serial_lte_modem app gets stuck after multiple AT#XHTTPCREQ commands
We are using nrf9160 as an LTE-M modem with the serial_lte_modem app running on it. Another chip (ESP32) communicates with it using AT commands and after a few minutes of successful communication (~tens of AT#XHTTPCREQ commands) the nrf chip gets stuck and no longer responds to requests.
serial_lte_modem & sdk version: 1.4.0
modem fw version: 1.2.2
network: NB-IOT, Vodafone Czech Republic
nrf log:
00> [00:05:52.526,519] <inf> httpc: Partial data received (235 bytes)
00> [00:05:52.557,861] <inf> httpc: Partial data received (42 bytes)
00> [00:05:52.557,861] <inf> httpc: All the data received (277 bytes)
00> [00:05:52.622,161] <inf> at_host: RX_DISABLED
00> [00:05:52.635,223] <inf> httpc: send header: 20 bytes
00> [00:05:52.635,620] <inf> httpc: wait until payload is ready
00> [00:05:52.644,042] <inf> httpc: send 51 bytes payload
00> [00:05:52.644,195] <inf> at_host: RX_DISABLED
00> [00:05:52.644,226] <wrn> at_host: UART RX buf rsp: -13
00> [00:05:52.644,317] <err> at_cmd: Invalid command
00> [00:05:52.644,317] <err> at_host: AT command error: -22
00> [00:05:52.646,118] <inf> at_host: RX_DISABLED
following two lines repeat aprox. 500 times:
00> [00:05:52.647,827] <err> at_cmd: Invalid command
00> [00:05:52.647,827] <err> at_host: AT command error: -22
00> [00:05:53.708,984] <inf> httpc: Partial data received (277 bytes)
00> [00:05:53.708,984] <inf> httpc: All the data received (277 bytes)
Sometimes the nrf chip reboots on its own, but most of the time it gets stuck and manual reboot is required.
The log contains `[00:04:22.522,003] <wrn> at_host: UART RX buf rsp: -13` but we have also captured logs without this error.
  • Thanks for the trace and the logs. From what I can see the modem crashes at some point, but I have forwarded the trace to the modem team so they can have a look. In the meantime, could you enable debug messages for the RTT log? Change/add the following to prj.conf:
    CONFIG_AT_CMD_LOG_LEVEL_DBG=y
    CONFIG_SLM_LOG_LEVEL_DBG=y
    This could give some more insight to what's happening.
    The watchdog solution is not ideal, but I'm glad that it works.
    Carl Richard
  • I was unable to enable debug as the app then started crashing on stack overflow exception. So I've just replaced DBG logs to INF.
    This is the end of the log collected over RTT:
    00> 23 58 48 54 54 50 43 43  4f 4e 3a 30 0d 0a       |#XHTTPCC ON:0..
    00> [00:06:11.588,409] <inf> at_host: TX
    00> 4f 4b 0d 0a                                      |OK..
    00> [00:06:11.594,573] <inf> at_host: RX
    00> 41 54 23 58 48 54 54 50  43 43 4f 4e 3d 31 2c 22 |AT#XHTTP CCON=1,"
    00> 69 6e 67 72 65 73 73 2e  64 65 76 2e 74 65 6d 70 |ingress. dev.temp
    00> 65 67 67 2e 63 6f 6d 22  2c 38 30                |egg.com" ,80
    00> [00:06:11.594,940] <inf> httpc: Connect from http server
    00> [00:06:11.595,062] <inf> at_host: RX_DISABLED
    00> [00:06:12.105,895] <err> httpc: Failed to resolve hostname ingress.dev.tempegg.com on IPv6
    00> [00:06:12.121,826] <inf> httpc: Attempting to connect over IPv4
    00> [00:06:12.312,316] <inf> httpc: Connected to ingress.dev.tempegg.com
    00> [00:06:12.312,316] <inf> httpc: Configuring socket timeout (10 s)
    00> [00:06:12.312,377] <inf> at_host: TX
    00> 23 58 48 54 54 50 43 43  4f 4e 3a 31 0d 0a       |#XHTTPCC ON:1..
