hello again Vishnu,
    I am sorry, but I am not sure I understand what you mean by this. Are you saying that the issue ( added CR character at the end of a transmission ) appears regardless of BLE connection status?
    If so, I do not understand the part in which you say it happens without Bluetooth packet exchange, while also saying you are connected to the device through an app or nRF UART app?
    Please bear in mind that empty packets are constantly being exchanged in a connection where no communication is happening on the application layer.
    Karl
  • We disconnect the Bluetooth and stop advertising too when USB is connected.
    On USB power detect event, we call sd_ble_gap_disconnect and sd_ble_gap_adv_stop.
    I am sorry I meant, the packets send by our application, not the empty packets.
    Thank you for clarifying.
    So, you connect your device to your phone through a cabled USB connection, and upon detecting this connection you disconnect any BLE connection and stop advertising.
    Then, you begin a transfer of sensor data over the USB, from the device to the phone.
    In this transfer ( which is entirely independent of BLE communications ) the issue appears, in which a CR character is added to the end of the transfer, when your phone is sending data to the device - but not the other way around. I.e the phone sends 20 bytes, but 21 is received by the device ( added CR character ), but when the device sends 20 bytes to the phone, only 20 bytes are received.
    Have I got this correctly?
    I am sorry
    No worries, I am just trying to make sure that I have understood the issue you are facing correctly :)
    In this case, application here refers to your smartphone application that is sending data to your device over USB. Correct?
    Karl
    I am sorry
    Karl
