Maximum bytes sent in a characteristic indicate function
Hi, I need to send data larger than 16 bytes on a characteristic.  I see that the maximum number of bytes I can send using the indicate function is limited to 16 bytes.
static uint8_t sm[16];
ind_params.attr = &vnd_svc.attrs[2];
		ind_params.func = indicate_cb;
		ind_params.data = &sm;
		ind_params.len = sizeof(sm);
		if (bt_gatt_indicate(NULL, &ind_params) == 0) {
			indicating = 2U;
Ideally, I need sm[] to be between 32 bytes and 64 bytes.  Is there a way to increase this size or do I have to send multiple 16-byte packets?  I am developing using Zephyr.  Your help is highly appreciated.
    As defined in Bluetooth spec, you can't do "long" notification/indication. So indication/notification can only sent as one single BLE packet. The ATT_MTU would decide the max size of a notification/indication you can send. For example if you set CONFIG_BT_L2CAP_TX_MTU = 23 bytes, you can send maximum CONFIG_BT_L2CAP_TX_MTU - 3 = 20 bytes payload (3 bytes overhead including opcode & handle value).
    What you mentioned about 16 bytes maximum sounds a little bit strange, most likely it should be 20 bytes if the CONFIG_BT_L2CAP_TX_MTU is minimum at 23 bytes.
    If you want to send larger indication/notification you would need to increase the CONFIG_BT_L2CAP_TX_MTU size. But please note that the actual ATT_MTU used in a connection depends on both sides. So if your peer device doesn't support large ATT_MTU you will receive "No ATT channel for MTU" warning when you send larger than limit indication as you already observed.
    You can use bt_gatt_get_mtu() to get the actual mtu of a connection.
  • Hi .  Thank you for your reply.  I will be dealing with large amounts of sample outputs from sensors.  If notifications/indications are not meant for large amounts of data, how would I go about sending large amounts of data?
    I did double-check and the maximum amount of bytes that I can send over a notification is indeed 20 bytes.  I will try and increase the MTU size.
    To get a high throughput you should try to achieve the maximum ATT_MTU and longest data length extension CONFIG_BT_CTLR_DATA_LENGTH_MAX (usually set = ATT_MTU+4) .
    If the size is still smaller than the amount of data you want to send, you would need to segment it to multiple trunks and send one by one.