    00> [00:06:12.329,528] <inf> at_host: TX
    00> [00:06:12.337,188] <inf> at_host: RX_DISABLED
    00> [00:06:12.339,050] <inf> at_host: RX
    00> 41 54 23 58 48 54 54 50  43 52 45 51 3d 22 50 4f |AT#XHTTP CREQ="PO
    00> 53 54 22 2c 22 2f 61 75  74 68 22 2c 22 43 6f 6e |ST","/au th","Con
    00> 74 65 6e 74 2d 4c 65 6e  67 74 68 3a 20 35 31 0d |tent-Len gth: 51.
    00> 0a 22 2c 35 31                                   |.",51
    00> [00:06:12.339,508] <inf> at_host: TX
    00> [00:06:12.340,301] <inf> httpc: send header: 20 bytes
    00> [00:06:12.358,306] <inf> at_host: TX
    00> 23 58 48 54 54 50 43 52  45 51 3a 31 0d 0a       |#XHTTPCR EQ:1..
    00> [00:06:12.358,306] <inf> httpc: wait until payload is ready
    00> [00:06:12.365,814] <inf> at_host: RX
    00> 7b 22 64 61 74 61 22 3a  22 30 30 31 31 32 32 33 |{"data": "0011223
    00> 33 34 34 35 35 36 36 37  37 38 38 39 39 41 41 42 |34455667 78899AAB
    00> 42 43 43 44 44 45 45 46  46 30 30 30 30 30 30 30 |BCCDDEEF F0000000
    00> 31 22 7d                                         |1"}
    00> [00:06:12.366,302] <inf> at_host: RX_DISABLED
    00> [00:06:12.366,973] <inf> httpc: send 51 bytes payload
    00> [00:06:12.367,004] <inf> at_host: TX
    00> [00:06:12.367,431] <inf> at_host: TX
    00> 23 58 48 54 54 50 43 52  45 51 3a 30 0d 0a       |#XHTTPCR EQ:0..
    00> [00:06:13.033,752] <inf> httpc: Partial data received (277 bytes)
    00> [00:06:13.033,782] <inf> httpc: All the data received (277 bytes)
    00> [00:06:13.033,843] <inf> at_host: TX
    00> 23 58 48 54 54 50 43 52  53 50 3a 32 37 37 2c 30 |#XHTTPCR SP:277,0
    00> 0d 0a                                            |..
    00> [00:06:13.042,541] <inf> at_host: TX
    00> 48 54 54 50 2f 31 2e 31  20 32 30 30 20 4f 4b 0d |HTTP/1.1  200 OK.
    00> 0a 43 6f 6e 74 65 6e 74  2d 4c 65 6e 67 74 68 3a |.Content -Length:
    00> 20 38 36 0d 0a 43 6f 6e  74 65 6e 74 2d 54 79 70 | 86..Con tent-Typ
    00> 65 3a 20 61 70 70 6c 69  63 61 74 69 6f 6e 2f 6a |e: appli cation/j
    00> 73 6f 6e 3b 20 63 68 61  72 73 65 74 3d 75 74 66 |son; cha rset=utf
    00> 2d 38 0d 0a 52 65 71 75  65 73 74 2d 43 6f 6e 74 |-8..Requ est-Cont
    00> 65 78 74 3a 20 61 70 70  49 64 3d 63 69 64 2d 76 |ext: app Id=cid-v
    00> 31 3a 66 32 66 61 65 37  35 66 2d 63 35 31 65 2d |1:f2fae7 5f-c51e-
    00> 34 38 37 63 2d 61 37 34  30 2d 32 39 63 33 31 36 |487c-a74 0-29c316
    00> 37 37 38 38 31 65 0d 0a  44 61 74 65 3a 20 54 68 |77881e.. Date: Th
    00> 75 2c 20 31 32 20 4e 6f  76 20 32 30 32 30 20 32 |u, 12 No v 2020 2
    00> 32 3a 31 34 3a 34 30 20  47 4d 54 0d 0a 0d 0a 7b |2:14:40  GMT....{
    00> 22 64 61 74 61 22 3a 22  33 35 38 32 65 32 31 39 |"data":" 3582e219
    00> 32 39 30 30 39 39 64 38  62 34 38 62 66 61 34 38 |290099d8 b48bfa48
    00> 31 34 38 65 39 64 35 34  32 33 34 64 65 63 37 31 |148e9d54 234dec71
    00> 65 37 62 34 30 34 62 38  32 38 64 66 33 66 66 36 |e7b404b8 28df3ff6
    00> 32 62 34 35 37 65 63 32  22 2c 22 63 6d 64 22 3a |2b457ec2 ","cmd":
    00> 6e 75 6c 6c 7d                                   |null}
    00> [00:06:13.075,561] <inf> at_host: RX_DISABLED
    00> [00:06:13.081,695] <inf> at_host: RX
    00> 41 54 23 58 48 54 54 50  43 43 4f 4e 3f          |AT#XHTTP CCON?
