Hello there,
First of all, I had searched similar issue internally but didn't find any solution.
My problem is for my application with DFU buttonless without bond everything is okay. So I just followed the instruction (https://devzone.nordicsemi.com/nordic/short-range-guides/b/software-development-kit/posts/getting-started-with-nordics-secure-dfu-bootloader#h61sjziauupw1j397q9s9ldr01q4j6d5) to add bond. It seemed pretty straightforward. The program stuck at
err_code = ble_dfu_buttonless_init(&dfus_init);
Here is the debug info
"<00> info> app: Setting vector table to bootloader: 0x00078000
<00> debug> app: nrf_dfu_svci_vector_table_set() -> success
<00> debug> app: nrf_dfu_set_peer_data_init() -> success
<00> info> app: Setting vector table to main app: 0x00026000
<00> debug> app: nrf_dfu_svci_vector_table_unset() -> success
<00> error> app: ERROR 8 [NRF_ERROR_INVALID_STATE] at ..\..\..\main.c:777 00> PC at: 0x00031A4B
<00> error> app: End of error report
here is where ble_dfu_buttonless_init located in my code
ret_code_t err_code;
ble_lbs_init_t init;
ble_nus_init_t nus_init;
ble_dfu_buttonless_init_t dfus_init = {0};
// Initialize Queued Write Module instances.
for (uint32_t i = 0; i < LINK_TOTAL; i++)
err_code = nrf_ble_qwr_init(&m_qwr[i], &qwr_init);
//Initialize DFU
// Initialize the async SVCI interface to bootloader.
err_code = ble_dfu_buttonless_async_svci_init();
dfus_init.evt_handler = ble_dfu_evt_handler;
// Initialize LBS.
init.led_write_handler = led_write_handler;
err_code = ble_lbs_init(&m_lbs, &init);
// Initialize NUS.
ble_conn_state_init();
Here is main function
bool erase_bonds;
// Initialize.
err_code = clock_config();
uart_init();
log_init();
timers_init();
leds_init();
buttons_init();
power_management_init();
ble_stack_init();
gap_params_init();
gatt_init();
services_init();
advertising_init();
conn_params_init();
peer_manager_init(erase_bonds);
start_app_timer();
advertising_start(erase_bonds);
// Enter main loop.
for (;;)
idle_state_handle();
Then I used ble_app_buttonless_dfu example and changed sdk_config.h to bond. It also worked fine.
So it must be something wrong with my services_init(). But I just cannot figure it out.
Thank you.
