Multiple SAADC Samples
I'm having issue where after booting I can immediately do three SAADC samples as follows:
    for (uint8_t i = 0; i < SAMPLES_IN_BUFFER; i++)
	nrfx_saadc_sample();
	nrf_delay_ms(SAADC_SAMPLE_DELAY);
This works as expected where I get the callback immediately after the third call to nrfx_saadc_sample(). I needed to put in a 1ms delay, otherwise the first sample is 0; However, when I do the same thing in a timer handler, I cannot do three samples in a row. The timer needs to timeout three times in order to get the three samples. I doesn't matter how long the delay time is (I've put in up to 1 second), the only way to get three samples is for the handler to trigger three times. I'm using an app_timer. Here is the handler code:
static void advertise_timeout_handler(void * p_context)
Here is the SAADC initialization code:
static void saadc_init(void)
    ret_code_t              err_code;
    nrf_drv_saadc_config_t  saadc_config;
    saadc_config.low_power_mode = NRFX_SAADC_CONFIG_LP_MODE;
    saadc_config.resolution = NRF_SAADC_RESOLUTION_10BIT;	//Set SAADC resolution to 10-bit. This will make the SAADC output values from 0 (when input voltage is 0V) to 2^10=1024 (when input voltage is 3.6V for channel gain setting of 1/6).
    saadc_config.oversample = NRF_SAADC_OVERSAMPLE_DISABLED;    //Disable oversample. Can't oversample with more than one channel active.
    saadc_config.interrupt_priority = NRFX_SAADC_CONFIG_IRQ_PRIORITY;
    nrf_saadc_channel_config_t channel_config =
    NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_VDD);
    err_code = nrf_drv_saadc_init(NULL, saadc_callback);
    err_code = nrf_drv_saadc_channel_init(0, &channel_config);
    err_code = nrfx_saadc_buffer_convert(m_buffer_pool, SAMPLES_IN_BUFFER);
Here is the callback code:
static void saadc_callback(nrf_drv_saadc_evt_t const *p_event)
    static uint32_t m_adc_evt_counter;
	uint32_t voltage;
	uint16_t average_sample = 0;
	err_code = nrfx_saadc_buffer_convert(p_event->data.done.p_buffer, SAMPLES_IN_BUFFER);
	SEGGER_RTT_printf(0, "\nADC event number: %d\n", m_adc_evt_counter);
	    voltage = p_event->data.done.p_buffer[i] * 3600 / 1024;
	    SEGGER_RTT_printf(0, "%d\n", voltage);
	    average_sample += voltage;
	if((++m_adc_evt_counter % SAADC_CALIBRATION_INTERVAL) == 0)
	    m_saadc_calibrate = true;
	battery_voltage = average_sample / SAMPLES_IN_BUFFER;
	change_manuf_specific_data();
Why does the timer handler have to trigger three times in order to get three samples when outside of the hander after booting, I can do three samples in row and get a valid result?
    On a general note, I can not recommend that you add delay's to any interrupt handling. Interrupts should complete quickly, as to let lower-priority processes have a chance at completing.
    It might function for now, in this particular project, but as the project gets bigger it is probable that it will cause some issue.
    Please make sure to add a APP_ERROR_CHECK to the error code returned by nrfx_saadc_sample - if you do not check the returned error codes you will not have any way of knowing whether the function call was successful or not.
    Furthermore I notice that the timeout function is called advertising_* - is this process in any way related to BLE? Please know that the SoftDevice takes priority over any application-layer task to do timing-critical operations, such as advertising at a specific interval or maintaining a connection. Since you are using the nrfx_saadc_sample function you will need the CPU to start this sampling, which might be busy with the SoftDevice.
    Instead, you might want to look into connecting the sampling task directly to your timer event by PPI. This way, it will not require CPU intervention to begin.
    Looking forward to resolving this issue together,
    Karl
  • I can look at using the PPI channel again. This is a very low-power application, so I would need to use the app_timer.
    The timeout function handler named "advertising" initiates the beacon advertising. This actually done through the SAADC callback function by calling change_manuf_specific_data(). nrfx_saadc_sample() starts the process, the advertising is not active when this call is made.
    Having your sampling trigger through PPI will likely reduce your applications power consumption, since it allows the CPU to spend its time completing other tasks or going to SYSTEM ON sleep.
    Thank you for clarifying.
    Did you add the APP_ERROR_CHECK to your sample call, to see if the samplings were actually successful in your previous test?
    Karl
  • Yes, I added APP_ERROR_CHECK to the call. There is no error.
    It seems as if the PPI channel needs a timer compare channel. How do I do this with the app_timer?
    So, you are receiving 3 NRF_SUCCESS's returned from the _sample triggering function, but you are not receiving the SAADC DONE event? What is the contents of your SAADC buffer after the third NRF_SUCCESS is returned from the sample trigger function?
    The PPI channel will connect a hardware event directly to the sample TASK. The app_timer is a software implementation built on top of the RTC peripheral, and is therefore not the best match for using with PPI since you will get COMPARE events from all of the app_timer's channels.
    Instead, you could set up a separate RTC or TIMER instance, to provide these periodic interrupts for the SAADC.
    Setting up the SAADC to trigger from a TIMER's interrupts through PPI is demonstrated in the SAADC peripheral example in the SDK, I highly recommend taking a look at it to see how you may go about doing this in your own application.
    Karl