    00> [00:06:13.082,031] <inf> at_host: TX
    00> 23 58 48 54 54 50 43 43  4f 4e 3a 20 31 2c 22 69 |#XHTTPCC ON: 1,"i
    00> 6e 67 72 65 73 73 2e 64  65 76 2e 74 65 6d 70 65 |ngress.d ev.tempe
    00> 67 67 2e 63 6f 6d 22 2c  38 30 0d 0a             |gg.com", 80..
    00> [00:06:13.085,998] <inf> at_host: TX
    00> [00:06:13.090,118] <inf> at_host: RX
    00> 41 54 23 58 48 54 54 50  43 43 4f 4e 3d 30       |AT#XHTTP CCON=0
    00> [00:06:13.090,362] <inf> httpc: Disconnect from http server
    00> [00:06:13.090,362] <inf> httpc: Closing socket 1
    00> [00:06:13.090,637] <inf> at_host: RX_DISABLED
    00> [00:06:13.090,728] <inf> at_host: TX
    00> [00:06:13.100,677] <inf> at_host: TX
    00> [00:06:13.106,842] <inf> at_host: RX
    00> [00:06:13.107,208] <inf> httpc: Connect from http server
    00> [00:06:13.107,330] <inf> at_host: RX_DISABLED
    00> [00:06:14.072,418] <err> httpc: Failed to resolve hostname ingress.dev.tempegg.com on IPv6
    00> [00:06:14.325,744] <inf> httpc: Attempting to connect over IPv4
    00> [00:06:14.427,337] <inf> httpc: Connected to ingress.dev.tempegg.com
    00> [00:06:14.427,368] <inf> httpc: Configuring socket timeout (10 s)
    00> [00:06:14.427,398] <inf> at_host: TX
    00> [00:06:14.444,915] <inf> at_host: TX
    00> [00:06:14.452,117] <inf> at_host: RX
    00> [00:06:14.452,575] <inf> at_host: RX_DISABLED
    00> [00:06:14.452,606] <inf> at_host: TX
    00> [00:06:14.453,399] <inf> httpc: send header: 20 bytes
    00> [00:06:14.472,717] <inf> at_host: TX
    00> [00:06:14.472,747] <inf> httpc: wait until payload is ready
    00> [00:06:14.479,919] <inf> at_host: RX
    00> 31 22 7d                                         |1"}
    00> [00:06:14.480,407] <inf> at_host: RX_DISABLED
    00> [00:06:14.481,475] <inf> httpc: send 51 bytes payload
    00> [00:06:14.481,506] <inf> at_host: TX
    00> [00:06:14.481,933] <inf> at_host: TX
    00> [00:06:24.451,202] <inf> at_host: RX_DISABLED
    00> [00:06:25.460,388] <inf> at_host: RX
    00> [00:06:25.460,754] <inf> at_host: TX
    00> [00:06:25.464,691] <inf> at_host: TX
    00> [00:06:25.468,811] <inf> at_host: RX
    00> [00:06:25.469,055] <inf> httpc: Disconnect from http server
    00> [00:06:25.469,055] <inf> httpc: Closing socket 1
    00> [00:06:25.469,329] <inf> at_host: RX_DISABLED
    After that it reboots. Unfortunately I've found that the watchdog does not always work. When the ESP reboots, it sends garbage over the UART, nRF gets stuck, but never reboots.
