Bluetooth Codded PHY couldn't connect after disconnecting. W: Found valid connection in disconnected state
I am working with:
NRF52840 boards
nRF Connect SDKwith Zephyr
On Ubuntu
Desired behaviour would be:
  1. Establish connection with Codded PHY
  2. After some time disconnect
  3. Connect back to the device in the same way as it was done in step 1. (with Codded PHY)
Scanner initialisation:
	struct bt_le_scan_param scan_param = {
		.type     = BT_LE_SCAN_TYPE_ACTIVE,
		.interval = BT_GAP_SCAN_FAST_INTERVAL,
		.window   = BT_GAP_SCAN_FAST_WINDOW,
		.options  = BT_LE_SCAN_OPT_CODED | BT_LE_SCAN_OPT_NO_1M | BT_LE_SCAN_OPT_FILTER_DUPLICATE
	struct bt_scan_init_param scan_init = {
		.connect_if_match = 0,			// Original code
		.scan_param = &scan_param,
		.conn_param = NULL
	bt_scan_init(&scan_init);
	bt_scan_cb_register(&scan_cb);
And activation with:
err = bt_scan_start(BT_SCAN_TYPE_SCAN_ACTIVE);
if (err) {
	printk("Starting scanning failed (err %d)\n", err);
	return;
When discovered I try to connect in the following way:
err = bt_scan_stop();
	if (err) {
		printk("Stop LE scan failed (err %d)\n", err);
	conn_params = BT_CONN_LE_CREATE_PARAM(
			BT_CONN_LE_OPT_CODED | BT_CONN_LE_OPT_NO_1M,
			BT_GAP_SCAN_FAST_INTERVAL);
	err = bt_conn_le_create(device_info->recv_info->addr, conn_params,
				BT_LE_CONN_PARAM_DEFAULT,
				&default_conn);
	if (err) {
		printk("Create conn failed (err %d)\n", err);
		if (err) {
			printk("Scanning failed to start (err %d)\n", err);
			return;
To disconnect, I call following function:
err = bt_conn_disconnect(default_conn,BT_HCI_ERR_REMOTE_USER_TERM_CONN);
if (err) {
	printk("Could not disconnect(err %d)\n", err);
	return;
I am able to successfully connect to device which advertise on Codded PHY.
Then I successfuly disconnect ( the callback disconnected is called)
But when I try to reconnect again I get the following error:
Create conn failed (err -22)
Connection pending
