serial_lte_modem app gets stuck after multiple AT#XHTTPCREQ commands
We are using nrf9160 as an LTE-M modem with the serial_lte_modem app running on it. Another chip (ESP32) communicates with it using AT commands and after a few minutes of successful communication (~tens of AT#XHTTPCREQ commands) the nrf chip gets stuck and no longer responds to requests.
serial_lte_modem & sdk version: 1.4.0
modem fw version: 1.2.2
network: NB-IOT, Vodafone Czech Republic
nrf log:
00> [00:05:52.526,519] <inf> httpc: Partial data received (235 bytes)
00> [00:05:52.557,861] <inf> httpc: Partial data received (42 bytes)
00> [00:05:52.557,861] <inf> httpc: All the data received (277 bytes)
00> [00:05:52.622,161] <inf> at_host: RX_DISABLED
00> [00:05:52.635,223] <inf> httpc: send header: 20 bytes
00> [00:05:52.635,620] <inf> httpc: wait until payload is ready
00> [00:05:52.644,042] <inf> httpc: send 51 bytes payload
00> [00:05:52.644,195] <inf> at_host: RX_DISABLED
00> [00:05:52.644,226] <wrn> at_host: UART RX buf rsp: -13
00> [00:05:52.644,317] <err> at_cmd: Invalid command
00> [00:05:52.644,317] <err> at_host: AT command error: -22
00> [00:05:52.646,118] <inf> at_host: RX_DISABLED
following two lines repeat aprox. 500 times:
00> [00:05:52.647,827] <err> at_cmd: Invalid command
00> [00:05:52.647,827] <err> at_host: AT command error: -22
00> [00:05:53.708,984] <inf> httpc: Partial data received (277 bytes)
00> [00:05:53.708,984] <inf> httpc: All the data received (277 bytes)
Sometimes the nrf chip reboots on its own, but most of the time it gets stuck and manual reboot is required.
The log contains `[00:04:22.522,003] <wrn> at_host: UART RX buf rsp: -13` but we have also captured logs without this error.
  • I have discovered that this error happens after the ESP sends the payload of the XHTTPCREQ command. Instead of receiving #XHTTPCREQ:0 we receive something else. I have captured two different instances of this problem:
    Log #1 - Ready is received after the payload has been accepted (via OK) by the NRF. The Ready message signalizes (reboot? reinit?) of the modem, so nrf is not stuck.
    ESP>NRF91:
    AT#XHTTPCREQ="POST","/auth","Content-Length: 51
    ",51
    NRF91>ESP:OK
    NRF91>ESP:#XHTTPCREQ:1
    ESP>NRF91:
    {"data":"........."}
    NRF91>ESP:OK�Ready
    Log #2 - ERROR is received after the payload confirmation. Now the NRF modem is stuck, it never reconnects again.
    ESP>NRF91:
    ",51
    NRF91>ESP:OK
    ESP>NRF91:
    {"data":".........."}
    NRF91>ESP:OK@
    NRF91>ESP:ERROR
  • Hi, Michal!
    Thank you for the patience. I'm looking into the issue. You are correct about "Ready". It means that the modem/nrf9160 has rebooted, indicating some kind of critical error.
    While I'm at it could you manage to do a modem trace?
    Carl Richard
  • Hi Carl,
    thank you for your response.
    I'm not able to colllect the modem trace easily, as the ESP+NRF91 is on a custom board. But I have both devkits on hand, so I'll try to run the code on them and collect the trace from nrf91DK.
    BR, Michal V.
  • Hi, so I was finally able to capture the modem trace.
    trace-2020-11-12T20-37-10.321Z.bin
    The moment the modem got stuck, the trace also stopped.
    This is the log from the ESP:
    LTEM - CONNECT - to: https://WWW.XXXYYY.ZZZ/auth
    LTEM - DISCONNECT
    ESP32->AT#XHTTPCCON?
    NRF91->#XHTTPCCON: 1,"WWW.XXXYYY.ZZZ",80
    NRF91->OK
    ESP32->AT#XHTTPCCON=0
    NRF91->#XHTTPCCON:0
    NRF91->OK
    ESP32->AT#XHTTPCCON=1,"WWW.XXXYYY.ZZZ",80
    NRF91->#XHTTPCCON:1
    NRF91->OK
    TEST REQ: 109
    ",51
    OK
    #XHTTPCREQ:1
    {"data":"00112233445566778899AABBCCDDEEFF00000001"}
    7B 22 64 61 74 61 22 3A 22 30 30 31 31 32 32 33 33 34 34 35 35 36 36 37 37 38 38 39 39 41 41 42 42 43 43 44 44 45 45 46 46 30 30
    30 30 30 30 30 31 22 7D OK
    #XHTTPCREQ:0
    #XHTTPCRSP:277,0
    Received http response:
    HTTP/1.1 200 OK
    Content-Length: 86
    Content-Type: application/json; charset=utf-8
    Request-Context: appId=cid-v1:f2fae75f-c51e-487c-a740-29c31677881e
    Date: Thu, 12 Nov 2020 20:39:59 GMT
    {"data":"3582e219290099d8b48bfa48148e9d54c74827431dd3fbb46cbaa7cc983d36ab","cmd":null}@
    TEST RESPONSE:{"data":"3582e219290099d8b48bfa48148e9d54c74827431dd3fbb46cbaa7cc983d36ab","cmd":null}
    LTEM - DISCONNECT
    NRF91->OK
    NRF91->#XHTTPCCON:0
    NRF91->OK
    NRF91->
    ERROR: not entire line received!
    NRF91->
    AT COMMAND FAILED: AT#XHTTPCCON=1,"WWW.XXXYYY.ZZZ",80
    Thanks.
  • So far my only workaround is to have a watchdog timer reboot the NRF chip when it gets stuck...