  • Hi!
    Apologies for the delay. We have been awaiting a response from the developers, whom are now working on the issue. Could you try to get the log (similarily to your other case), so that we may get some more insight into what's happening. The prj.conf is as follows:
    CONFIG_LOG_IMMEDIATE=y
    CONFIG_NET_LOG=y
    CONFIG_NET_SOCKETS_LOG_LEVEL_DBG=n
    CONFIG_NET_HTTP_LOG_LEVEL_DBG=y
    Thank you for your patience and best regards,
    Carl Richard
  • Hi again!
    The developer suggested that the updated slm_at_httpc.c from your other ticket should mitigate this issue as well. Please report back if that's not the case.
    Carl Richard
  • Hi, unfortunately it does not resolve this issue for us. I have tried to capture a better log than the one I send you, but without any luck. The new log just contains additional http request logging.
    In the meantime we have found out a possible workaround - adding sleep after each response from AT is read. It definetly improves the issue, but of course it does not solve the root cause.
    Thank you for your help, BR, Michal V.
    00> 41 54 23 58 48 54 54 50  43 43 4f 4e 3d 31 2c 22 |AT#XHTT[00:07:03.963,653] <inf> at_host: RX_DISABLED
    00> P CCON=1,"
    00> 69 6e 67 72 65 73 73 2e  67 77 78 63 6c 6f 75 64 |ingress. gwxcloud
    00> 2e 63 6f 6d 22 2c 38 30                          |.com",80
    00> [00:07:03.966,461] <inf> httpc: Attempting to connect over IPv6
    00> [00:07:03.968,719] <err> httpc: Unable to connect, errno 114
    00> [00:07:03.970,336] <inf> httpc: Attempting to connect over IPv4
    00> [00:07:04.510,040] <inf> httpc: Connected to ingress.gwxcloud.com
    00> [00:07:04.510,345] <inf> at_host: TX
    00> [00:07:04.526,184] <inf> at_host: TX
    00> [00:07:04.535,919] <inf> at_host: RX_DISABLED
    00> [00:07:04.537,353] <inf> at_host: RX
    00> 74 65 6e 74 2d 4c 65 6e  67 74 68 3a 20 31 31 38 |tent-Len gth: 118
    00> 0d 0a 22 2c 31 31 38                             |..",118
    00> [00:07:04.539,459] <inf> at_host: TX
    00> [00:07:04.540,039] <dbg> net_http.Data to send
    00> 50 4f 53 54 20 2f 61 75  74 68 20 48 54 54 50 2f |POST /au th HTTP/
    00> 31 2e 31 0d 0a 48 6f 73  74 3a 20 69 6e 67 72 65 |1.1..Hos t: ingre
    00> 73 73 2e 67 77 78 63 6c  6f 75 64 2e 63 6f 6d 0d |ss.gwxcl oud.com.
    00> 0a                                               |.
    00> [00:07:04.544,525] <dbg> net_http.Data to send
    00> 0d 0a                                            |..
