The following define is present in file nrf_sdm.h, SDK 17.0.2:
#define SD_FLASH_SIZE 0x26000
I think it's wrong, it shall be 0x27000. But it's maybe not used at all.
Correct you are! Here's the release notes for S140 v7.2.0, where its clearly stated:
Thank you very much for pointing this out to us, and taking the time to file a report on the matter. thank you very much for helping us improve our delivery!
I will make sure that our SDK team is aware of this bug.
I hope you have a nice weekend!
Håkon
*edit*:
It looks like we both read the header definitions incorrect.
The define doesn't include the size of the MBR region, which is 0x1000. It looks to be correct in that sense:
/** @brief Defines the amount of flash that is used by the SoftDevice. * Add @ref MBR_SIZE to find the first available flash address when the SoftDevice is installed * just above the MBR (the usual case). */ #define SD_FLASH_SIZE 0x26000
Where MBR_SIZE is define to:
/** @brief The size that must be reserved for the MBR when a SoftDevice is written to flash. This is the offset where the first byte of the SoftDevice hex file is written. */ #define MBR_SIZE (0x1000)
Since the "SD_FLASH_SIZE" excludes the MBR region, it is correctly defined.
