Is it possible to ble_app_buttonless_dfu transmit beacons?
I tested "ble_app_buttonless_dfu" example and "ble_app_beacon" example. Everything was fine. Now, I am trying to make an application that advertise as a beacon and supports DFU OTA.
This is my advertising_init function:
static void advertising_init(void) {
  uint32_t err_code;
  ble_advertising_init_t init;
  ble_advdata_manuf_data_t manuf_specific_data;
  manuf_specific_data.company_identifier = APP_COMPANY_IDENTIFIER;
   manuf_specific_data.data.p_data = (uint8_t *) m_beacon_info;
   manuf_specific_data.data.size   = APP_BEACON_INFO_LENGTH;
  init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
  init.advdata.include_appearance      = true;
  init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
  init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
  init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
 // init.advdata.p_manuf_specific_data = &manuf_specific_data;
  advertising_config_get(&init.config);
  // Initialize advertising parameters (used when starting advertising).
  memset(&m_adv_params, 0, sizeof(m_adv_params));
  m_adv_params.properties.type = BLE_GAP_ADV_TYPE_NONCONNECTABLE_NONSCANNABLE_UNDIRECTED;
  m_adv_params.p_peer_addr     = NULL;    // Undirected advertisement.
  m_adv_params.filter_policy   = BLE_GAP_ADV_FP_ANY;
  m_adv_params.interval        = NON_CONNECTABLE_ADV_INTERVAL;
  m_adv_params.duration        = 0;    // Never time out.
  m_adv_params.channel_mask[4] = 0x60;
when I uncomment the line with "init.advdata.p_manuf_specific_data = &manuf_specific_data;", the application doesn't work. Any idea of what is the problem? Or how can I solve it?
PS.: I am newbie here and this is my first question. I am sorry if the question is not so clear. Sweat smile
    The manufacturer field is probably too big to fint into the advertisment packet which is 31 bytes. Please try to comment these to lines:
      init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]); /* Advertise Service UUIDs*/
    Then uncomment the "init.advdata.p_manuf_specific_data" to include the manufacturer field. You will also need to change the BLE_GAP_ADV_TYPE_NONCONNECTABLE_NONSCANNABLE_UNDIRECTED flag to make the device connectable.
    Vidar
  • Thanks for your answer, Vidar
    I made these changes in my code, but the nRF5232 still doesn't transmit beacons...
    I think that the manufacturer field isn't too big, as you can see:
    #define APP_BEACON_INFO_LENGTH          0x17                               /**< Total length of information advertised by the Beacon. */
    #define APP_ADV_DATA_LENGTH             0x15                               /**< Length of manufacturer specific data in the advertisement. */
    #define APP_DEVICE_TYPE                 0x02                               /**< 0x02 refers to Beacon. */
    #define APP_MEASURED_RSSI               0xC3                               /**< The Beacon's measured RSSI at 1 meter distance in dBm. */
    #define APP_COMPANY_IDENTIFIER          0x0059                             /**< Company identifier for Nordic Semiconductor ASA. as per www.bluetooth.org. */
    #define APP_MAJOR_VALUE                 0x01, 0x02                         /**< Major value used to identify Beacons. */
    #define APP_MINOR_VALUE                 0x03, 0x04                         /**< Minor value used to identify Beacons. */
    #define APP_BEACON_UUID                 0x01, 0x12, 0x23, 0x34, \
                                            0x45, 0x56, 0x67, 0x78, \
                                            0x89, 0x9a, 0xab, 0xbc, \
                                            0xcd, 0xde, 0xef, 0xf0            /**< Proprietary UUID for Beacon. */
    static uint8_t m_beacon_info[APP_BEACON_INFO_LENGTH] =                    /**< Information advertised by the Beacon. */
        APP_DEVICE_TYPE,     // Manufacturer specific information. Specifies the device type in this
                             // implementation.
        APP_ADV_DATA_LENGTH, // Manufacturer specific information. Specifies the length of the
                             // manufacturer specific data in this implementation.
        APP_BEACON_UUID,     // 128 bit UUID value.
        APP_MAJOR_VALUE,     // Major arbitrary value that can be used to distinguish between Beacons.
        APP_MINOR_VALUE,     // Minor arbitrary value that can be used to distinguish between Beacons.
        APP_MEASURED_RSSI    // Manufacturer specific information. The Beacon's measured TX power in
                             // this implementation.
    Gabriel
  • Hi Gabriel,
    It is too big if you also need to include device name and Service UUIDs. Please try this implementation:
    #define APP_ADV_DURATION     BLE_GAP_ADV_TIMEOUT_GENERAL_UNLIMITED
    #if defined(USE_UICR_FOR_MAJ_MIN_VALUES)
        // If USE_UICR_FOR_MAJ_MIN_VALUES is defined, the major and minor values will be read from the
        // UICR instead of using the default values. The major and minor values obtained from the UICR
        // are encoded into advertising data in big endian order (MSB First).
        // To set the UICR used by this example to a desired value, write to the address 0x10001080
        // using the nrfjprog tool. The command to be used is as follows.
        // nrfjprog --snr <Segger-chip-Serial-Number> --memwr 0x10001080 --val <your major/minor value>
        // For example, for a major value and minor value of 0xabcd and 0x0102 respectively, the
        // the following command should be used.
        // nrfjprog --snr <Segger-chip-Serial-Number> --memwr 0x10001080 --val 0xabcd0102
        uint16_t major_value = ((*(uint32_t *)UICR_ADDRESS) & 0xFFFF0000) >> 16;
        uint16_t minor_value = ((*(uint32_t *)UICR_ADDRESS) & 0x0000FFFF);
        uint8_t index = MAJ_VAL_OFFSET_IN_BEACON_INFO;
        m_beacon_info[index++] = MSB_16(major_value);
        m_beacon_info[index++] = LSB_16(major_value);
        m_beacon_info[index++] = MSB_16(minor_value);
        m_beacon_info[index++] = LSB_16(minor_value);
        init.advdata.name_type               = BLE_ADVDATA_NO_NAME;
        //init.advdata.include_appearance      = true;
        //init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
        //init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
    Vidar