    00> [00:07:04.559,051] <inf> at_host: TX
    00> [00:07:04.573,333] <inf> a[00:07:04.573,852] <inf> at_host: RX_DISABLED
    00> t_host: RX
    00> 7b 60 64 61 74 61 60 3a  60 39 41 34 30 44 43 39 |{`data`: `9A40DC9
    00> 44 32 31 45 39 30 42 39  32 43 30 39 36 35 39 37 |D21E90B9 2C096597
    00> 45 39 35 43 37 42 39 36  41 30 30 41 30 30 30 34 |E95C7B96 A00A0004
    00> 30 60 2c 60 64 65 62 75  67 60 3a 7b 60 76 45 53 |0`,`debu g`:{`vES
    00> 50 60 3a 60 31 2e 36 2e  32 60 2c 60 76 4e 52 46 |P`:`1.6. 2`,`vNRF
    00> 60 3a 60 31 2e 36 2e 30  60 2c 60 77 69 66 69 5f |`:`1.6.0 `,`wifi_
    00> 72 73 73 69 60 3a 30 2c  60 75 70 74 69 6d 65 60 |rssi`:0, `uptime`
    00> 3a 34 32 34 7d 7d                                |:424}}
    00> [00:07:04.579,162] <inf> at_host: TX
    00> [00:07:04.580,413] <inf> at_host: TX
    00> [00:07:04.580,963] <dbg> net_http.http_client_req: (0x20021628): Sent 190 bytes
    00> [00:07:05.343,231] <dbg> net_http.on_message_begin: (0x20021628): -- HTTP POST response (headers) --
    00> [00:07:05.345,062] <dbg> net_http.on_status: (0x20021628): HTTP response status 200 OK
    00> [00:07:05.345,825] <dbg> net_http.print_header_field: (0x20021628): [4] Date
    00> [00:07:05.346,557] <dbg> net_http.print_header_field: (0x20021628): [29] Tue, 01 Dec 2020 13:46:08 GMT
    00> [00:07:05.347,351] <dbg> net_http.print_header_field: (0x20021628): [12] Content-Type
    00> [00:07:05.348,083] <dbg> net_http.print_header_field: (0x20021628): [31] application/json; charset=utf-8
    00> [00:07:05.348,876] <dbg> net_http.print_header_field: (0x20021628): [17] Transfer-Encoding
    00> [00:07:05.349,639] <dbg> net_http.print_header_field: (0x20021628): [7] chunked
    00> [00:07:05.350,311] <dbg> net_http.print_header_field: (0x20021628): [10] Connection
    00> [00:07:05.351,013] <dbg> net_http.print_header_field: (0x20021628): [10] keep-alive
    00> [00:07:05.351,715] <dbg> net_http.print_header_field: (0x20021628): [10] Set-Cookie
    00> [00:07:05.352,416] <dbg> net_http.print_header_field: (0x20021628): [127] __cfduid=df6d2cea734298689b4474c814bfcc0b51606830368; expires=Thu, 31-Dec-20 13:46:08 GMT; path=/; domain=.gwxcloud.com; HttpOn
    00> [00:07:05.353,393] <dbg> net_http.print_header_field: (0x20021628): [4] Vary
    00> [00:07:05.355,895] <dbg> net_http.print_header_field: (0x20021628): [15] Accept-Encoding
    00> [00:07:05.356,872] <dbg> net_http.print_header_field: (0x20021628): [15] CF-Cache-Status
    00> [00:07:05.357,513] <dbg> net_http.print_header_field: (0x20021628): [7] DYNAMIC
    00> [00:07:05.358,093] <dbg> net_http.print_header_field: (0x20021628): [13] cf-request-id
    00> [00:07:05.359,191] <dbg> net_http.print_header_field: (0x20021628): [32] 06c026bee1000072879cb90000000001
    00> [00:07:05.360,198] <dbg> net_http.print_header_field: (0x20021628): [9] Report-To
    00> [00:07:05.361,083] <dbg> net_http.print_header_field: (0x20021628): [127] {"endpoints":[{"url":"https:\/\/a.nel.cloudflare.com\/report?s=QLHQt3De14vfKIZEAM%2B2tQ%2BidFbctYw3mT%2Bc2oZGo6f9qe6tfp6RfGAo2z
    00> [00:07:05.361,877] <dbg> net_http.print_header_field: (0x20021628): [3] NEL
    00> [00:07:05.362,335] <dbg> net_http.print_header_field: (0x20021628): [39] {"report_to":"cf-nel","max_age":604800}
    00> [00:07:05.362,854] <dbg> net_http.print_header_field: (0x20021628): [6] Server
    00> [00:07:05.369,079] <dbg> net_http.print_header_field: (0x20021628): [4] clou
    00> [00:07:05.407,226] <dbg> net_http.print_header_field: (0x20021628): [6] dflare
    00> [00:07:05.407,714] <dbg> net_http.print_header_field: (0x20021628): [6] CF-RAY
    00> [00:07:05.441,711] <dbg> net_http.print_header_field: (0x20021628): [20] 5fad40ab0efb7287-AMS
    00> [00:07:05.442,108] <dbg> net_http.on_headers_complete: (0x20021628): No body expected
    00> [00:07:05.442,749] <dbg> net_http.on_message_complete: (0x20021628): -- HTTP POST response (complete) --
    00> [00:07:05.443,206] <inf> at_host: TX
    00> 23 58 48 54 54 50 43 52  53 50 3a 38 34 30 2c 30 |#XHTTPCR SP:840,0
    00> 0d 0a                                            |..
