Unable to connect to nRF52840 on custom board over SWD. "No idcode detected:
Hi, I have a custom board with an nrf52840 onboard I was able to program the nrf52, but then I executed:
% nrfjprog --eraseall
and,
% nrfjprog --pinreset
and the JLink can no longer communicate with the board.  I get a "No idcode detected" on SES.  I have also tried nrfjprog --recover and it was not successful.  I thought it may be a bad board, but I now have two boards in the same state.
% nrfjprog --family NRF52 --recover
ERROR: JLinkARM DLL reported an error. Try again. If error condition
ERROR: persists, run the same command again with argument --log, contact Nordic
ERROR: Semiconductor and provide the generated log.log file to them.
All tools are the latest.
log.log:
2260.log.log
Voltage looks good.  Let me know if there is anything else that can help debug.
  • DannyB said:
    I am using an external Segger JLink USB-based programmer.
    Have you made sure that this programmer supports the voltage level your board is running at?
    DannyB said:
    However, I did try with the Segger onboard the DK and it was the same result
    This makes sense if the custom board runs at 1.76V. The on-board debugger on the DK does not support level-shifting, meaning it can only program boards running at the DK voltage (normally 3.0 V).
  • Interesting, I believe the programmer works at 1.8 V, but I don't know for sure.  I am able to use this JLink on boards I haven't erased.  Here is the log of a successful debug session:
    SEGGER J-Link GDB Server V6.86f Command Line Version
    JLinkARM.dll V6.86f (DLL compiled Oct 23 2020 17:50:09)
    Command line: -if swd -device nRF52840_xxAA -endian little -speed 1000 -port 2331 -swoport 2332 -telnetport 2333 -vd -ir -localhostonly 1 -singlerun -strict -timeout 0 -nogui
    -----GDB Server start settings-----
    GDBInit file:                  none
    GDB Server Listening port:     2331
    SWO raw output listening port: 2332
    Terminal I/O port:             2333
    Accept remote connection:      localhost only
    Generate logfile:              off
    Verify download:               on
    Init regs on start:            on
    Silent mode:                   off
    Single run mode:               on
    Target connection timeout:     0 ms
    ------J-Link related settings------
    J-Link Host interface:         USB
    J-Link script:                 none
    J-Link settings file:          none
    ------Target related settings------
    Target device:                 nRF52840_xxAA
    Target interface:              SWD
    Target interface speed:        1000kHz
    Target endian:                 little
    Connecting to J-Link...
    J-Link is connected.
    Firmware: J-Link V9 compiled Dec 13 2019 11:14:50
    Hardware: V9.10
    S/N: XXXXXXXX
    Feature(s): GDB
    Checking target voltage...
    Target voltage: 1.79 V
    Listening on TCP/IP port 2331
    Connecting to target...
    Connected to target
    Waiting for GDB connection...Connected to 127.0.0.1
    Reading all registers
    Read 4 bytes @ address 0x00000000 (Data = 0x20040000)
    Read 2 bytes @ address 0x00000000 (Data = 0x0000)
    Received monitor command: speed 1000
    Target interface speed set to 1000 kHz
    Received monitor command: clrbp
    Received monitor command: reset
    Resetting target
    Received monitor command: halt
    Halting target CPU...
    ...Target halted (PC = 0x00000100)
    Received monitor command: regs
    R0 = 00000000, R1 = 00000000, R2 = 00000000, R3 = 00000000
    R4 = 00000000, R5 = 00000000, R6 = 00000000, R7 = 00000000
    R8 = 00000000, R9 = 00000000, R10= 00000000, R11= 00000000
    R12= 00000000, R13= 20040000, MSP= 20040000, PSP= 00000000
    R14(LR) = FFFFFFFF, R15(PC) = 00000100
    XPSR 01000000, APSR 00000000, EPSR 01000000, IPSR 00000000
    CFBP 00000000, CONTROL 00, FAULTMASK 00, BASEPRI 00, PRIMASK 00
    Received monitor command: speed auto
    Select auto target interface speed (2000 kHz)
    Received monitor command: flash breakpoints 1
    Flash breakpoints enabled
    Received monitor command: semihosting enable
    Semi-hosting enabled (Handle on BKPT)
    Received monitor command: semihosting IOClient 1
    Semihosting I/O set to TELNET Client
    Received monitor command: SWO DisableTarget 0xFFFFFFFF
    SWO disabled successfully.
    Received monitor command: SWO EnableTarget 0 0 0x1 0
    SWO enabled successfully.
    Downloading 16032 bytes @ address 0x0000C020 - Verified OK
    Downloading 16064 bytes @ address 0x0000FEC0 - Verified OK
    Downloading 16016 bytes @ address 0x00013D80 - Verified OK
    Downloading 16064 bytes @ address 0x00017C10 - Verified OK
    Downloading 16096 bytes @ address 0x0001BAD0 - Verified OK
    Downloading 15872 bytes @ address 0x0001F9B0 - Verified OK
    Downloading 16096 bytes @ address 0x000237B0 - Verified OK
    Downloading 16064 bytes @ address 0x00027690 - Verified OK
    Downloading 16064 bytes @ address 0x0002B550 - Verified OK
    Downloading 16016 bytes @ address 0x0002F410 - Verified OK
    Downloading 16032 bytes @ address 0x000332A0 - Verified OK
    Downloading 16320 bytes @ address 0x00037140 - Verified OK
    Downloading 2224 bytes @ address 0x0003B100 - Verified OK
    Downloading 24 bytes @ address 0x0003B9B0 - Verified OK
    Downloading 2200 bytes @ address 0x0003B9C8 - Verified OK
    Comparing flash   [....................] Done.
    Writing register (PC = 0x    c120)
    Read 4 bytes @ address 0x0000C120 (Data = 0x0000F04F)
    Read 2 bytes @ address 0x0000C120 (Data = 0xF04F)
    Read 2 bytes @ address 0x0000C122 (Data = 0x0000)
    Read 2 bytes @ address 0x0000CA8C (Data = 0xB508)
    Reading 64 bytes @ address 0x0002B980
    Read 2 bytes @ address 0x0002B9B2 (Data = 0xF7E1)
    R14(LR) = FFFFFFFF, R15(PC) = 0000C120
  • Here is the log from a failing board:
    Hardware: V9.10
    S/N: 59103743
    Feature(s): GDB
    Target voltage: 1.80 V
    ERROR: Could not connect to target.
    Target connection failed. GDBServer will be closed...Restoring target state and closing J-Link connection...
    Shutting down...
  • Ok, I was able to recover both boards.  I had to apply power to the nRF as I was calling:
    nrfjprog --recover  --family NRF52
    But I still don't know the root cause for the problem.  Is it possible the nrfjprog --eraseall put the pin pselreset UICR registers in a weird state?  Also, these nRFs had probably never been programmed/erased before i did it.
  • Also, now I can't seem to duplicate the problem.  (I tried a couple times on each board)
