nRF52 Connect after scan_evt_handler()
I am using the nRF5_SDK_17.0.2  "examples\ble_central\ble_app_blinky_c" example to start with my device.
It works using "init_scan.connect_if_match = true"
However, my project need to control when the device should be connected.
So I have change it to "init_scan.connect_if_match = false".
Which API should be called to connect to the device ?
void scan_evt_handler(scan_evt_t const * p_scan_evt)
switch(p_scan_evt->scan_evt_id)
   case NRF_BLE_SCAN_EVT_FILTER_MATCH:
//  Connect HERE when certain condition met
  • I think you have better to do the connect rule in nrf_ble_scan.c
    static void nrf_ble_scan_on_adv_report(nrf_ble_scan_t const * const p_scan_ctx,
    ble_gap_evt_adv_report_t const * const p_adv_report)
    if ((all_filter_mode) &&(!is_filter_matched))
    if (........) /* your connect rule here*/
    scan_evt.scan_evt_id = ........;    /* your definition event here*/
    nrf_ble_scan_connect_with_target(p_scan_ctx, p_adv_report);
    scan_evt.scan_evt_id = NRF_BLE_SCAN_EVT_NOT_FOUND;
    scan_evt.params.p_not_found = p_adv_report;