    00> [00:07:05.445,678] <inf> at_host: TX
    00> 0a 44 61 74 65 3a 20 54  75 65 2c 20 30 31 20 44 |.Date: T ue, 01 D
    00> 65 63 20 32 30 32 30 20  31 33 3a 34 36 3a 30 38 |ec 2020  13:46:08
    00> 20 47 4d 54 0d 0a 43 6f  6e 74 65 6e 74 2d 54 79 | GMT..Co ntent-Ty
    00> 70 65 3a 20 61 70 70 6c  69 63 61 74 69 6f 6e 2f |pe: appl ication/
    00> 6a 73 6f 6e 3b 20 63 68  61 72 73 65 74 3d 75 74 |json; ch arset=ut
    00> 66 2d 38 0d 0a 54 72 61  6e 73 66 65 72 2d 45 6e |f-8..Tra nsfer-En
    00> 63 6f 64 69 6e 67 3a 20  63 68 75 6e 6b 65 64 0d |coding:  chunked.
    00> 0a 43 6f 6e 6e 65 63 74  69 6f 6e 3a 20 6b 65 65 |.Connect ion: kee
    00> 70 2d 61 6c 69 76 65 0d  0a 53 65 74 2d 43 6f 6f |p-alive. .Set-Coo
    00> 6b 69 65 3a 20 5f 5f 63  66 64 75 69 64 3d 64 66 |kie: __c fduid=df
    00> 36 64 32 63 65 61 37 33  34 32 39 38 36 38 39 62 |6d2cea73 4298689b
    00> 34 34 37 34 63 38 31 34  62 66 63 63 30 62 35 31 |4474c814 bfcc0b51
    00> 36 30 36 38 33 30 33 36  38 3b 20 65 78 70 69 72 |60683036 8; expir
    00> 65 73 3d 54 68 75 2c 20  33 31 2d 44 65 63 2d 32 |es=Thu,  31-Dec-2
    00> 30 20 31 33 3a 34 36 3a  30 38 20 47 4d 54 3b 20 |0 13:46: 08 GMT;
    00> 70 61 74 68 3d 2f 3b 20  64 6f 6d 61 69 6e 3d 2e |path=/;  domain=.
    00> 67 77 78 63 6c 6f 75 64  2e 63 6f 6d 3b 20 48 74 |gwxcloud .com; Ht
    00> 74 70 4f 6e 6c 79 3b 20  53 61 6d 65 53 69 74 65 |tpOnly;  SameSite
    00> 3d 4c 61 78 0d 0a 56 61  72 79 3a 20 41 63 63 65 |=Lax..Va ry: Acce
    00> 70 74 2d 45 6e 63 6f 64  69 6e 67 0d 0a 43 46 2d |pt-Encod ing..CF-
    00> 43 61 63 68 65 2d 53 74  61 74 75 73 3a 20 44 59 |Cache-St atus: DY
    00> 4e 41 4d 49 43 0d 0a 63  66 2d 72 65 71 75 65 73 |NAMIC..c f-reques
    00> 74 2d 69 64 3a 20 30 36  63 30 32 36 62 65 65 31 |t-id: 06 c026bee1
    00> 30 30 30 30 37 32 38 37  39 63 62 39 30 30 30 30 |00007287 9cb90000
    00> 30 30 30 30 30 31 0d 0a  52 65 70 6f 72 74 2d 54 |000001.. Report-T
    00> 6f 3a 20 7b 22 65 6e 64  70 6f 69 6e 74 73 22 3a |o: {"end points":
    00> 5b 7b 22 75 72 6c 22 3a  22 68 74 74 70 73 3a 5c |[{"url": "https:\
    00> 2f 5c 2f 61 2e 6e 65 6c  2e 63 6c 6f 75 64 66 6c |/\/a.nel .cloudfl
    00> 61 72 65 2e 63 6f 6d 5c  2f 72 65 70 6f 72 74 3f |are.com\ /report?
