Right now, I am trying to open that example files in SES IDE. But I couldn't open.
I kept the file location like as
D:\Nordic\nRF5_SDK_17.0.2_d674dde\examples\peripheral\uart\pca10056\blank\ses
Please give your guidelines
But I couldn't open
So what, exactly, did you try?
You should be able to open the project by simply double-clicking the .emProject file in the Windows file explorer.
eg,
Or, from within the IDE, use File > Open Solution:
Which will let you browse for .emProject files:
It looks like your are trying to open the project file itself:
Now also I tried whatever you shared here. But i couldn't open.
I want to open that attached image like that
Hi.
Could you try to press the "Collapse to Folders" button in the project explorer and see if you can see the rest?
If that doesn't work, I'm, not sure what the problem is. Maybe you could try to make a fresh download of the nRF5 SDK and see if that fixes the problem.
Is it the same for every project in the SDK? Can you try with another example?
I tried "Collapse to Folders" and another example. Still that is not open
It's still not at all clear what you're actually doing.
Remember that we cannot see your screen, and we cannot see what you are doing - so you need to give a complete, detailed, step-by-step description of exactly what you are doing, what is happening, and what you are seeing on your screen.
Start from showing the Project file in the Windows explorer.
Or, preferably, find someone local to assist you.
