* Copyright (c) 2019 Nordic Semiconductor ASA
* SPDX-License-Identifier: LicenseRef-BSD-5-Clause-Nordic
#include <zephyr.h>
#include <kernel.h>
#include <drivers/gpio.h>
#include <drivers/flash.h>
#include <bsd.h>
#include <lte_lc.h>
#include <at_cmd.h>
#include <at_notif.h>
#include <net/bsdlib.h>
#include <net/fota_download.h>
#include <dfu/mcuboot.h>
#include <logging/log.h>
#include <sms.h>
LOG_MODULE_REGISTER(main_,4);
#define LED_PORT DT_ALIAS_LED0_GPIOS_CONTROLLER
static struct device *gpiob;
static struct gpio_callback gpio_cb;
static struct k_work fota_work;
/**@brief Recoverable BSD library error. */
void bsd_recoverable_error_handler(uint32_t err)
printk("bsdlib recoverable error: %u\n", err);
/**@brief Start transfer of the file. */
static void app_dfu_transfer_start(struct k_work *unused)
int retval;
retval = fota_download_start(CONFIG_DOWNLOAD_HOST,
CONFIG_DOWNLOAD_FILE);
if (retval != 0) {
/* Re-enable button callback */
gpio_pin_enable_callback(gpiob, DT_ALIAS_SW0_GPIOS_PIN);
printk("fota_download_start() failed, err %d\n",
retval);
/**@brief Turn on LED0 and LED1 if CONFIG_APPLICATION_VERSION
* is 2 and LED0 otherwise.
static int led_app_version(void)
struct device *dev;
dev = device_get_binding(LED_PORT);
if (dev == 0) {
printk("Nordic nRF GPIO driver was not found!\n");
return 1;
gpio_pin_configure(dev, DT_ALIAS_LED0_GPIOS_PIN, GPIO_DIR_OUT);
gpio_pin_write(dev, DT_ALIAS_LED0_GPIOS_PIN, 1);
#if CONFIG_APPLICATION_VERSION == 2
gpio_pin_configure(dev, DT_ALIAS_LED1_GPIOS_PIN, GPIO_DIR_OUT);
gpio_pin_write(dev, DT_ALIAS_LED1_GPIOS_PIN, 1);
return 0;
void dfu_button_pressed(struct device *gpiob, struct gpio_callback *cb,
u32_t pins)
k_work_submit(&fota_work);
gpio_pin_disable_callback(gpiob, DT_ALIAS_SW0_GPIOS_PIN);
static int dfu_button_init(void)
int err;
gpiob = device_get_binding(DT_ALIAS_SW0_GPIOS_CONTROLLER);
if (gpiob == 0) {
return 1;
err = gpio_pin_configure(gpiob, DT_ALIAS_SW0_GPIOS_PIN,
GPIO_DIR_IN | GPIO_INT | GPIO_PUD_PULL_UP |
GPIO_INT_EDGE | GPIO_INT_ACTIVE_LOW);
if (err == 0) {
gpio_init_callback(&gpio_cb, dfu_button_pressed,
BIT(DT_ALIAS_SW0_GPIOS_PIN));
err = gpio_add_callback(gpiob, &gpio_cb);
if (err == 0) {
err = gpio_pin_enable_callback(gpiob, DT_ALIAS_SW0_GPIOS_PIN);
if (err != 0) {
printk("Unable to configure SW0 GPIO pin!\n");
return 1;
return 0;
void fota_dl_handler(const struct fota_download_evt *evt)
switch (evt->id) {
case FOTA_DOWNLOAD_EVT_ERROR:
printk("Received error from fota_download\n");
/* Fallthrough */
case FOTA_DOWNLOAD_EVT_FINISHED:
/**@brief Configures modem to provide LTE link.
* Blocks until link is successfully established.