    00> 73 3d 51 4c 48 51 74 33  44 65 31 34 76 66 4b 49 |s=QLHQt3 De14vfKI
    00> 5a 45 41 4d 25 32 42 32  74 51 25 32 42 69 64 46 |ZEAM%2B2 tQ%2BidF
    00> 62 63 74 59 77 33 6d 54  25 32 42 63 32 6f 5a 47 |bctYw3mT %2Bc2oZG
    00> 6f 36 66 39 71 65 36 74  66 70 36 52 66 47 41 6f |o6f9qe6t fp6RfGAo
    00> 32 7a 41 38 7a 25 32 46  6d 74 4e 47 78 72 44 66 |2zA8z%2F mtNGxrDf
    00> 51 77 78 55 6f 5a 36 6d  4b 53 5a 6f 6e 42 56 7a |QwxUoZ6m KSZonBVz
    00> 67 4a 31 48 73 30 4b 6e  69 61 50 71 4f 46 68 51 |gJ1Hs0Kn iaPqOFhQ
    00> 53 52 4a 6d 79 7a 62 61  64 49 4b 77 25 33 44 25 |SRJmyzba dIKw%3D%
    00> 33 44 22 7d 5d 2c 22 67  72 6f 75 70 22 3a 22 63 |3D"}],"g roup":"c
    00> 66 2d 6e 65 6c 22 2c 22  6d 61 78 5f 61 67 65 22 |f-nel"," max_age"
    00> 3a 36 30 34 38 30 30 7d  0d 0a 4e 45 4c 3a 20 7b |:604800} ..NEL: {
    00> 22 72 65 70 6f 72 74 5f  74 6f 22 3a 22 63 66 2d |"report_ to":"cf-
    00> 6e 65 6c 22 2c 22 6d 61  78 5f 61 67 65 22 3a 36 |nel","ma x_age":6
    00> 30 34 38 30 30 7d 0d 0a  53 65 72 76 65 72 3a 20 |04800}.. Server:
    00> 63 6c 6f 75 64 66 6c 61  72 65 0d 0a 43 46 2d 52 |cloudfla re..CF-R
    00> 41 59 3a 20 35 66 61 64  34 30 61 62 30 65 66 62 |AY: 5fad 40ab0efb
    00> 37 32 38 37 2d 41 4d 53  0d 0a 0d 0a 35 36 0d 0a |7287-AMS ....56..
    00> 7b 22 64 61 74 61 22 3a  22 62 39 65 63 31 66 37 |{"data": "b9ec1f7
    00> 62 63 61 62 61 37 64 35  36 30 33 65 66 33 63 35 |bcaba7d5 603ef3c5
    00> 38 36 65 33 63 38 61 30  30 35 36 65 31 39 61 33 |86e3c8a0 056e19a3
    00> 62 62 65 39 38 61 64 63  63 33 63 62 36 34 63 61 |bbe98adc c3cb64ca
    00> 30 37 63 36 61 65 32 36  34 22 2c 22 63 6d 64 22 |07c6ae26 4","cmd"
    00> 3a 6e 75 6c 6c 7d 0d 0a                          |:null}..
