Unable to connect to nRF52840 on custom board over SWD. "No idcode detected:
Hi, I have a custom board with an nrf52840 onboard I was able to program the nrf52, but then I executed:
% nrfjprog --eraseall
and,
% nrfjprog --pinreset
and the JLink can no longer communicate with the board.  I get a "No idcode detected" on SES.  I have also tried nrfjprog --recover and it was not successful.  I thought it may be a bad board, but I now have two boards in the same state.
% nrfjprog --family NRF52 --recover
ERROR: JLinkARM DLL reported an error. Try again. If error condition
ERROR: persists, run the same command again with argument --log, contact Nordic
ERROR: Semiconductor and provide the generated log.log file to them.
All tools are the latest.
log.log:
2260.log.log
Voltage looks good.  Let me know if there is anything else that can help debug.
    How is the custom board connected to the debugger? Are you using the on-board debugger on the DK?
    When you say "Voltage looks good", what does this mean exactly? Is the custom board powered from the DK, at the same voltage level, or is it powered externally?
    Jørgen
  • DannyB said:
    I am using an external Segger JLink USB-based programmer.
    Have you made sure that this programmer supports the voltage level your board is running at?
    DannyB said:
    However, I did try with the Segger onboard the DK and it was the same result
    This makes sense if the custom board runs at 1.76V. The on-board debugger on the DK does not support level-shifting, meaning it can only program boards running at the DK voltage (normally 3.0 V).
  • Interesting, I believe the programmer works at 1.8 V, but I don't know for sure.  I am able to use this JLink on boards I haven't erased.  Here is the log of a successful debug session:
    SEGGER J-Link GDB Server V6.86f Command Line Version
    JLinkARM.dll V6.86f (DLL compiled Oct 23 2020 17:50:09)
    Command line: -if swd -device nRF52840_xxAA -endian little -speed 1000 -port 2331 -swoport 2332 -telnetport 2333 -vd -ir -localhostonly 1 -singlerun -strict -timeout 0 -nogui
    -----GDB Server start settings-----
    GDBInit file:                  none
    GDB Server Listening port:     2331
    SWO raw output listening port: 2332
    Terminal I/O port:             2333
    Accept remote connection:      localhost only
    Generate logfile:              off
    Verify download:               on
    Init regs on start:            on
    Silent mode:                   off
    Single run mode:               on
    Target connection timeout:     0 ms
    ------J-Link related settings------
    J-Link Host interface:         USB
    J-Link script:                 none
    J-Link settings file:          none
    ------Target related settings------
    Target device:                 nRF52840_xxAA
    Target interface:              SWD
    Target interface speed:        1000kHz
    Target endian:                 little
    Connecting to J-Link...
    J-Link is connected.
    Firmware: J-Link V9 compiled Dec 13 2019 11:14:50
    Hardware: V9.10
    S/N: XXXXXXXX
    Feature(s): GDB
    Checking target voltage...
    Target voltage: 1.79 V
    Listening on TCP/IP port 2331
    Connecting to target...
    Connected to target
    Waiting for GDB connection...Connected to 127.0.0.1
    Reading all registers
    Read 4 bytes @ address 0x00000000 (Data = 0x20040000)
    Read 2 bytes @ address 0x00000000 (Data = 0x0000)
    Received monitor command: speed 1000
    Target interface speed set to 1000 kHz
    Received monitor command: clrbp
    Received monitor command: reset
    Resetting target
    Received monitor command: halt
    Halting target CPU...
    ...Target halted (PC = 0x00000100)
    Received monitor command: regs
    R0 = 00000000, R1 = 00000000, R2 = 00000000, R3 = 00000000
    R4 = 00000000, R5 = 00000000, R6 = 00000000, R7 = 00000000
    R8 = 00000000, R9 = 00000000, R10= 00000000, R11= 00000000
    R12= 00000000, R13= 20040000, MSP= 20040000, PSP= 00000000
    R14(LR) = FFFFFFFF, R15(PC) = 00000100
    XPSR 01000000, APSR 00000000, EPSR 01000000, IPSR 00000000
    CFBP 00000000, CONTROL 00, FAULTMASK 00, BASEPRI 00, PRIMASK 00
    Received monitor command: speed auto
    Select auto target interface speed (2000 kHz)
    Received monitor command: flash breakpoints 1
    Flash breakpoints enabled
    Received monitor command: semihosting enable
    Semi-hosting enabled (Handle on BKPT)
    Received monitor command: semihosting IOClient 1
    Semihosting I/O set to TELNET Client
    Received monitor command: SWO DisableTarget 0xFFFFFFFF
    SWO disabled successfully.
    Received monitor command: SWO EnableTarget 0 0 0x1 0
    SWO enabled successfully.
    Downloading 16032 bytes @ address 0x0000C020 - Verified OK
    Downloading 16064 bytes @ address 0x0000FEC0 - Verified OK
    Downloading 16016 bytes @ address 0x00013D80 - Verified OK
    Downloading 16064 bytes @ address 0x00017C10 - Verified OK
    Downloading 16096 bytes @ address 0x0001BAD0 - Verified OK
    Downloading 15872 bytes @ address 0x0001F9B0 - Verified OK
    Downloading 16096 bytes @ address 0x000237B0 - Verified OK
    Downloading 16064 bytes @ address 0x00027690 - Verified OK
    Downloading 16064 bytes @ address 0x0002B550 - Verified OK
    Downloading 16016 bytes @ address 0x0002F410 - Verified OK
    Downloading 16032 bytes @ address 0x000332A0 - Verified OK
    Downloading 16320 bytes @ address 0x00037140 - Verified OK
    Downloading 2224 bytes @ address 0x0003B100 - Verified OK
    Downloading 24 bytes @ address 0x0003B9B0 - Verified OK
    Downloading 2200 bytes @ address 0x0003B9C8 - Verified OK
    Comparing flash   [....................] Done.
    Writing register (PC = 0x    c120)
    Read 4 bytes @ address 0x0000C120 (Data = 0x0000F04F)
    Read 2 bytes @ address 0x0000C120 (Data = 0xF04F)
    Read 2 bytes @ address 0x0000C122 (Data = 0x0000)
    Read 2 bytes @ address 0x0000CA8C (Data = 0xB508)
    Reading 64 bytes @ address 0x0002B980
    Read 2 bytes @ address 0x0002B9B2 (Data = 0xF7E1)
    R14(LR) = FFFFFFFF, R15(PC) = 0000C120
  • Here is the log from a failing board:
    Hardware: V9.10
    S/N: 59103743
    Feature(s): GDB
    Target voltage: 1.80 V
    ERROR: Could not connect to target.
    Target connection failed. GDBServer will be closed...Restoring target state and closing J-Link connection...
    Shutting down...
  • Ok, I was able to recover both boards.  I had to apply power to the nRF as I was calling:
    nrfjprog --recover  --family NRF52
    But I still don't know the root cause for the problem.  Is it possible the nrfjprog --eraseall put the pin pselreset UICR registers in a weird state?  Also, these nRFs had probably never been programmed/erased before i did it.
  • Also, now I can't seem to duplicate the problem.  (I tried a couple times on each board)