static void modem_configure(void)
#if defined(CONFIG_LTE_LINK_CONTROL)
BUILD_ASSERT_MSG(!IS_ENABLED(CONFIG_LTE_AUTO_INIT_AND_CONNECT),
"This sample does not support auto init and connect");
int err;
err = at_notif_init();
__ASSERT(err == 0, "AT Notify could not be initialized.");
err = at_cmd_init();
__ASSERT(err == 0, "AT CMD could not be established.");
printk("LTE Link Connecting ...\n");
err = lte_lc_init_and_connect();
__ASSERT(err == 0, "LTE link could not be established.");
printk("LTE Link Connected!\n");
static int application_init(void)
int err;
k_work_init(&fota_work, app_dfu_transfer_start);
err = dfu_button_init();
if (err != 0) {
return err;
err = led_app_version();
if (err != 0) {
return err;
err = fota_download_init(fota_dl_handler);
if (err != 0) {
return err;
return 0;
void sms_callback_process(struct sms_data *const data, void *context)
if (NULL == data)
return;
LOG_DBG("sms: %s",data);
LOG_DBG("alpha: %s",data->alpha);
LOG_DBG("leng: %d",data->length);
LOG_DBG("pdu: %d",data->pdu);
void sms_send_test1(void)
//Testing a sms messaging over lte
at_cmd_write("AT+CMGS=42\r0011000B912103000100F500000B20D4F29C9E769F4161D0BC3D07B5CBF379F89C769F416F7B590E62D3CB\x1A",NULL,0,NULL);
//Hello Nordic
// at_cmd_write("AT+CMGS=24\r0001000B912103000100F500000CC8329BFD0639DF72727A0C\x1A",NULL,0,NULL);
static int test_sms = 0;
static int test_sms1 = 0;
void main(void)
int err;
printk("Initializing bsdlib\n");
err = bsdlib_init();
switch (err) {
case MODEM_DFU_RESULT_OK:
printk("Modem firmware update successful!\n");
printk("Modem will run the new firmware after reboot\n");
k_thread_suspend(k_current_get());
case MODEM_DFU_RESULT_UUID_ERROR:
case MODEM_DFU_RESULT_AUTH_ERROR:
printk("Modem firmware update failed\n");
printk("Modem will run non-updated firmware on reboot.\n");
case MODEM_DFU_RESULT_HARDWARE_ERROR:
case MODEM_DFU_RESULT_INTERNAL_ERROR:
printk("Fatal error.\n");
case -1:
printk("Could not initialize bsdlib.\n");
return;
LOG_INF("Initialized bsdlib\n");
modem_configure();
boot_write_img_confirmed();
err = application_init();
if (err != 0) {
return;
LOG_DBG("Press Button 1 to start the FOTA download\n");
sms_init();
at_cmd_write("AT+CMFG=0\r\n",NULL,0,NULL);
sms_register_listener(sms_callback_process,NULL);
if (err != 0)
LOG_ERR("Can't register handler rc=%d", err);
while(1)
// LOG_INF("main thread run");
if (0xff == test_sms1)
sms_send_test1();
test_sms1 = 0;
k_sleep(1000);
Initializing bsdlib
[00:00:00.189,239] <inf> main_: Initialized bsdlib
[00:00:00.197,082] <inf> at_cmd: AT%XSYSTEMMODE=1,0,0,0
[00:00:00.204,711] <inf> at_cmd: OK
[00:00:00.208,923] <inf> at_cmd: AT+CEREG=5
[00:00:00.220,031] <inf> at_cmd: OK
[00:00:00.224,304] <inf> at_cmd: AT%XSYSTEMMODE=1,0,0,0
[00:00:00.237,976] <inf> at_cmd: OK
[00:00:00.242,218] <inf> at_cmd: AT+CFUN=1
[00:00:00.284,851] <inf> at_cmd: OK
[00:00:05.684,600] <inf> at_cmd: +CEREG: 2,"0001","01A2D001",7,0,0,"11100000","11100000"
[00:00:06.296,142] <inf> at_cmd: +CEREG: 1,"0001","01A2D001",7,,,"11100000","11100000"
LTE Link Connected!
[00:00:06.307,098] <dbg> main_.main: Press Button 1 to start the FOTA download
[00:00:06.314,971] <inf> at_cmd: AT+CNMI?
[00:00:06.319,824] <inf> at_cmd: +CNMI: 0,0,0,0,1
OK
[00:00:06.325,744] <inf> at_cmd: AT+CNMI=3,2,0,1
[00:00:06.331,237] <inf> at_cmd: OK
[00:00:06.335,449] <inf> sms: SMS client successfully registered
[00:00:21.775,329] <inf> at_cmd: +CMS ERROR: 300
04800000000410D0C176589E9EBFCD7400000211010154752303ECF718
[00:07:22.368,103] <dbg> main_.sms_callback_process: alpha: 1C6785E9E9FBDC47
[00:07:22.375,701] <dbg> main_.sms_callback_process: leng: 24
[00:07:22.381,958] <dbg> main_.sms_callback_process: pdu: 537010464
[00:07:22.388,824] <inf> at_cmd: AT+CNMA=1
[00:07:22.420,776] <inf> at_cmd: OK