    00> [00:07:05.487,945] <dbg> net_http.http_client_req: (0x20021628): Received 840 bytes
    00> [00:07:12.658,843] <inf> at_host: RX
    00> 41 54                                            |AT
    00> [00:07:12.659,362] <inf> at_host: RX_DISABLED
    00> [00:07:12.659,637] <inf> at_cmd: Sending command AT
    00> [00:07:12.660,034] <inf> at_cmd: Awaiting response for AT
    00> [00:07:12.661,193] <inf> at_cmd: at_cmd_rx 5 bytes, OK
    00>
    00> [00:07:12.661,437] <inf> at_cmd: Enqueueing response for sync call
    00> [00:07:12.661,743] <inf> at_host: TX
    00> [00:07:12.661,987] <inf> at_host: TX
    00> [00:07:12.662,536] <inf> at_cmd: Writing any pending command
    00> [00:07:12.662,811] <inf> at_cmd: Listening on socket
    00> [00:07:22.659,790] <inf> at_host: RX
    00> 41 54                                            |AT
    00> [00:07:22.660,308] <inf> at_host: RX_DISABLED
    00> [00:07:22.660,583] <inf> at_cmd: Sending command AT
    00> [00:07:22.660,980] <inf> at_cmd: Awaiting response for AT
    00> [00:07:22.662,109] <inf> at_cmd: at_cmd_rx 5 bytes, OK
    00>
    00> [00:07:22.662,384] <inf> at_cmd: Enqueueing response for sync call
    00> [00:07:22.662,689] <inf> at_host: TX
    00> [00:07:22.662,933] <inf> at_host: TX
    00> [00:07:22.663,452] <inf> at_cmd: Writing any pending command
    00> [00:07:22.663,726] <inf> at_cmd: Listening on socket
    00> [00:07:32.660,736] <inf> at_host: RX
    00> 41 54                                            |AT
    00> [00:07:32.661,254] <inf> at_host: RX_DISABLED
    00> [00:07:32.661,529] <inf> at_cmd: Sending command AT
    00> [00:07:32.668,029] <inf> at_cmd: Awaiting response for AT
    00> [00:07:32.669,830] <inf> at_cmd: at_cmd_rx 5 bytes, OK
    00>
    00> [00:07:32.670,104] <inf> at_cmd: Enqueueing response for sync call
    00> [00:07:32.670,410] <inf> at_host: TX
    00> [00:07:32.670,623] <inf> at_host: TX
    00> [00:07:32.671,173] <inf> at_cmd: Writing any pending command
    00> [00:07:32.671,447] <inf> at_cmd: Listening on socket
    00> [00:07:42.661,407] <inf> at_host: RX
    00> 41 54                                            |AT
    00> [00:07:42.661,926] <inf> at_host: RX_DISABLED
    00> [00:07:42.662,200] <inf> at_cmd: Sending command AT
    00> [00:07:42.668,701] <inf> at_cmd: Awaiting response for AT
    00> [00:07:42.670,501] <inf> at_cmd: at_cmd_rx 5 bytes, OK
    00>
    00> [00:07:42.670,776] <inf> at_cmd: Enqueueing response for sync call
    00> [00:07:42.671,081] <inf> at_host: TX
    00> [00:07:42.671,325] <inf> at_host: TX
    00> [00:07:42.671,844] <inf> at_cmd: Writing any pending command
    00> [00:07:42.672,119] <inf> at_cmd: Listening on socket
    00> [00:07:52.663,085] <inf> at_host: RX
    00> 41 54                                            |AT
    00> [00:07:52.663,604] <inf> at_host: RX_DISABLED
    00> [00:07:52.663,879] <inf> at_cmd: Sending command AT
    00> [00:07:52.670,379] <inf> at_cmd: Awaiting response for AT
    00> [00:07:52.672,180] <inf> at_cmd: at_cmd_rx 5 bytes, OK
    00>
    00> [00:07:52.672,454] <inf> at_cmd: Enqueueing response for sync call
    00> [00:07:52.672,760] <inf> at_host: TX
    00> [00:07:52.673,004] <inf> at_host: TX
    00> [00:07:52.673,553] <inf> at_cmd: Writing any pending command
    00> [00:07:52.673,797] <inf> at_cmd: Listening on socket
    00> [00:07:56.733,245] <wrn> at_host: RX_STOPPED (4)
    00> [00:07:56.733,489] <wrn> at_host: RX_STOPPED (8)
    00> [00:07:56.733,734] <wrn> at_host: RX_STOPPED (4)
    00> [00:07:56.733,978] <wrn> at_host: RX_STOPPED (4)
    00> [00:07:56.734,222] <inf> at_host: RX_DISABLED
