debug session doesn't stop at main
Hi
I am trying to debug the "ble_app_hrs" example from SDK 6.1.0 (using keil IDE), on 51822 chip. The IROM1 is defined to start at 0x16000 (meant to be used with softdevice). when I start the debug session, the debugger doesn't stop at "main" (even with a breakpoint). The only solution I have found is to set IROM1 to 0x0, and than debugger stops at main and I am able to single step.
Is there a way to debug without changing IROM1 definitions?
  • Hi Martin.
    First, thanks for the quick response. I am aware that I cannot change the IROM1 settings in order to run a ble example , but that is not the issue. I want to be able to single step inside the debugger in order to better understand certain functions. I do not need the actual ble service (and that's why I don't need to load the softdevice).
    I just wondered if there is a way to do this without changing IROM1 settings. Thanks again Yaron
  • Hi Martin
    "You want to debug the code in the ble_app_hrs example, but you want to do it without running the bluetooth stuff?" - correct
    "You can set breakpoints in your code, but the debugger runs past them? Or is the problem that the debugger never reach them?" - I can set breakpoints, but it seems that the debugger never reaches tham
