SoftDevice S132 stack usage V7.0.1/V7.2.0
Hi all,
I was wondering what the correct stack usage of the S132 is?
In the release notes for both V7.0.1 and V7.2.0 it says:
"The worst-case stack usage for the SoftDevice is 1.75 kB (0x700 bytes)."
But when I check the SoftDevice Specification (S132_SDS_v7.1) in chapter 14.1, table 29. It states the maximum stack usage as 1536 bytes (0x600).
I can imagine, that the value in the SDS was not updated and is therfore still the old value.
Maybe you can confirm that.
Thank you in advance!
Pascal
    I can see from the s132 releases notes for v7.0.0 vs v7.0.1:
    Call stack: The SoftDevice uses a call stack combined with the application. The worst-case stack usage for the SoftDevice is 1.5 kB (0x600 bytes). Application writers should ensure that enough stack space is reserved to cover the worst-case SoftDevice call stack usage combined with the worst-case application call stack usage.
    Call stack: The SoftDevice uses a call stack combined with the application. Update 1: The worst-case stack usage for the SoftDevice is 1.75 kB (0x700 bytes). Application writers should ensure that enough stack space is reserved to cover the worst-case SoftDevice call stack usage combined with the worst-case application call stack usage.
    Hereby confirmed.
    Kenneth
  • Hi Kenneth
    Perfect! Thank you for quickly confirming this!
    Pascal
