There is a problem applying the 'complementary filter' to the value of mpu6050
Hello
I use mpu6050 and I want to use a 'Complementary Filter' to get the angle of the X, Y, and Z axes.
Applying this filter to the value of mpu6050 seems to reduce noise at first and produce good results. However, after some time, the value of the Z-axis continues to grow.
It keeps getting bigger and bigger, and after a while, the value is printed out too strangely.
This is the output when the sensor is placed on the floor.  The X and Y axes seem to come out normally, but the Z axis has a strange value.
This is the code I wrote about filtering. I wrote it while referring to the example of Arduino, is there anything strange?
Or is it possible that this is a sensor problem?
//mpu6050
void mpu_init(void)
    ret_code_t ret_code;
    // Initiate MPU driver
    ret_code = app_mpu_init();
    APP_ERROR_CHECK(ret_code); // Check for errors in return value
    // Setup and configure the MPU with intial values
    app_mpu_config_t p_mpu_config = MPU_DEFAULT_CONFIG(); // Load default values
    p_mpu_config.smplrt_div = 19;   // Change sampelrate. Sample Rate = Gyroscope Output Rate / (1 + SMPLRT_DIV). 19 gives a sample rate of 50Hz
    p_mpu_config.accel_config.afs_sel = AFS_2G; // Set accelerometer full scale range to 2G
    p_mpu_config.gyro_config.fs_sel = AFS_2G; // Set gyro full scale range to 2G
    ret_code = app_mpu_config(&p_mpu_config); // Configure the MPU with above values
int16_t AcX, AcY, AcZ, Tmp, GyX, GyY, GyZ;
double mpu_accel_x, mpu_accel_y, mpu_accel_z;
double mpu_gyro_x, mpu_gyro_y, mpu_gyro_z;
float dt;
float accel_angle_x, accel_angle_y, accel_angle_z;
float gyro_angle_x, gyro_angle_y, gyro_angle_z;
float filtered_angle_x, filtered_angle_y, filtered_angle_z;
float baseAcX, baseAcY, baseAcZ;
float baseGyX, baseGyY, baseGyZ;
static void readAccelGyro() //send to app
    uint32_t err_code;
    double angle_x, angle_y;
    accel_values_t accel_values; //mpu6050
    gyro_values_t gyro_values;
    app_mpu_read_accel(&accel_values);
    err_code = app_mpu_read_accel(&accel_values);
    app_mpu_read_gyro(&gyro_values);
    err_code = app_mpu_read_gyro(&gyro_values);
    mpu_accel_x = accel_values.x;
    mpu_accel_y = accel_values.y;
    mpu_accel_z = accel_values.z;
    mpu_gyro_x = gyro_values.x;
    mpu_gyro_y = gyro_values.y;
    mpu_gyro_z = gyro_values.z;
void calibAccelGyro(){
  float sumAcX = 0, sumAcY = 0, sumAcZ = 0;
  float sumGyX = 0, sumGyY = 0, sumGyZ = 0;
  readAccelGyro();
  for(int i=0; i<10; i++){
    readAccelGyro();
    sumAcX += mpu_accel_x;
    sumAcY += mpu_accel_y;
    sumAcZ += mpu_accel_z;
    sumGyX += mpu_gyro_x;
    sumGyY += mpu_gyro_y;
    sumGyZ += mpu_gyro_z;
    nrf_delay_ms(100);
  baseAcX = sumAcX / 10; baseAcY = sumAcY / 10; baseAcZ = sumAcZ / 10;
  baseGyX = sumGyX / 10; baseGyY = sumGyY / 10; baseGyZ = sumGyZ / 10;
uint32_t t_now;
uint32_t t_prev;
void initDT(){
  t_prev = app_timer_cnt_get()*1000/32768;//milli-sec
void calcDT(){
  t_now = app_timer_cnt_get()*1000/32768;//milli-sec
  dt = (t_now - t_prev) / 1000.0; //millis()
  t_prev = t_now;
void calcAccelYPR(){
  float accel_x, accel_y, accel_z;
  float accel_xz, accel_yz;
  const float RADIANS_TO_DEGREES = 180/3.14159;
