DFU buttonless with Bond not working.
Hello there,
First of all, I had searched similar issue internally but didn't find any solution.
My problem is for my application with DFU buttonless without bond everything is okay. So I just followed the instruction (https://devzone.nordicsemi.com/nordic/short-range-guides/b/software-development-kit/posts/getting-started-with-nordics-secure-dfu-bootloader#h61sjziauupw1j397q9s9ldr01q4j6d5) to add bond. It seemed pretty straightforward. The program stuck at
err_code = ble_dfu_buttonless_init(&dfus_init);
Here is the debug info
"<00> info> app: Setting vector table to bootloader: 0x00078000
<00> debug> app: nrf_dfu_svci_vector_table_set() -> success
<00> debug> app: nrf_dfu_set_peer_data_init() -> success
<00> info> app: Setting vector table to main app: 0x00026000
<00> debug> app: nrf_dfu_svci_vector_table_unset() -> success
<00> error> app: ERROR 8 [NRF_ERROR_INVALID_STATE] at ..\..\..\main.c:777
00> PC at: 0x00031A4B
<00> error> app: End of error report
here is where ble_dfu_buttonless_init located in my code
    ret_code_t         err_code;
    ble_lbs_init_t     init;
    ble_nus_init_t nus_init;
        ble_dfu_buttonless_init_t dfus_init = {0};
    // Initialize Queued Write Module instances.
    for (uint32_t i = 0; i < LINK_TOTAL; i++)
        err_code = nrf_ble_qwr_init(&m_qwr[i], &qwr_init);
        //Initialize DFU
            // Initialize the async SVCI interface to bootloader.
    err_code = ble_dfu_buttonless_async_svci_init();
    dfus_init.evt_handler = ble_dfu_evt_handler;
    // Initialize LBS.
    init.led_write_handler = led_write_handler;
    err_code = ble_lbs_init(&m_lbs, &init);
    // Initialize NUS.
    ble_conn_state_init();
Here is main function
        bool erase_bonds;
    // Initialize.
        err_code = clock_config();
    uart_init();
    log_init();
    timers_init();
    leds_init();
    buttons_init();
    power_management_init();
    ble_stack_init();
    gap_params_init();
    gatt_init();
    services_init();
    advertising_init();
    conn_params_init();
        peer_manager_init(erase_bonds);
        start_app_timer();
    advertising_start(erase_bonds);
    // Enter main loop.
    for (;;)
        idle_state_handle();
Then I used ble_app_buttonless_dfu example and changed sdk_config.h to bond. It also worked fine.
So it must be something wrong with my services_init(). But I just cannot figure it out.
Thank you.
  • Hi Vidar,
    The ble_dfu_buttonless_async_svci_init is in service Initialization. I tried to move it right after log_init() in main() but got the same error.
    The current init sequence in Main() is okay for DFU without bond. It's like bond changes something.
    I just tried to move the peer_manager_init before service_init. It seems the program passed the service_init but stuck at advertising_init(), more specifically at
    err_code = ble_advdata_encode(&srdata, m_adv_data.scan_rsp_data.p_data, &m_adv_data.scan_rsp_data.len);
    with "ERROR 7, INVALID_PARAM".
    Can I send you my source code?
    Here is my advertising_init() code
        ble_advdata_t        advdata;
        ble_advdata_t        srdata;
        ble_gap_adv_params_t adv_params;
    //        ble_advertising_init_t init;
        ble_uuid_t adv_uuids[] = {{LBS_UUID_SERVICE, m_lbs.uuid_type}};
        // Build and set advertising data.
        memset(&advdata, 0, sizeof(advdata));
        advdata.name_type          = BLE_ADVDATA_FULL_NAME;
        advdata.include_appearance = true;
        advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
        memset(&srdata, 0, sizeof(srdata));
        srdata.uuids_complete.uuid_cnt = sizeof(adv_uuids) / sizeof(adv_uuids[0]);
        srdata.uuids_complete.p_uuids  = adv_uuids;
        err_code = ble_advdata_encode(&advdata, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len);
        // Start advertising.
        memset(&adv_params, 0, sizeof(adv_params));
        adv_params.p_peer_addr   = NULL;
        adv_params.filter_policy = BLE_GAP_ADV_FP_ANY;
        adv_params.interval      = APP_ADV_INTERVAL;
        adv_params.properties.type = BLE_GAP_ADV_TYPE_CONNECTABLE_SCANNABLE_UNDIRECTED;
        adv_params.duration        = APP_ADV_DURATION;
        adv_params.primary_phy     = BLE_GAP_PHY_1MBPS;
        err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &adv_params);
  • Hi Vidar,
    Can I create a private case ticket? So I can upload everything for your reference.
    Thanks a lot!
    -Lei
  • Hi Lei,
    Yes, please do. It's probably easier if I can debug it here. Just create a new private ticket. I'll assign it to myself tomorrow.
  • What is the cause of the problem?The problems I am currently facing are the same as yours
  •   , this case is pretty old. Please create a new thread with information about your setup and a description of the problem you're experiencing.
