Hello !
I am working on the asset tracker project on NCS 1.4.0. Since I switched to this NCS, I have an error that comes up very often (once in two or once in three): get-addrinfo error 11. Here is the outlog :
[00:00:00.212,280] [0m<inf> asset_tracker: Asset tracker started
[0m[00:00:00.218,597] [0m<inf> watchdog: Watchdog timeout installed. Timeout: 60000[0m[00:00:00.226,318]
[0m<inf> watchdog: Watchdog started[0m[00:00:00.231,689] [0m<inf> watchdog: Watchdog feed enabled. Timeout: 30000
[0m[00:00:00.245,910] [0m<dbg> nrf_cloud_transport.nct_client_id_get: client_id = nrf-352656100371973
[0m[00:00:00.261,993] [0m<dbg> nrf9160_gps.configure_antenna: MAGPIO set: AT%XMAGPIO=1,0,0,1,1,1565,1586
[0m[00:00:00.277,679] [0m<dbg> nrf9160_gps.configure_antenna: COEX0 set: AT%XCOEX0=1,1,1565,1586
[0m[00:00:00.286,499] [0m<dbg> nrf9160_gps.open_socket: GPS socket created, fd: 1232491587
[0m[00:00:00.294,830] [0m<inf> gps_control: GPS initialized
[0m[00:00:00.300,415] [0m<inf> asset_tracker: Connecting to LTE network.
[0m[00:00:00.307,098] [0m<inf> asset_tracker: This may take several minutes.
[0m+CEREG: 2,"7F4C","0843AE08",7,0,0,"11100000","11100000"[00:00:01.674,743] [0m<inf> asset_tracker: LTE cell changed: Cell ID: 138653192, Tracking area: 32588
[0m[00:00:01.684,295] [0m<inf> asset_tracker: PSM parameter update: TAU: -1, Active time: -1
[0m+CSCON: 1[00:00:01.745,086] [0m<inf> asset_tracker: RRC mode: Connected
[0m+CEREG: 5,"7F4C","0843AE08",7,,,"11100000","11100000"AT+COPS=3,2[00:00:02.485,809]
[0m<inf> asset_tracker: Connected to LTE network.[0m[00:00:02.492,614]
[0m<inf> asset_tracker: Connecting to cloud, attempt 1 of 8[0m[00:00:02.500,152]
[0m<inf> asset_tracker: Cloud connection request sent.[0m[00:00:02.507,202]
[0m<inf> asset_tracker: Connection response timeout is set to 30 seconds.
[0m[00:00:02.515,991] [0m<inf> asset_tracker: Network registration status: Connected - roaming
[0m[OK00:00:02.524,963] [0m<inf> asset_tracker: CLOUD_EVT_CONNECTING[0m[00:00:02.532,104]
[0m<dbg> nrf_cloud_transport.nct_connect: getaddrinfo failed -100[0m[00:00:02.540,100]
[0m<inf> asset_tracker: CLOUD_EVT_CONNECTING[0m[00:00:02.546,264] [1;31m<err> asset_tracker: Failed to connect to cloud, error -3
[0m[00:00:02.554,077] [1;31m<err> asset_tracker: Network error, check cloud configuration
[0m[00:00:02.562,255] [1;31m<err> asset_tracker: Device will reboot in 300 seconds
[0m[00:00:02.569,824] [1;31m<err> asset_tracker: LTE link disconnect
[0m[00:00:02.625,488] [1;33m<wrn> date_time: sntp_query, error: -115
[0m[00:00:02.632,141] [1;33m<wrn> date_time: getaddrinfo, error: -11
[0m+CEREG: 0,"7F4C","0843AE08",7,0,0,"11100000","11100000"[00:00:02.638,885] [1;33m<wrn> date_time: getaddrinfo, error: -11
[0m[00:00:02.650,939] [1;33m<wrn> date_time: getaddrinfo, error: -11
[0m[00:00:02.657,501] [1;33m<wrn> date_time: getaddrinfo, error: -11
[0m[00:00:02.663,848] [1;33m<wrn> date_time: Not getting time from any NTP server
[0m[00:00:02.671,325] [0m<inf> asset_tracker: DATE_TIME_NOT_OBTAINED
[0m+CSCON: 0[00:00:03.910,919]
[0m<inf> asset_tracker: RRC mode: Idle
[0m[00:00:04.095,184] [1;31m<err> asset_tracker: Shutdown modem
What could this be due to? Is it the network that "rejects" me because I did not disconnect correctly?
Thanks by avace,
best regards,