  accel_x = mpu_accel_x - baseAcX;
  accel_y = mpu_accel_y - baseAcY;
  accel_z = mpu_accel_z + (16384 - baseAcZ);
  accel_yz = sqrt(pow(accel_y, 2) + pow(accel_z, 2));
  accel_angle_y = atan(-accel_x / accel_yz)*RADIANS_TO_DEGREES;
  accel_xz = sqrt(pow(accel_x, 2) + pow(accel_z, 2));
  accel_angle_x = atan(accel_y / accel_xz)*RADIANS_TO_DEGREES;
  accel_angle_z = 0;
float gyro_x, gyro_y, gyro_z;
void calcGyroYPR(){
  const float GYROXYZ_TO_DEGREES_PER_SED = 131;
  gyro_x = (mpu_gyro_x - baseGyX) / GYROXYZ_TO_DEGREES_PER_SED;
  gyro_y = (mpu_gyro_y - baseGyY) / GYROXYZ_TO_DEGREES_PER_SED;
  gyro_z = (mpu_gyro_z - baseGyZ) / GYROXYZ_TO_DEGREES_PER_SED;
  gyro_angle_x += gyro_x * dt;
  gyro_angle_y += gyro_y * dt;
  gyro_angle_z += gyro_z * dt;
void calcFilteredYPR(){
  const float ALPHA = 0.96;
  float tmp_angle_x, tmp_angle_y, tmp_angle_z;
  tmp_angle_x = filtered_angle_x + gyro_x * dt;
  tmp_angle_y = filtered_angle_y + gyro_y * dt;
  tmp_angle_z = filtered_angle_z + gyro_z * dt;
  filtered_angle_x = ALPHA * tmp_angle_x + (1.0 - ALPHA) * accel_angle_x;
  filtered_angle_y = ALPHA * tmp_angle_y + (1.0 - ALPHA) * accel_angle_y;
  filtered_angle_z = tmp_angle_z;
  /*printf("%.1f", filtered_angle_x);
  printf(", ");
  printf("%.1f", filtered_angle_y);
  printf(", ");
  printf("%.1f", filtered_angle_z);
  printf("\n"); */
    uint32_t err_code;
    bool erase_bonds = false;
    // Initialize.
    gpio_init();
    uart_init();
    log_init();
    timers_init();
    app_buttons_init();
    power_management_init();
    ble_stack_init();
    gap_params_init();
    set_static_passkey();
    gatt_init();
    services_init();
    advertising_init();
    conn_params_init();
    peer_manager_init();
    //err_code = app_button_enable();
    err_code = app_button_disable();
    adc_configure();
    pwm_init();
    mpu_init(); //mpu6050
    bsp_board_init(BSP_INIT_LEDS); //use bsp led
    // Start execution.
    //CenterLED_timers_start();
    advertising_start(erase_bonds); //false
    //LeftLED_timers_start(); //Left Led timer
    All_Stop();
    calibAccelGyro(); //start filter
    initDT();
    pwm_change_frequency(500);
    do_play_buzzer(); //When start play buzzer
    // Enter main loop.
    for (;;)
        pm_sec_params_set(NULL); //No Security parameters
        idle_state_handle(); //if no data sleep mode
        readAccelGyro();
        calcDT();
        calcAccelYPR();
        calcGyroYPR();
        calcFilteredYPR();
        printf("%.1f", filtered_angle_x); //filter value
        printf(", ");
        printf(", ");
        printf("\n");
        nrf_delay_ms(100);
Thank you.
I think I found a problem.
The value of dt in void calcDT() comes out as a fixed value as shown below, and suddenly becomes very large.
Can you tell me the cause of this problem??
dt : 0.153000
Gyro_xyz : 0.0, 0.0, 0.0
Filter : -0.3, 0.1, -8.5
dt : 0.152000
Gyro_xyz : 0.1, 0.0, -0.0
dt : 4294836.500000
Gyro_xyz : 0.0, -0.0, 0.0
Filter : 195136.5, -31473.5, 19662.5
dt : 0.153000
Gyro_xyz : -0.0, -0.0, 0.0
Filter : 187331.0, -30214.6, 19662.5
dt : 0.153000
Gyro_xyz : -0.0, -0.0, -0.0
Filter : 179837.7, -29006.0, 19662.5
dt : 0.154000
Gyro_xyz : 0.0, -0.1, -0.0
Filter : 172644.2, -27845.7, 19662.5
